| Marius |
 Marius Guest
 Posted: 18:19 - 28 Dec 2001 Post subject: Need help with my norwegian Bike! |
My bike aint restricked like yours.. i have tried to follow the guide.. I cant find det intake plate.. it is`nt there.. So i wonder how my bike i restrickted..! i no the exhaust is restrickted , but i have a un-restricked one.. What do i do next.. i want Full power!!  So if anyone no how? Please help me! - Marius J |
| Seragg |
 Seragg Guest
| C Samsgard |
 C Samsgard Guest
| Marius |
 Marius Guest
 Posted: 03:52 - 31 Dec 2001 Post subject: questions |
Hello.. What do you mean by " pluggen"? Is it the same at det intake plate? havent removed nothing from the bike.. i just have a new exhaust.. and i just goes in 130-140 km\t.. i didnt understand nothing the site you gave me.. dosent no Ger..  Is the plugs easy to find.. can you exsplane where they are and how the look like..? So i dosent have to get alot of stuff like cdi boks and so on to get full power? Do you now what i can do to the carb? Txn.. Regards Marius |
| Benny(norway) |
 Benny(norway) Guest
| benny(norway) |
 benny(norway) Guest
| Haakon of Norway |
 Haakon of Norway Guest
| zaijin |
 zaijin Guest
 Posted: 22:31 - 07 Jan 2002 Post subject: norwegian nsr `s |
hey hey hey, dere er helt på jordet ! jeg har en honda nsr 99 mod. for å få full effekt må du først skifte til effekt anlegg deretter cdi boks deretter må du dyse om forgasseren, hvis du vil ha ekstra kraft sett på en polini 160ccm cylinder, da gjør den rundt 190  |
| Lasse |
 Lasse Guest
| benny(norway) |
 benny(norway) Guest
| C Samsgard |
 C Samsgard Guest
| jensa |
 jensa Guest
| benny(norway) |
 benny(norway) Guest
| jensa |
 jensa Guest
| benny(norway) |
 benny(norway) Guest
 Posted: 03:58 - 17 Jan 2002 Post subject: . |
Hvem del festa hvor? hvis du tenker på den boksen som skal sitte på sylinderen kan det være fordi du har feil boks. den norske sylinderen er jo litt forskjellig fra den britiske så du trenger kanskje en annen sånn feste boks antagelig vis du har bytta sylinder. (nevt ovenfor i den lista) tenker du på åssen du skal montere den som summer og drar i kablene så er det ett gått bilde hvis du går inn på www.nsr125.com <A HREF="https://www.nsr125.com/derestrict.htm">https://www.nsr125.com/derestrict.htm</A> og ser på bildet det står tray removal. vis ikke så har de jo lagt ut alt av deleplasseringer vis du går inn på <A HREF="https://www.nsr125.com/tech.htm">https://www.nsr125.com/tech.htm</A> effektanlegg: du vil få litt mere effekt men du taper litt bunndrag og. jeg ville heller tatt og borra ut plomba eller kjøpe ett "reint" orginalt anlegg. men du burde jo kvitte deg med resten av plombene og. dvs. bytte cdi, controleksosventil, sylinder og eksosventilene og litt andre diverse smådeler så du får den orginal. og dyse om til 135/42/65 (tror jeg det var). så får du den helt orginal fullefekt (toppfart oppmot 180km/h). mindre sjans for at det skal skjære seg eller att det skal skje ett eller annet kødd. det er jo litt dyrere men jeg vil jo tro du vil få mere igjen får den når du selger den. uorginale trimma sykler er jo ikke kjent for og holde så lenge. |
The last post was made 24 years, 181 days ago. Instead of replying here, would creating a new thread be more useful? |
