Crash damage - Cause and effect
White Noise
Mr Dudwee
PostPosted: 19:52 - 08 Oct 2005    Post subject: Crash damage - Cause and effect Reply with quote
Well this weekend i have finally got the time to try and sort out my bike after my off. replacing bits and bobs and the like. the crash bung got a little bent, see the "Cause" picture and has split the engine mounting bolt which is hollow (effect pic). its only split the bolt where there is a large hex section at the end, as far as i can tell the bolt is actually sound for the important bit. but my question is this i am guessing that the hex part is for when you want to remove the bolt to get the engine out. just wondering how difficult it would be to change this bolt for a new one so that if the engine ever did have to come out it would make it easy rather than having to deal with this if that time comes!
WN
PostPosted: 21:49 - 08 Oct 2005    Post subject: Reply with quote
Ouch.
The "bolt" is threaded into the frame. Basically it allows you to adjust the gap between the frome where it mates with the engine. The bit around the bolt is a lock nut for once the clearance is set.
Nasty bit is that I doubt you have anything like enough clearance to remove it without dropping the engine out.
Think R&G sell spares for their crash bungs at fairly sensible prices.
White Noise
Mr Dudwee
PostPosted: 22:09 - 08 Oct 2005    Post subject: Reply with quote
Kickstart wrote:
Ouch.
my first feelings were crap! Laughing
crap again springs to mind! Laughing
They sent me a free bung for my testimonial which is all good
is your opinion still the same after seeing these pics? can't tell if the lug T1 has some sort of lip on the inside to stop it coming out, if it doesn't it could come out, but the manual says to insert them from the inside! Doh!
WN
White Noise
Mr Dudwee
PostPosted: 23:58 - 08 Oct 2005    Post subject: Reply with quote
yep, took a touch out and seen that the bolt does have a lug at the end! doh
so the only way to get it out is through the inside of the frame and there is no way of doing that without dropping the engine out! doh
looks like the bolt stays Confused
WN
PostPosted: 11:35 - 09 Oct 2005    Post subject: Reply with quote
Suspect it is the same as Cols ZX6R, so there is quite a lip around it. You might be able to cut it away to get the old one out but that is not help when replacing it with a new one.
Suspect that you need the long bolt as well as the bung. Doubt it will work as well folded back against the fairing Wink .
White Noise
Mr Dudwee
PostPosted: 12:10 - 09 Oct 2005    Post subject: Reply with quote
yep lip is there! Doh!
R&G provided the bolt FOC aswell! Thumbs Up
WN
The last post was made 20 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 16 - Page Size: 55.09 Kb
