Author |
mr.z |
mr.z World Chat Champion
Posted: 03:19 - 22 Oct 2005 Post subject: Tank clearing/reconing... |
Don't know where to start really, the tanks pretty manky inside, the odd big spot of rust, but looks like its surface rust, trouble is can't get to it...
I've heared of filling it up with bolts+petrol and shakeing it for an hour, but i'd still not be 100% happy with that...
Apparently you can seal it with something, so that any loose shat in there can't move anywhere, i'll be putting a filter on anyways but i'd be happyer if it wasn't movein...
Another thing, whats a good way of shifting the paint? i'd get it sand blasted if i could afford it but its not happening, would paint stripper do the trick? considering all the protective layers on the paint and all... or is it wire brush time?
Wouldn't mind haveing the tank as bare metal, otherwise might have a go at painting the tank myself (propperly with brushes)
Tanks for reading ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
Back to top |
Aikman666 |
Aikman666 World Chat Champion
Posted: 12:57 - 22 Oct 2005 Post subject: |
I'd take your petrol cock off, fill it up with water, putting a finger in the hold where the cock was, shake it about, then run the water through. Once youve got all the shite out of the inside, wire brush the rust and repeat the water bit. Once you've got all the surface rust off, put some meths into your tank to evaporate all the leftover water. After this i would spray a protective coating on the surface where the rust was. Maybe Hammerite (or maybe a clear laquer?). Leave it to dry, leave it in the sun (ha! sun) for a few days, then you should be good!
Please note: This post may be a load of piss, so i would get one of the older folk (who know what their doing) to confirm before you do anything! ____________________ Will work for petrol
My Design Blog |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
ZRX61 |
ZRX61 Victor Meldrew
Back to top |
MalcolmT |
MalcolmT Nova Slayer
Back to top |
stinkwheel |
Posted: 22:46 - 23 Oct 2005 Post subject: |
Yep. Petseal works ok. It will stink the house out though.
Ideally, if you are going to use petseal, you want a little surface rust left for it bind to (says so in the instructions). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
The last post was made 18 years, 191 days ago. Instead of replying here, would creating a new thread be more useful? |
