Cleaning Air Filter
dransy
PostPosted: 11:20 - 12 Sep 2005    Post subject: Cleaning Air Filter Reply with quote
Hi all
Im planning on giving my bike a little service today cleaning carbs , replacing oils *etc* and i was just woundering what i can use to clean my air filter?
Run it under the tap and squeeze it? or let it soak in something?
Anything will do just woundering whats best to clean it with.
Marc
killa
Won't Shut Up
PostPosted: 11:29 - 12 Sep 2005    Post subject: Reply with quote
Use something with high alcohol other wise it will be damp and under perform for ages.
I used my mates compressed air tool to blast it through.
map
Mr Calendar
PostPosted: 11:54 - 12 Sep 2005    Post subject: Reply with quote
Assuming it's the foam type (you did say squeeze).
Rinse and clean out using petrol (a small bowl helps).
Then leave to dry.
Then get some new oil and soak this through the foam. Sqeeze out any excess, you don't want it dripping. The oil is there so that any muck sticks to it and doesn't end up in the carbs.
If it's the folder cardboard/paper type then these can be cleaned out using an air line/compressor. However, easily damaged and so sometimes not worth the hassle. If available often easier to just get a new one of these types (only clean if not available).
FWIW for servicing, Hein Gericke do an offer of oil, oil filter and air filter. If there's one near you might be worth a try, although check first as they don't always have the filters (but you can get for another bike under the same deal!).
HTH Thumbs Up
dransy
PostPosted: 11:56 - 12 Sep 2005    Post subject: Reply with quote
My uncle cleaned it for me when first got the bike , he used a bowl of petrol but i wasnt to sure on it,
Cheers map
Johnny GSX-R
PostPosted: 12:01 - 12 Sep 2005    Post subject: Reply with quote
I use warm soapy water and then rinse it through before hanging it on the washing line whilst i do the service and check up,, usually find it dry by the time i'm ready to re oil and re insatall.
dransy
PostPosted: 12:17 - 12 Sep 2005    Post subject: Reply with quote
Warm soapy water as in soap and water
Or somethinglike washing up liquid?
Marc
The last post was made 21 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 1.55 - MySQL Queries: 16 - Page Size: 52.09 Kb
