Spark plug Gap
shammon
PostPosted: 23:02 - 22 Oct 2005    Post subject: Spark plug Gap Reply with quote
Can any one shed some light on the issue of setting the correct spark plug contact gap? Mine is to be 0.8mm is it realy important? If so whats the benifits? Rolling Eyes
PostPosted: 22:52 - 23 Oct 2005    Post subject: Reply with quote
Bigger gap=higher resistance. Higher resistance means larger voltage to push the spark across the gap. This means a bigger spark.
Smaller gap = lower resistance. Lower resistance means a smaller voltage required to push the spark across. This means a smaller spark.
Too big a gap = not enough voltage to throw the spark properly. This would mean it sparking intermittantly or throwing the spark to the edge of the plug rather than across the gap to the tang. Both of which are not good.
Too small a gap = too small a spark which may not be hot enough to burn the fuel properly, the gapo could also become blocked with carbon and stop working altogether.
Too big a gap was also a good way to fry the contacts off your points back when bikes had such things.
The last post was made 20 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 16 - Page Size: 33.04 Kb
