Author |
veeeffarr |
veeeffarr Super Spammer
Back to top |
mchaggis |
mchaggis World Chat Champion
Posted: 01:00 - 07 Oct 2005 Post subject: |
That blasted plate thing with holes in? All I could see that it did was get in the way of adjusting the carburettor. I guess it's because of the accelerator pump and all that business.
Um. Sorry I'm not much help. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush. |
Back to top |
veeeffarr |
Posted: 01:04 - 07 Oct 2005 Post subject: |
Yeah that's the one, screws mustve fallen out of it...
And I thought that metallic vibration was my keyfob |
Back to top |
veeeffarr |
Back to top |
Gazdaman |
Gazdaman I did a trackday!!!
Back to top |
veeeffarr |
Posted: 13:39 - 07 Oct 2005 Post subject: |
I've checked all the bolts, nothing else is loose...
No it's still working, just think it was some sort of guard...Still want to replace it tho! |
Back to top |
Gazdaman |
Back to top |
veeeffarr |
Posted: 13:23 - 08 Oct 2005 Post subject: |
I've noticed something else as well! On the right hand side of the engine, just below the screw you take off to get to the side panel (With the battery/airbox underneath) there is a loose bolt with no nut on top! Shit! What's that for? |
Back to top |
pipnet11 |
pipnet11 Brolly Dolly
Back to top |
veeeffarr |
Back to top |
veeeffarr |
Posted: 01:34 - 22 Oct 2005 Post subject: |
This bike is fucking shit, lost the 2 bolts that attach the exhaust to the swingarm now..
So, total things lost now:
Carb guard
Screw on engine mount
2 screws on exhaust pipe
Things come loose:
Cable that goes into the back of the clocks
Chain adjust locking nuts
Wingmirror nut
What the fuck? Is this a shit bike or am I doing something really really wrong? It's horrific...
Anything more goes wrong and I'm selling and not buying another bike. |
Back to top |
mchaggis |
Posted: 02:14 - 22 Oct 2005 Post subject: |
That all sounds pretty much par for the course. Tightening them all up properly and keeping an eye on them is pretty much essential. They're all just odds and sods and mostly not dangerous. It's a CG125, it's a little vibey single, put together at minimal cost, but something which can cope with minimal maintenance. Just keep on tightening nuts and looking after it, and you'll be able to move on up once you've done your test. Don't give up on it. ____________________ I must not be a troll...
Mmmm, Guinness
Back to top |
veeeffarr |
Back to top |
veeeffarr |
Back to top |
darkinthepark |
darkinthepark Two Stroke Sniffer
Posted: 18:30 - 22 Oct 2005 Post subject: |
Nought major mate it's just the carb gaurd. My CG has done the same thing before. I just had my bike out of the garage and it's still busted |
Back to top |
mchaggis |
Posted: 23:19 - 22 Oct 2005 Post subject: |
Chain and sprockets aren't difficult to do really. The chain guard can be a bit fiddly, but as it's a split link jobby, it's fairly simple to get the chain off. A socket set, spanners and a screwdriver or two should be enough. Remember to adjust the rear brake to take into account the 'shorter' chain, and loosening the rear wheel and putting it fully forward will make life easier.
Beware of things which go ping - the split link.
The problems selecting first are fairly common. An ill-adjusted drive chain, low or knackered engine oil, an ill-adjusted clutch or in the worst case a bent selector fork/ shaft can all cause it. A more decisive firm boot will help too. I'd check the clutch adjustment first. If drive isn't properly disengaged, it can be difficult to get first in.
Today I discovered that my front axle nut and the swingarm pivot were both loose, as well as having lost one of the bolts for the bottom triple clamp (holding the forks on). Tightening them up improved the handling of the machine markedly. I removed the spotlights and their mounting bracket and the vibey buzzing went away, but then an annoying resonance appeared at 10k rpm. ____________________ I must not be a troll...
Mmmm, Guinness
Back to top |
Marci |
Marci Brolly Dolly
Posted: 12:11 - 25 Oct 2005 Post subject: |
Gear selection / neutral selection probs - check clutch cable freeplay against haynes manual. Sorted all similar problems out on my bike... ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
Back to top |
The last post was made 18 years, 190 days ago. Instead of replying here, would creating a new thread be more useful? |
