Fork Oil
instigator
PostPosted: 09:07 - 05 Aug 2005    Post subject: Fork Oil Reply with quote
Does anyone know what fork oil 'rating' I should put in my forks of my 600 hornet if I want to stiffen it upa little?
I find the front moves too much and needs stiffening. I'm replacing fork seals at the moment, not willing to buy better springs as of yet as I don't want to spend that much money really.
Ideas?
BFG
PostPosted: 09:54 - 05 Aug 2005    Post subject: Re: Fork Oil Reply with quote
If it moves too much, you need to incease the pre-load. This means altering the springs. Altering the oil will change the damping only!
It you can't afford new springs you can put spacers on the top end of the springs. This is a short term bodge only, as although it will stiffen the pre-load, it shortens the effective travel of the forks.
Personally, I would go to a breakers yard with my old springs and a vernier. They usually have a box of pairs of springs.
PostPosted: 11:39 - 05 Aug 2005    Post subject: Reply with quote
You can use thicker oil, but as mentioned above this affects the damping. The forks will still dive just as far but will just take longer to dive (and also longer to return).
A couple of 10p piece worth of preload on the springs might help.
Also try fiddling with the fork oil level. More oil means less air above the oil, and the air needs to be there to compress when the forks compress. Reduce the air gap and you stiffen the forks. Very cheap and easy to do (although potentially putting more stress on the fork seals). Probably worth reducing the air gap by 10mm and see how that goes. Easy to add a small measured amount of oil to each fork afterwards to reduce the air gap further.
jay12329
Dr. Evil
PostPosted: 20:45 - 05 Aug 2005    Post subject: Reply with quote
You have 3 options to improve the front end of the hornet.
1, Replace oil with thicker, or use one of the little tricks mentioned above. Will improve slightly but genrally at the cost of other performance.
2, Replace springs with ohlins or WP. Changeing oil at the same time. This will reduce dive but can also cause issues with other areas of the suspention performance.
3, Full re spring and revalve from BSD. This is the most expencive and best option for both track and road rideing. The forks are set up to your body weight.
I have fitted ohlins springs to my hornet 6' this has reduced the dive under brakeing but there is very little dampning causing the front to skip under braking as the springs force the front end up sudenly. I will be changing my oil for heaver 15w oil shortly to try and reduce this.
The only sure way to sort the hornet suspention is to replace the rear shock and get the front end re-valved. This will cost £500 for an ohlins shock and around £200 for the re valve. BSD are the only company i would trust with my forks as they do all the work for the Hornet cup bikes so have devolped there own method of revalving the basic hornet units.
HTH
J
instigator
PostPosted: 21:51 - 05 Aug 2005    Post subject: Reply with quote
Right.
Shocked
Didn't realise it was that much of a deep-rooted problem. I mean, the bike handles amazingly, just less so at say 80-90+mph. Just dives a lot is the problem. I'll try the thicker and more oil to see what happens with it. Cheers for the assistance folks. Thumbs Up
BFG
PostPosted: 12:43 - 06 Aug 2005    Post subject: Reply with quote
Sorry to labour the point, but most people play with the oil because it is cheap and easy. But, the short path leads to the dark side! Wink
See our advice on damping.......
IMHO, increasing damping without increasing pre-load can make bikes handle dangerously.
If you are on a tight budget, you really can swap parts. A lot of people frown on this as they see it as being "not a proper one". But springs are springs. There are differences, but they aren't that significant. Consider that all the Jap four buy in their springs from outside suppliers anyway - usually the same ones Wink
Swapping for springs from a different bike is perfectly safe. People don't advocate it because it takes time and care, and won't make as much difference as a pukka job. But you'll get close, for about 25 quid. I have done this myself, where I had a bike that no-one made progressive springs for. We can assist in giving info on what to look for.
Another method, which will work - is to get some spacers machined up to fit on top of the springs, about 1.5 in long - then cut 1.5 inches from the loosly wound end of the springs. This will give you increased spring strength without the suspension travel being affected. You could even cut just 1", and use 1.5" spacers for greater effect.
Smile
PostPosted: 16:24 - 06 Aug 2005    Post subject: Reply with quote
Good idea.
For those who think that cutting length of the spring does not logically sound like it makes them stiffer, think that a spring works by twisting the metal as the spring compresses. Make it shorter and to compress it needs to twist the metal more.
Robby
Dirty Old Man
PostPosted: 17:29 - 06 Aug 2005    Post subject: Reply with quote
Getting back to the root problem, you currently have blown seals. That means the air isn't getting compressed much and a large amount of the oil has probably pissed out of the blown seals.
Its going to handle shit on bumps in this situtation.
The last post was made 21 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 16 - Page Size: 63.14 Kb
