carb icing
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2
Lone-Wolf
PostPosted: 19:31 - 28 Dec 2005    Post subject: Reply with quote
Wotcha.
Never had a problem with the carb on either of the bikes.
The VW trike however is a different matter. The carb is mounted on a massive long manifold, and also has accelerator pumps fitted. Ride it on a cold, foggy day and you literally get a snowball on the outside of the carb. The way I got around it was to 'box' the engine in - then make a warm air intake to the air filter. There is an aftermarket 12 volt "electric blanket" that wraps around the carb and the manifold. These electric carb heaters could be modified to fit on a bike Wink
The Ford trike has a water jacket around the inlet manifold - ain't noticed the carb ice up yet.
Cheers.
L.W. - www.moonshiners.org.uk
Zimbo
PostPosted: 19:32 - 28 Dec 2005    Post subject: Reply with quote
To stop it happening, use an additive. Silkolene Pro FST is favourite, but not always easy to get hold of. Wynns Dry Fuel works well too and is more widely available, including Halfords.
Simply add some to the fuel tank each time you fill up, and no more problems.
PostPosted: 19:41 - 28 Dec 2005    Post subject: Reply with quote
jonnay wrote:
Is this possible on 2t's? My NSR dies when its cold (even when the engine temperature is up), and I don't know what it is. It's still rideable, and only happens after I've been going fast - if I'm pottering about it's fine Thinking
Entirely possible but it is not as common as some might think. I would be tempted to adjust the mixture slightly and richen it up first which might sort it out.
Years ago I did have carb icing once on my old MBX125. Had just done 25 miles down dual carraigeways, but in addition to whatever was on the inside of the carb there was a good layer of frost all over the outside of it.
jonnay
PostPosted: 19:45 - 28 Dec 2005    Post subject: Reply with quote
Cheers keith, thinking of playing around with that anyway, because it is running a bit rich Smile
Thanks.
Jon
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
PostPosted: 20:13 - 28 Dec 2005    Post subject: Reply with quote
Running rich at what kind of throttle openings?
Bezzer
PostPosted: 20:19 - 28 Dec 2005    Post subject: Reply with quote
sickpup wrote:
Carb icing is caused by either the freezing of petrol or water droplets in the main jet or emulsion tube of the carb or carbs. As I understand it normally petrol in the main jet as this is a the smallest part of the carb.
1. As a piston goes down (assume intake stroke for 4 stroke) it creates a vacuum, now as we know from physics at school vacuums are cold.
2. The inrush of air to fill the above vacuum also causes a vacuum over the emulsion tube and a temperature drop.
3. This vacuum pulls fuel through the main jet and up the emulsion tube atomising it as it pulls it up. For the fuel to atomise it takes heat from the carb, the nearest part being the emulsion tube.
Now all this taking of heat caused either by vacuum or atomisation causes the fuel or water to freeze in the jet/emulsion tube.
Happens more on cold days as the inital temperature is lower.
Now if you want a practical demonstration of the above you can recreate it using a 40kg propane bottle and heater with a 8foot long hose outside on a cold day.
Set up the bottle and heater as far from each other as possible with the hose hanging taut between them. Aim the heater away from the bottle and turn it on full blast. After about 45mins to an hour you will see ice crystals forming around the bottom of the bottle and if you leave this running the ice crystals will reach about half way up the bottle before it runs out. The reason this happens is that as gas leaves the bottle to fuel the heater the gas remaining in the bottle expands (remember fuel atomisation is much like expansion) by taking heat from the actual bottle causing it to drop in temperature.
You can of course short cut this by just hitting the valve off the bottle with a sledge hammer but I thought the safe way would be best although if you do it this ay the affect is quite interesting to say the least.
Why does it happen.
Carbs are isolated from the engine on big rubber manifolds so that the intake charge of air is as compressed (assuming NA) as possible. Thats why it happens.
How can you stop it.
Heat the carbs it doesn't happen but on bikes like the GPZ900 the carb heaters took 9BHP, a fair amount.
Toss up between power and rideability in the cold.
Thats a long winded and not a very factually correct explanation, Kickstarts was right
Carb icing is when ice forms in the carb(s) initially affecting the idle circuit, the ice is moisture taken from the incoming air which gets supercooled by the carb venturi effect, the petrol has nothing to do with it other than it can't flow. It can happen anywhere from 5-6C (sometimes more) down to freezing point in damp air (if it's freezing then you have next to no moisture in the air so it's not so bad surprisingly), that's why it's more prevalent in early winter and late winter/early spring. The faster you go the cooler it gets the more ice you get around the idle jet area and eventually it blocks. You slow down come off the mains onto the idle but it's partial/fully blocked so the engine runs either really rough or just dies. You can get away with it just running rough for a bit until the latent heat from the engine melts the ice or if it stalls you have to wait for the ice to melt before it will start again.
Used to have an old GS Suzuki that could take up to half an hour to thaw out on a bad day, then just start and carry on as if nothing had happened.
