GSXR 600 K4, help.....
UrbanRacer
PostPosted: 01:54 - 25 Sep 2005    Post subject: GSXR 600 K4, help..... Reply with quote
Hi, my bike seems to be running rough as f**k the passed week, surprisingly just after its 4k service.
the idle speed seems very erractic (more so than normal) and cuts out sometimes, even tonight when the bike was warmed up it stalled sitting at a set of traffic lights.
when the bike has been sitting overnight or even just after a few hours and the engine has cooled i'll normally sit for a few mins till the engine temp comes up to about 50c before i set off, but now when i do this the bike seems to shudder at low rpms in 1st gear and i have to open up the throttle a bit more to smooth it out.
to me its sounds like the fuel mixture was changed when it went in for its service and its now running lean (i cant smell fuel)
anyone have any other ideas?
LittleGSXRgir...
PostPosted: 06:16 - 25 Sep 2005    Post subject: Reply with quote
What was done at the 4k service?
My thought at first was...fuel filter or bad tank of gas.
UrbanRacer
PostPosted: 11:33 - 25 Sep 2005    Post subject: Reply with quote
the fuel i use is Shell Optimax (97 ron)
i'm going to up the idle speed slightly and check the plugs
gavin
PostPosted: 11:37 - 25 Sep 2005    Post subject: Reply with quote
did you use optimax before this problem? optimax requires different jetting as its density is higher.
https://www.shell.com/home/Framework?siteId=uk-en&FC2=/uk-en/html/iwgen/leftnavs/zzz_lhn3_1_1.html&FC3=/uk-en/tailored/shell_for_motorists/fuels/optimax/optimax_faqs_ga_1602.html
UrbanRacer
PostPosted: 11:47 - 25 Sep 2005    Post subject: Reply with quote
yea i did, the bike ran sweet
Slinn84
PostPosted: 13:15 - 25 Sep 2005    Post subject: Reply with quote
sounds like a similar problem to me, bike idle seemed jerky and never really settled, it needed warming up evertime i left it for more then a few hours and seemed a bit jerky at low speeds
try giving your carbs a good clean, if your service ppl had it all exposed then some crap could have got in there and be messing things up a bit. does the bike seem to vibrate more then it did before too? this is a tell tale sign that your carbs are a bit out of balance
cc123
Geez a joab?
PostPosted: 14:48 - 25 Sep 2005    Post subject: Reply with quote
Thought your K4 was fuel injected??? Confused
Old bikes >>> https://www.bikepics.com/members/cc123/
Slinn84
PostPosted: 16:15 - 25 Sep 2005    Post subject: Reply with quote
aaah yeah, well noticed,
you can still give a good squirt of carb clean into the air intake tho, might help stable your idle a bit
UrbanRacer
PostPosted: 16:42 - 25 Sep 2005    Post subject: Reply with quote
it is fuel injected, i've checked and cleaned the plugs but the shuddering at low rpms still remains Neutral
i'll phone the garage on tuesday
LUXY DJ
PostPosted: 23:02 - 25 Sep 2005    Post subject: Reply with quote
chain loose @ all?
UrbanRacer
PostPosted: 23:21 - 25 Sep 2005    Post subject: Reply with quote
nah, its not a drivetrain problem. i'm becoming more and more convinced its a fueling problem.
fazed
Korn is my hero!
PostPosted: 03:47 - 26 Sep 2005    Post subject: Reply with quote
Take it back to the dealership I am sure they fiddle with the mixture at some stage normally after it's run in ?
gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack.
KevTM
PostPosted: 18:53 - 26 Sep 2005    Post subject: Reply with quote
i had this problem with my Bandit when i first got it, used to stall at junctions in warm weather and always idles rough and still does but it doesn't stall any more... needs the carbs balancing.
My gsxr idles a bit rough, too.. i gave it a wee service not too long ago so it's not plugs, air filter, etc.. again i think it's just the throttle bodies that need balanced.
Btw, i done the TRE mod (DIY style) and it runs much better and is easier to ride in town but still it's no replacement for balancing the throttle bodies.
I'm sure that's all it'll be but i don't know why it would just have started after a service unless they thought they'd try balancing them and messed it up, although it's unlikely.
UrbanRacer
PostPosted: 12:21 - 27 Sep 2005    Post subject: Reply with quote
The garage is fucking useless, instead of maybe suggesting a few things to try they want me to bring it in next fucking tuesday Confused
and no doubt they'll charge me for the pleasure. fucking wanks Evil or Very Mad Evil or Very Mad Evil or Very Mad
the grim reaper
PostPosted: 13:24 - 27 Sep 2005    Post subject: Reply with quote
Fuel injected bikes still need equal vacuum levels and still use butterfly valves to achieve this, hence they still need balancing.
Grim
The last post was made 20 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.05 - MySQL Queries: 16 - Page Size: 87.75 Kb
