Author |
puremagic72 |
puremagic72 Brolly Dolly
Posted: 21:21 - 12 Dec 2005 Post subject: TOP SPEED 50MPH ON NS125R-K?? |
WELL, JUST WENT OUT ON MY NS125R-K AND COULD ONLY GET 50mph OUT OF IT, ALAIN HAS MENTIONED OF UPJETTING, BUT LACK OF EXPERIENCE AND FUNDS AT THE MO, UNABLE TO DO THIS.
Just so dissapointed could only get this out of her, any cheap suggestions, as cant get new jets yet, or will have to play the waiting game???? Think maybe one of the jets are blocked.
Thanks,
Baz. |
Back to top |
Kickstart |
Kickstart The Oracle
Posted: 22:09 - 12 Dec 2005 Post subject: |
Stock they should do just over 70 true (and indicate rather more, the speedo was in cloud cuckoo land).
You rejet the carb to compensate for changes to the engine / carb / exhaust / air filter / etc, not to get more performance.
First thing I would do is to check the service items and to do a compression check. My guess would be that either the exhaust is seriously clogged up, or the air filter clogged up or possibly that it has had a light seize in the past (which would result in massively low compression).
It could be the main jet being siezed. If you look at the bottom of the carb you will see a large "bolt" (14mm spanner required). If you take this off you will find the main jet screwed into it (but petrol will pee out if you do this, so turn the petrol off first).
Back to top |
Hex |
Hex Party Boy
Posted: 23:00 - 12 Dec 2005 Post subject: |
You haven't changed the spark plug recently have you?
Just with the recent cold weather using a colder plug could kill the performance.
Of course the problem is more likely to be along the lines of what Keith said. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
Back to top |
puremagic72 |
Posted: 07:08 - 13 Dec 2005 Post subject: |
yeah changed the spark plug to BR9EIX, but my speedo not working(getting cable today), but my mate rode along side me when i opened her up as much as she could go, and he said it was 48mph!!!
Thanks chaps!!
Baz. |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Hex |
Hex Party Boy
Back to top |
puremagic72 |
Posted: 16:42 - 13 Dec 2005 Post subject: |
no its an italian import, the problem could be down to the piping in between the carb and the engine, its only been taped up, which i have just been told by someone, so there is air escaping and when i open her up theres not enough fuel getting to the engine due to lack of suction.
will post a picture of it soon 2night,
Thanks,
Baz. |
Back to top |
alains |
alains World Chat Champion
Back to top |
puremagic72 |
Posted: 19:06 - 13 Dec 2005 Post subject: picture of taped up part. |
well here is the picture of the taped up bit, its between the carb and engine,carb being on the right, should be solid, is this why there is nore top end speed, and when i go up a hill, losing compression, and air leaking. Very poor from the previous owner i think.
Anyone know what this part is called??
Regards,
Baz. |
Back to top |
lilredmachine |
lilredmachine World Chat Champion
Back to top |
puremagic72 |
Posted: 19:51 - 13 Dec 2005 Post subject: |
forgive me, but wats wtf??
Baz. |
Back to top |
puremagic72 |
Back to top |
puremagic72 |
Posted: 19:52 - 13 Dec 2005 Post subject: |
do you know wat this part is called??
Baz. |
Back to top |
Aikman666 |
Aikman666 World Chat Champion
Posted: 19:53 - 13 Dec 2005 Post subject: |
Its either because your not getting a steady air flow OR you've blown your rings on it due to running it dry OR its sucked in some nasty air through a hole and it has clogged up the intake/carb needle/completely wrecked your barrell and piston! Only option is really to open it up and have a look.
WHY WOULD YOU RUN IT WITHOUT OIL!? Its there for a reason! ____________________ Will work for petrol
My Design Blog |
Back to top |
puremagic72 |
Posted: 19:55 - 13 Dec 2005 Post subject: |
the oil is topped up, i make sure of that.
Baz. |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Hex |
Hex Party Boy
Posted: 20:23 - 13 Dec 2005 Post subject: |
Looks like the jubilie clip round the middle of its slipped and been tightend and as such really messed it up.
I'm not gona bother finding out what plug is in my old one now, you've found the cause of your problems. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Back to top |
Kickstart |
Back to top |
The last post was made 18 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
