Emergency Stop on test
FreshAL
Sir Crashalot
PostPosted: 13:20 - 02 Sep 2005    Post subject: Emergency Stop on test Reply with quote
I have developed a habit of changing down during an emergency stop.
I'm doing the front brake, rear brake, progressively on the front, clucth in routine ok, but as soon as I pull the clutch in, my left foot clicks down a gear.
It doesn't seem to affect the stopping distance, but will it just be a minor on test or a fail?
Just wondering how much effort I need to put into training myself out of this habit.
craigs23
Mr Muscle
PostPosted: 13:41 - 02 Sep 2005    Post subject: Reply with quote
Not sure if it'll help in any way, but I tend to ride with the balls (near toes) of my feet on the pegs. Maybe it'll keep your foot further away from the gear level?
fuzz
PostPosted: 13:51 - 02 Sep 2005    Post subject: Reply with quote
Do not change down a gear on your test. This is not an emergency stop! Pull the clutch in just as you almost stall the engine, and you should have your left foot ready to place on the tarmac by this time. Get yourself out of this habit quick!
cunni
PostPosted: 15:04 - 02 Sep 2005    Post subject: Reply with quote
First of all, there is no such thing as an Emergency Stop anymore, due to it implying panic braking, it is now called something daft like Rapid speed Reduction Exercise, or something equally as bizzare!
first of all, brake as hard as you can front and back without either of the wheels locking or sliding, otherwise it's an instant fail.
come to a halt and put which ever foot it is you are supposed to put down on the ground. If you go down the gears, great! If you can use engine braking as well, then all the better. You will not pick up any minors for this! Also, if you leave the clutch out, it shows you were engine braking. It is possibly to leave the clutch totally and even stall as a result and not gain any marks. (unless you shout dam/shit or shake your head like you fecked it up - then you'll get a bad mark!)
Just get the bike stopped as fast as you can by what ever means without locking any of the wheels!
sounds to me that you ahve this nailed mate!
TL1000R Parts For Sale!
fuzz
PostPosted: 16:01 - 02 Sep 2005    Post subject: Reply with quote
No it's not. I locked both wheels and still passed because I let go of the brakes slightly to regain traction, then reapplied pressure until I stopped. Dealt with the situation, no fail!
Going2fast
PostPosted: 16:07 - 02 Sep 2005    Post subject: Reply with quote
Thumbs Up If anything that shows your in complete control, Had to do the same if i rem correctly.
Passed My Test 15/03/05 Very Happy Very Happy
BikePics Profile ||| 96' RVF 400 ||| 01' CBR 600 F Sport ||| 2009 Yamaha YZF-R6 Delivered 23/06/09
/-\ndy
JonT
PostPosted: 16:12 - 02 Sep 2005    Post subject: Reply with quote
I never had to do an emergency stop because near the start of the test I was panicking and not paying attention and didn't slow down before some lights. Some lights which then changed to red.
I did my finest emergency stop to come to a halt before the white line. I picked up a minor for awareness but then didn't have to do the E-Stop seperately Smile
DanceLikeAMon...
PostPosted: 20:30 - 02 Sep 2005    Post subject: Reply with quote
I had exactly the same problem with emergency stops. The way my instructor got me through the test was to make me point my left foot out at 45 degrees. There's no penalty for feet position on the pegs and it makes it very easy not to change gear! Thumbs Up
The Old Geeza
Back in my day...
PostPosted: 21:56 - 02 Sep 2005    Post subject: Reply with quote
Correct.
As long as you don't skid to a halt, you'll pass the Emergency Stop (or whatever fancy name some others might like to give it these days. It's still an Emergency Stop irrespective, and it'll be described that way on your test).
Best of luck Thumbs Up
Horse Power was safer when the Horses had it!
krebsy
PostPosted: 14:57 - 06 Sep 2005    Post subject: catching me out... Reply with quote
The E-Stop kept catching me out and two things sorted it in the end. A morning on the playground relying on the front brake to stop and NOT using the rear break, just covering it with my right foot.
My tip is to change up to 3rd gear to use Max. engine braking, Close the throttle and progressively squeeze the brake lever whilst locking your arms out straight. By the time you have locked out your arms you will be able to rest your foot on the rear brake, but don't push it. The locked arms will stop your weight sliding forward (to avoid putting it onto the rear brake through your foot) and make sure you keep looking at the examiner. If you don't watch him then the bike will wobble or pitch off balance. When you are about to stop, pull in the clutch, bring her to a halt and get your left foot ONLY down.
If you pull in the clutch too early then you lose all the drive to the rear. Having the drive prevents the rear locking up if you do press slightly too hard on the back brake.
Well, it worked for me anyway... Wink
K.
1280 x 1024.
