Stiff clutch handle
shammon
PostPosted: 21:06 - 10 Nov 2005    Post subject: Stiff clutch handle Reply with quote
Stripped the clutch down today as the clutch lever was so stiff. And once all re assembled and back together still the same? The bikes being rebuilt but do i have to run the engine and ride it for it to ease of? the handle, cable inc outer cable cover are all ok as it the clutch arm selector and return spring. There is plenty oil in there also. Onlt stripped it back half way so did not check the rest of the friction plates. Question
https://i7.photobucket.com/albums/y277/shammon/mini-STCL.jpg
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
Guest
PostPosted: 21:12 - 10 Nov 2005    Post subject: Reply with quote
Looks like a conventional UJM clutch from here. You've had the operating arm off the sprocket cover and cleaned/greased it and it's nice and free?
That 'mushroom' in the middle of the clutch basket - I'm guessing that the operting arm works a pushrod through the middle of the gearshaft to push the mushroom out and release the pressure plate - have you tried pushing the pushrod back and forth? It's probably stuck in the seal or gummed into the gearshaft. without the pressure plate on there should be no resistance at all.
shammon
PostPosted: 21:27 - 10 Nov 2005    Post subject: Reply with quote
All is well greased etc. i removed the oil cap and with the help of a torch was able to see the plate move in and out ok when it was all reassembled. The mushroom part is ok moving freely, i think it has to be the pressure springs they seem to be too hard to compress? can they deteriorate and become stiffer?
doggone
PostPosted: 21:39 - 10 Nov 2005    Post subject: Reply with quote
They can't become stiffer - most likely someone's deliberately fitted stronger springs for some reason.
It may be better when ridden about a bit.
Guest
PostPosted: 22:40 - 10 Nov 2005    Post subject: Reply with quote
Does seem odd. The plates shouldn't make a difference, when you operate the lever all you're doing is pushing (or pulling) the pressure plate against the springs.
Looking at the pic again, it seems the operating arm is on the clutch cover, not the sprocket cover? if so it pulls the shaft round that's got the worm gear on that pulls the pressure plate outwards.
If the shaft isn't positioned right it could give problems meshing with the other worm gear.
Ichy
PostPosted: 00:30 - 11 Nov 2005    Post subject: Reply with quote
For what its worth, I had a XJ750 for a few years and the clutch was pretty heavy on that. Stripped it all down and cleaned it but it made very little difference. All I could do was just make sure the cable was well oiled.
map
Mr Calendar
PostPosted: 09:06 - 11 Nov 2005    Post subject: Reply with quote
marki wrote:
...was just make sure the cable was well oiled.
Thumbs Up was going to type something similar. A friend of mine had a horrible clutch lever. I mean really painful and hard to use. Got a cable oiler to slip on, applied the oil and the difference was remarkable.
the grim reaper
PostPosted: 12:25 - 11 Nov 2005    Post subject: Reply with quote
Be careful though, if someone has fitted a teflon lined cable, some oils cause the liner to swell and the cable gets worse instead of better.
Grim
PostPosted: 12:53 - 11 Nov 2005    Post subject: Reply with quote
I would be tempted to just replace the cable. They are cheap (and you can still keep the old one as an emergency spare). Cables are often nylon lined and oil causes the nylon to expand, making the cable stick.
However if it has been like this since you bought it then I would suspect someone has fitted aftermarket heavy duty clutch springs. As such it is probably worth replacing them with stock springs (which should be fine on a standard engine).
the grim reaper
PostPosted: 15:31 - 11 Nov 2005    Post subject: Reply with quote
Nylon, that's the word I was looking for, WTF I got teflon from is beyond me Rolling Eyes
Grim
Guest
PostPosted: 17:56 - 11 Nov 2005    Post subject: Reply with quote
Grim
Yeh, the world went downhill when women started wearing tights instead of teflons Laughing
ZRX61
Victor Meldrew
PostPosted: 18:26 - 11 Nov 2005    Post subject: Re: Stiff clutch handle Reply with quote
So what was the point of stripping it down if ya stopped halfway thru the job??????? Those extra 10 seconds ya saved by not to removing the rest of the plates must have been really valuable... Rolling Eyes
shammon
PostPosted: 22:29 - 11 Nov 2005    Post subject: Reply with quote
Relised i had to go to work Embarassed Half covered in oil and bits every where relised i started in 40mins.hence only half stripped it down. Thanks for the replys.
bidman
PostPosted: 22:14 - 12 Nov 2005    Post subject: Reply with quote
Have you tried just sliding the inner clutch cable in and out to see how free it moves if its even remotely stiff i think this will be your problem, if so get a new 1 greasing it never seems to work properly and they arent too expensive i think around 10-15quid, if not check your clutch springs to see if they are stock, if not replace them Thumbs Up , Dan
Don't ride it, RAG IT!!
The last post was made 21 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.75 - MySQL Queries: 16 - Page Size: 84.62 Kb
