| brown_d9 |
 brown_d9 Borekit Bruiser
 Posted: 12:02 - 15 Nov 2005 Post subject: |
They would indicate around 80 anyway when restricted (the speedo was one of the less accurate ones when they were new). Unlike most sports 2 strokes they will not rev out well, mainly due to the way Honda restricted them by leaving the ATAC chamber open in the low revs position.
I would expect an indicated 95mph+ from an NS, with a real 85~90 top speed if properly derestricted.
| brown_d9 |
| Hex |
 Hex Party Boy
 Posted: 15:43 - 17 Nov 2005 Post subject: |
It would allow to much fuel in and basically flood the engine, thus making it run slower/bog down.
Bigger is not always better, ideally you want the correct one for the engines needs. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
 Posted: 17:25 - 17 Nov 2005 Post subject: |
As above. Bigger is safer (you are unlikely to suffer sudden terminal engine failure from using a main jet a bit too big, quite probably from using one slightly too small), but not better.
You need the right size for best results. Just like increasing the mains up to 300V would not give you a better TV picture.
The NS airbox was meant to be quite restrictive. Drilling holes in it (make sure you drill them in the right place) or replacing it with a K&N were both quite good for performance, just make sure you rejet to get it right.
Also, check your sprockets. Sound to me as though someone has lowered the gearing.
| clemsta |
 clemsta Scooby Slapper
| brown_d9 |
There is a gap of 2 years, 218 days between these two posts... |
| andi_woodley |
 andi_woodley L Plate Warrior
| plugger147 |
 plugger147 World Chat Champion
| alains |
 alains World Chat Champion
The last post was made 18 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
