Front end knocking and Oil question
cc123
Geez a joab?
PostPosted: 19:15 - 03 Oct 2005    Post subject: Front end knocking and Oil question Reply with quote
Well I stripped my bike down today as I have new fairings coming and an exhaust to weld and polish but I'm concerned about 2 things.
1. There is a knocking noise coming from the front end when I pull the brake on, sounds like the pads are loose or something is loose in the front forks, dunno what tho. Rides and stops as normal.....any suggestions?
2. Looking at the oil level, its fine but in the looking glass its looking..um...milky. I've attached a picture but dunno if its too clear. Bike was serviced about 2/3 weeks ago with new oil. What causes this? Bike running lean or water mixing with the oil? Only noticed it since my crash...
Ta
Old bikes >>> https://www.bikepics.com/members/cc123/
riichy
PostPosted: 19:21 - 03 Oct 2005    Post subject: Reply with quote
the oil do you do lots of short trips. if so the guy at the garage told me its water vapor on the inside of the metal oil casing that dont have time to tern in to steam so gets m,ixed in with the oli.......might not be though Thumbs Up
.......... PLOD ............ zx636 2004
Mr.Everready
PostPosted: 20:29 - 03 Oct 2005    Post subject: Reply with quote
Hopefully riichy is right and its only because the bike hasn't been used for a few days that it looks milky inside. A long blast to heat everything up should hopefully clear it. If not it could be the head gasket that needs replacing.
Robby
Dirty Old Man
PostPosted: 20:47 - 03 Oct 2005    Post subject: Reply with quote
To expand a little on what these guys have said.
The emulsion on the oil is due to water mixing in with the oil. This may be from condensation inside the engine, a blown head gasket, a leaking water pump seal, or a leaking seal or gasket somewhere that separates oil and water.
The knocking could be a few things. If your steering head bearings are very loose they can knock, this will also make the bike feel floppy in the steering. It could also be loose steering yoke bolts, or even floating disks knocking.
My SV650 knocks from the front over bumps sometimes. The head bearings and yoke bolts are all tight enough, so I ignore it. Its easier.
instigator
PostPosted: 21:53 - 03 Oct 2005    Post subject: Reply with quote
It's mostly likely your brakes knocking, lots of bikes do it, my hornets did until it went away (for a reason unknown to me!)
Give it time and see how the brakes go - if they still knock after a while, I'd look to take the pads out and clean the whole lot. (I say whole lot because I have no idea what you call the individual parts Wink)
cc123
Geez a joab?
PostPosted: 22:06 - 03 Oct 2005    Post subject: Reply with quote
Well the bike has spent a good 7/8mins or so on its side between being crashed and transported back to mines last week. Its not turned a wheel in 7 days now....
Is it possible for water to spill from somewhere when the bike has fallen over getting into the water supply?
Never noticed this knocking noise to be as bad, bike ain't road worthy just now so a quick spin down my street was all I could muster (with the end can off Shocked so loud!!). Steers straight, rides straight just a loud knock/clunk as I pull the front brake on and off? Doesn't do it if the bike is rolling back, only when its going forwards.
The last post was made 21 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.72 - MySQL Queries: 16 - Page Size: 50.97 Kb
