| jamie192 |
 jamie192 Spanner Monkey
| feef |
 feef Energiser Bunny
| Fellony |
 Fellony Scooby Slapper
 Posted: 16:50 - 20 Sep 2005 Post subject: |
im pretty sure zxr 400 bearings are pressed in. ____________________ A2 License
'92 Honda CBR400RR NC29 |
| jamie192 |
| feef |
| jamie192 |
| feef |
| jamie192 |
| feef |
| jamie192 |
 Posted: 17:31 - 20 Sep 2005 Post subject: |
Get a chisel (fairly long and thin, possibly an old and knackered screw driver that you do not care about). Put this in the hole on the inside and push the inner spacer to one side (sometimes they only have clearance to move on on end). Then put the end of the chisel though one side and onto the inside race of the bearing on the other side (hopefully the spacer is far enough to one side to allow this, if not keep trying) and start to knock it out.
You will probably have to move across to the other edge of the bearing to get it to come out straight. They come out normally without too much effort.
When putting the new one in place use a something like a large socket as a drift to ensure you only push on the outer edge of the new bearing. Do not forget the spacer, it is important.
 Posted: 20:25 - 20 Sep 2005 Post subject: |
Remember to take any circlips out first There is usually one on the outside of each bearing holding them in.
Then as kickstart says, drift it out from the middle by getting the wheel up of the ground on two blocks (with a gap in the middle for the bearing to drop out into), pushing the spacer to one side and tapping round the middle race until it drops out.
My preferred tool for drifting things is surprisingly, a drift:
https://webserver.diygear.com/acatalog/3658a-6.jpg
In the absence of one you can substitute a long bolt, you need to keep filing the end of the bolt square because it is soft metal and rounds off easily. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mrchips |
 mrchips World Chat Champion
 Posted: 20:31 - 20 Sep 2005 Post subject: |
Last time I was doing this I used my hammer and my trusty red handled screwdriver. ____________________ Northern Irish? www.nibikers.com |
| Teaman |
 Teaman World Chat Champion
| jamie192 |
| mr.z |
 mr.z World Chat Champion
 Posted: 01:37 - 21 Sep 2005 Post subject: |
You can use a suitably sized socket as a drift if you dont mind mashing it...
I'm pretty sure the zxr400's wheel bearings are straightforward enough, so i'd guess yours are too (certainly didn't need a press)
In addition to gentle heat (dont know how sensible it would be there) you can use this stuff called "freezer" comes in a can and lowers the tempreture to -30 ish... its been very handy being used with my trusty mallet in the past  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
The last post was made 21 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
