is car oil alright?
LUXY DJ
PostPosted: 17:20 - 21 Oct 2005    Post subject: is car oil alright? Reply with quote
only a quickie
i need 2 fill up my bike with oil but iv heard its alright to use car oil
& m8s got casrtol gtx & im about to fill gsxr600 up but b4 i do is it ok to use this?
also its in my manual saying SAE 10w-40 isrecommended & its also on the casrtol GTX bottle to so its ok (i assume) but is it good?
& whats the 10W-40 mean?
GSXR750
Ninja
Caption Abuser
PostPosted: 17:24 - 21 Oct 2005    Post subject: Reply with quote
NO it's not alright - there's MOTORCYCLE oil and there's CAR oil for a reason ...
James
4 wheels transport the Body ... 2 wheels transport the SOUL
LUXY DJ
PostPosted: 17:27 - 21 Oct 2005    Post subject: Reply with quote
hmmm ok so why not? & whats best/decent oil TOO buy then?
GSXR750
Guest
PostPosted: 17:28 - 21 Oct 2005    Post subject: Reply with quote
Utter garbage Rolling Eyes
However, if you're just topping up the oil level it's best to use the same as what's already in there if you can find out.
LUXY DJ
PostPosted: 17:35 - 21 Oct 2005    Post subject: Reply with quote
oh no! why cant everyone say if its fine or not Laughing 1st two replies are yes & no Rolling Eyes
well oil in there @ the moment is BLACK & bloke i know @ shop filled it up(as it was nearly empty) & once around the block & it was BLACK again already & since then has gone down quite abit aswell but i want to drain it out & fill up again & so on till its clearer/oil colour
GSXR750
veeeffarr
PostPosted: 17:41 - 21 Oct 2005    Post subject: Reply with quote
If it's Magnatec or anything similarly magnetic then it's NOT ok to put in your bike, it will cause the clutch to slip.
If not, then it should be ok.
10W40 refers to the viscosity (thickness) of the oil at cold, and at running temperature. in cold (I think) it's 10, when it's warm, it's 40.
LUXY DJ
PostPosted: 17:47 - 21 Oct 2005    Post subject: Reply with quote
yeah iv heard about that aswell & no it isnt magnatec its just STD castrol GTX
also i was told that fully syth makes the clutch slip aswell
so use semi(this was a bloke who's been setting up race bikes for 30+ years& reversed my gearing,etc)
but coming from 2-stroke to 4-stroke it was always fully syth in my 2t so is it not as such a big thing on a 4-stroke then?
cheers peeps so far Wink
GSXR750
Guest
PostPosted: 19:46 - 21 Oct 2005    Post subject: Reply with quote
Some Suzukis suffer chronic clutch slip if run on fully synth, but are perfectly happy on semi synth. Mine runs on 'car' oil and has done for the last 45000 miles and is still on the original clutch plates.
Pop along to www.socweb.co.uk and ask - plenty of Gixxer 6 users there. Thumbs Up
Robby
Dirty Old Man
PostPosted: 19:53 - 21 Oct 2005    Post subject: Reply with quote
In a gsxr600 I'd use a semi synthetic bike oil.
You must learn to spell.
LUXY DJ
PostPosted: 21:31 - 21 Oct 2005    Post subject: Reply with quote
well iv put that castrol gtx oil in & its so far ok
but what does everyone recommend/use like whats the best?
GSXR750
kenny
PostPosted: 22:41 - 21 Oct 2005    Post subject: Reply with quote
Cant You just empty the lot and put the oil the maual says in it it would be much easier and keep ya mind at rest to
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
LUXY DJ
PostPosted: 01:17 - 22 Oct 2005    Post subject: Reply with quote
manual just says 10w-40 which is same on casrtol gtx car oil but its fine so far but ill drain it if anything feels/goes wrong
but so what can ppl recommend as a good gsxr600 oil? Rolling Eyes
GSXR750
freestyler_onli
PostPosted: 11:29 - 22 Oct 2005    Post subject: Reply with quote
Can someone explain to me if/how the oil you put in affects the Fuel Injection?????
PostPosted: 13:34 - 22 Oct 2005    Post subject: Reply with quote
It doesn't really.
I have used car oil in bikes loads of times with no problems, including fully synthetic car oils. There are occasional brands that do cause problems (Magnetec seems regularly mentioned, few people seem to have had issues with Texaco oil as well), but 99% should be fine.
Bikes often have very basic oil requirements (eg, Triumph only specify 15W50 SH oil for the TT600).
freestyler_onli
PostPosted: 13:36 - 22 Oct 2005    Post subject: Reply with quote
I asked because when i ran low on oil the 'FI' error message showed- meaning Fuel Injection..... Confused
Hmmm.
Maybe a dodgy wire.
PostPosted: 14:28 - 22 Oct 2005    Post subject: Reply with quote
Probably there is a feed to the ECU to turn the light on an get you to stop immediatly.
Oil too low will rapidly result in a wrecked engine.
Fortuna
PostPosted: 14:38 - 22 Oct 2005    Post subject: Reply with quote
Doesn't it affect clutch slip on bikes like the R1? They add something to car oil IIRC.
Don't bike engines get much hotter too?
PostPosted: 17:40 - 22 Oct 2005    Post subject: Reply with quote
They add some stuff to some oils that can provoke clutch slip. 1200 Bandit has had car oil in it most of its life. GPZ500 gets it. FZR600 gets it.
Temp wise they are all about the same really.
Beef
PostPosted: 19:15 - 25 Oct 2005    Post subject: Reply with quote
actualy most modern car oils use friction reducers, which if you tried to run in a bike with a wet clutch( sits in engine oil) you would find it almost impossible to set off without bouncin it off the rev limiter
PostPosted: 19:41 - 25 Oct 2005    Post subject: Reply with quote
Some do, so don't. Try it. You will probably find no problems with the clutch. I don't have a problem using BP semi synthetic or fully synthetic car oil. Only one that has slipped was the Bandit when the engine was tuned, but then that also slipped with brand new clutch plates and bike oil in it.
luderacer
PostPosted: 19:52 - 25 Oct 2005    Post subject: Reply with quote
i would never run car oil in a motor cycle, only run what your owner manual says, or what your dealer suggets
PostPosted: 23:34 - 25 Oct 2005    Post subject: Reply with quote
Which would be (using the CBR600 manual I have here) SAE 10W40 , API rated SE, SF or SG. Pretty much the same for the Suzuki 1200 Bandit manual and for the ZZR600 manuals I have floating round. No mention of motorcycle specific oil. Only one that does is the Triumph TT600 manual.
Nath
PostPosted: 00:09 - 26 Oct 2005    Post subject: Reply with quote
luderacer wrote:
or what your dealer suggets.
Which would probably be whatever they're selling with the biggest profit margin Rolling Eyes
Hard livin', hard luck.
pipnet11
PostPosted: 22:41 - 26 Oct 2005    Post subject: Reply with quote
First time Iv even heard of it causing a problem. I could imagine something like magnatec causeing slipping clutches though. Just put any bog standard 10W40 in and itll be fine.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
iceCrash28
PostPosted: 04:40 - 01 Nov 2005    Post subject: oil............. Reply with quote
Laughing https://www.xs11.com/stories/mcnoil94.htm Laughing
............................nice stuff......................
i hope this would help..... Rolling Eyes Thumbs Up
The last post was made 20 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.62 - MySQL Queries: 16 - Page Size: 134.74 Kb