Slinn84
PostPosted: 16:59 - 06 Sep 2005    Post subject: Reply with quote
i was always told by my instructor that you will fail if you down change during your e/stop
rubbish took my test, rode round the circut he told me to, his hand went up, throttle off, front brake on, rear brake, harder and harder, clutch in, ooops foot hit the gear lever and into first.
thought i'd failed but after the test (i passed) the examiner said it was fine
the idea behind the e/stop is to stop as quickly and safely as possable, changing gears is fine so long as u stop safely, covering the clutch will give you a minor as the examiner will assume your anticipating his actions but i doubt he will fail you.
also you can lock wheels up and still pass, so long as you let off the brakes easily then re-apply and stop safely.
my mate locked a wheel up and recovered well but thought he'd failed cos of it, as a result he didn't concentrate on the rest of his test, turned out his e/stop was fine, but he failed cos after his stop he did'nt do any life savers hehe silly boy
Misc
PostPosted: 19:12 - 06 Sep 2005    Post subject: Reply with quote
Ya, I was also told it doesn't matter if you stall as the point is just to stop, Then my other instructer said no you have to keep it from stalling Confused
Rookie
PostPosted: 00:11 - 07 Sep 2005    Post subject: Reply with quote
Well isn't a stall a minor, so it would be best not to.
This is helpful stuff!
fuzz
PostPosted: 01:16 - 07 Sep 2005    Post subject: Reply with quote
IIRC you should stop the bike without locking either wheel and without stalling, but whether this would give you a minor or a fail I suppose is down to the examiners discretion. If you stop safely, I don't see how you can fail it.
JonT
PostPosted: 03:28 - 07 Sep 2005    Post subject: Reply with quote
Surely selecting a higher gear would give you less engine braking?
getcarter4dyn...
PostPosted: 03:46 - 07 Sep 2005    Post subject: Reply with quote
what the fuck are u lot talking about? Rolling Eyes
give it a rest! Twisted Evil
Misc
PostPosted: 08:42 - 07 Sep 2005    Post subject: Reply with quote
Then remember to push the bike to the side, I forget this Smile
krebsy
PostPosted: 22:03 - 15 Sep 2005    Post subject: Instructor... Reply with quote
My instructor said change up so I changed up. Worked for me.
K.
1280 x 1024.
fuzz
PostPosted: 13:20 - 16 Sep 2005    Post subject: Reply with quote
You get more engine braking in a lower gear. This is because the rear wheel is trying to turn the engine. It is hard for the engine to turn the wheel in a high gear (which is why you pull away in first,) whereas it's hard for the wheel to turn the engine in a low gear i.e. more braking force.
Nb
PostPosted: 19:19 - 16 Sep 2005    Post subject: Reply with quote
Ive had a lesson today and take my test on tuesday....i've been told to ride to the side of the road not push. First time i tried an emergency stop i stomped on the back brake Neutral
Misc
PostPosted: 19:56 - 16 Sep 2005    Post subject: Reply with quote
I think everyone gets told diffrent,
My instructer said also you have to make sure you don't stall (Show you have control)
My other one said (Don't matter if you stall as the object is just to stop)
I'm not looking foward to my u-turn, I can do it fine but theres the odd times when you loose balance. Smile
Gimboid
PostPosted: 03:39 - 20 Sep 2005    Post subject: Reply with quote
As an instructor I would say:
You must make an attempt to pull in the clutch at the end, to help show (same as your U-Turn) that you have proper control of the bike, but stalling does not matter and will not cause any minors / fail, but does make your riding look tidier if your able to stop neatly AND keep it running.
Changing down is discouraged by all Instructors, and your told your going to fail for a simple reason:
- Changing Down is an automatic reaction you've already had drummed into your previous changing... slowing down > change down. part of this automatic action is to pull in the clutch.
- Changing down a gear whilst doing an emergency stop will quite often cause some students to pull their clutch in first
- Whilst pulling the clutch in early may not mean an instant fail, it will most likely get you a minor mark, but much more dangerously, with the clutch in your rear wheel has nothing trying to keep turning it, and you GREATLY increase the chance of a SKID by pulling in your clutch too early.
Many things in a bike test are just like the car test, in the "Turn in the Road" (Read politically correct 3 point turn) you dont HAVE to put your hand break on between each part, but it looks tidier and more professional if you do.
Flip
PostPosted: 03:54 - 20 Sep 2005    Post subject: Reply with quote
Can't be bothered to read all this thread but if no-one had already said it....
Dont even cover the clutch till you need to use it. If the examiner sees you covering the clutch ready, he'll ask you to do it again and you'll only get one more chance. Thumbs Up
The last post was made 21 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.74 - MySQL Queries: 16 - Page Size: 125.61 Kb
