| jamesn |
 jamesn Two Stroke Sniffer
 Posted: 19:34 - 23 Feb 2003 Post subject: Nsr gear oil problem (or lack of it!) |
Just got my nsr serviced yesterday,went out this morning,checked gearbox oil(had to lean the bike over 45 deg before it would show min)the oil level was fine before the service,so i topped it up to max,went out again this evening and when i got home the same again(back down to min) can anyone please help me!  |
| Ste |
 Ste Not Work Safe
| Robby |
 Robby Dirty Old Man
| jamesn |
| Ste |
 Ste Not Work Safe
| jamesn |
| Ste |
 Ste Not Work Safe
| Kickstart |
 Kickstart The Oracle
 Posted: 20:18 - 23 Feb 2003 Post subject: |
The oil filler is on the clutch casing, so when you fill it up it will show in the window quickly, and then drop as it finds its way into the gearbox (not talking ages, just a minute or so). So top the oil up as it should be , let it stand for a while and then check it. It should be checked with the bike upright. Make sure you are using the right gear oil (not 2 stroke oil, sorry if that was obvious to you).
If there is not oil leak on the outside then the only place for the oil to go is in through one of the main bearing seals, and the bike would smoke like crazy if it was using that much oil through there
The last post was made 22 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
