Oh man another problem, this time with cooling system!!
18aprilia
I don't get it?
PostPosted: 22:03 - 26 Aug 2005    Post subject: Reply with quote
do you have that little seal that comes with the cap its almost always right under it???? it helps get the pressure out when u put it on
Supra King
mchaggis
PostPosted: 22:06 - 26 Aug 2005    Post subject: Reply with quote
Personally I reckon your head gasket is gone, and it's blowing exhaust into the water jacket: exhaust and steam from the coolant is overpressurising the system. That is very bad news itself, and if allowed to overheat, the head will warp and have to be skimmed. It is however, a fairly simple job to replace it, especially on a two-stroke, with no overhead valves.
Has there been any steam from the exhaust?
I must not be a troll...
Mmmm, Guinness
sickpup
Old Timer
PostPosted: 22:33 - 26 Aug 2005    Post subject: Reply with quote
Headgasket.
sickpup
Old Timer
PostPosted: 23:23 - 26 Aug 2005    Post subject: Reply with quote
Yokogeri wrote:
ARGH for god sake! Will it smell of exhaust gasses if I smell it?? Also wouldnt I lose compression and the engine not run?
You asked so cut the drama.
Why would it smell of exhust as it comes out the CYLINDER? think about it. Also most of the componants of exhaust gas break down in water I believe.
Why would the bike not run? yes the compression would be lower but the gas is being pushed into the water jacket not the water being pushed into the cylinder.
Well I suppose you could always carry on believing you have a family of elves or pixies putting the air in the coolant system.
bish777
PostPosted: 23:32 - 26 Aug 2005    Post subject: Reply with quote
your not in the bloody signals are you?
GSXR1100J
bish777
PostPosted: 23:42 - 26 Aug 2005    Post subject: Reply with quote
ahhhh
well then its Corporal to you! lol
Well used to be anyways am a john Q civvy now.
I was a Combat Telecommunications Technican (Radio), then i did so many systems courses when i did my T2 i converted to a Systems tech.
did a few tours here and there (mostly balkans) and got out august 2002.
If you get sent to 600 sig troop in corsham give us a pm!
GSXR1100J
bish777
PostPosted: 23:48 - 26 Aug 2005    Post subject: Reply with quote
where you at now? Bassingbourne?
GSXR1100J
bish777
PostPosted: 23:51 - 26 Aug 2005    Post subject: Reply with quote
[email protected]
GSXR1100J
PsychoHippy
Jammy Git
PostPosted: 22:39 - 27 Aug 2005    Post subject: Reply with quote
Yeah, me too, as you will be working about a mile from my house Thumbs Up
I spend all my money on bikes and beer, the rest I simply waste!
James
PostPosted: 22:53 - 27 Aug 2005    Post subject: Reply with quote
Could be a stubborn airlock as often they're tricky to bleed. Could be head gasket, hard to tell without looking at the bike. Hows it running now mate?
Like shit off a stick
binge
Emo Kiddy
PostPosted: 00:54 - 28 Aug 2005    Post subject: Reply with quote
XL125. Wink
No cooling system, to worry about. Laughing
binge
Emo Kiddy
PostPosted: 01:06 - 28 Aug 2005    Post subject: Reply with quote
Hmm. 2 stroke cooling systems. Had many problems with mine on my speedfight.
I ended up puttting fresh in mine and then leaving it ticking over with the rad cap OFF for about an hour with a fan blowing cold air onto the radiator to get all the air out of my system...
Head gaskets are Piece of P1ss to change on 2 strokes. Few bolts and your done. Cool
even liquid cool'd are easy.
Ichy
PostPosted: 01:07 - 28 Aug 2005    Post subject: Reply with quote
Slighty out of context but I used to have problems with BMW's (cars) that used to cause me the same headache, it was almost impossible to get all the air out doing things the proper way, used to run them with the cap off and a hose pipe through the top hose. Same symptoms as you particulary the 'eruption' bit when the air finally escapes. If the head gasket has gone then there is usually water going into the cylinder as well, you might see this on the plug.
The last post was made 21 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.24 Sec - Server Load: 1.17 - MySQL Queries: 71 - Page Size: 79.24 Kb