Warming it up before setting out doesn't really help as if the right weather conditions are there and you haven't got heaters or additives then it will happen anyway, some bikes are more prone to it than others dependant on their layout, think yourself lucky if you haven't got a ramair Kwacker, they're notorious for it.
jonnay
PostPosted: 20:27 - 28 Dec 2005    Post subject: Reply with quote
When I whack it full open it bogs down, but the plug is always black instead of the brown it should be. I remember from my scooter tuning days that if the plug is black there's too much fuel, and if it's white it's too rich. I messed around with the moped carb until I got a chocolate brown plug, and that was running sweet.
I think the same principle would apply for the NSR? They're both 2 strokes, only the NSR is 3 times the capacity of the moped, nearly Smile
PostPosted: 21:08 - 28 Dec 2005    Post subject: Reply with quote
Trouble is that it can be rich at low revs and lean at high revs.
Best not to just whack the throttle fully open on a slide carb anyway as you will not get the right mixture.
jonnay
PostPosted: 21:25 - 28 Dec 2005    Post subject: Reply with quote
Ah right.. thanks again Thumbs Up
sickpup
Old Timer
PostPosted: 22:05 - 28 Dec 2005    Post subject: Reply with quote
Why thank you.
Well you used 'Venturi effect instead of vacuum but the above agrees with me. I suppose we could say the dropping of the piston creates a low pressure area and as the inrushing air stream passes over the emulsion tube to creates a venturi causing a vacuum.
Remember the word supercool.
So the supercooling can only effect water and not atomised petrol?
And heres where we run into a problem with your explanation.
It also happens when bikes are on WOT. In fact if I remember the Kawasaki custom thing that was the first (japanese) bike in the UK to be recalled for carb mods it only happened at WOT.
Incidently this disagrees with Kickstarts explanation
Kickstart wrote:
This results in the carb being so cold that the moisture in the intake air starts to condense and freeze, normally around the attomiser tube.
a hell of a lot more than mine so why am I wrong and he's right?
Please refer to the why does it happen bit on my post.
Should try an old 900SS.
Yes Kawasaki's are bad.
HurtMePlease This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 09:21 - 29 Dec 2005    Post subject: Reply with quote
From my PPL days, on planes at least, carb icing was always attributed, as keith suggested, to moisture in the air. Obviously it's a bit more serious on a plane if your engine dies, so they would often have carb heaters to prevent it.
The r6 does have a hook up to the cooling system to heat the carbs yoko.
I never had a problem with carb icing on my zx6 J model - is yours an import dodsi? I did think I had it once when I first got it, but got a feeling it was actually just it going onto reserve.
Ian (GPX)
PostPosted: 09:50 - 29 Dec 2005    Post subject: Reply with quote
I had this problem last year and the year before, decided to look into it over the summer of this year. Noticed on my bike that the carbs on it had water ways, so i got all the bit's to hook the carbs to my cooling system just before winter (Nov 2005) and since then I have not had a problem with the carbs iceing up.
Oh, bike is a ZX600R Very Happy
sickpup
Old Timer
PostPosted: 15:03 - 29 Dec 2005    Post subject: Reply with quote
Right at the begining of my post in brackets I wrote 'as I understand it'. I'm willing to be wrong on this.
None of the articles I can find explaining carb icing relate to Motorcycles, they all seem to be about planes and I agree they all say due to moisture. Thing is different things happen at altitude.
I also didn't disagree that it could be moisture as to be honest I'm not sure but I did put forward the petrol idea as this is the theory I know about.
Bezzer
PostPosted: 15:27 - 30 Dec 2005    Post subject: Reply with quote
I'm back Mr. Green
Exactly, may be different heights, so even cooler, but it's still moisture in the air that freezes and blocks the jets, not the fuel.
There are loads of different "official articles" as you say relating to aircraft as it's a bit more serious when your engine cuts out a few thousand feet up Rolling Eyes but there are also plenty of car and bike articles, some more official than others, that all confirm the same causes.
Yes, the freezing point of petrol is so much greater than water, if it gets that cold then it would be one big ice block from the water before petrol started to freeze. If the air temperature is freezing but dry you won't get the icing as Dodsi mentions from experience in an earlier post because there is little or no moisture in the air, so you're getting an extremely low intake temperature but the petrol still doesn't
freeze or even wax.
No problem there dude, there's always an exception to the rule, people who have had it will tell you that the majority of times, perhaps even every time they've had it(my problems with various bikes were never a problem at high throttle openings even the cursed Sucksuki Confused ), it's when you come off the throttle that it dies/misfires. It doesn't usually happen at large throttle openings for the same reason that flowing water takes longer and lower temperatures to freeze compared to still water. The petrol is flowing and not giving the moisture time to build up ice and block the flow, the idle circuit is "idle" so thats gets the ice building up, you come back onto the idle and there's little or no petrol getting through so it runs rough/dies. In extreme circumstances, and we are talking about notorious Kawasakis here, the mains could start to ice up even when flowing causing problems.
I agreed that Kickstarts explanation was right because he stated it was all to do with moisture not petrol.
PostPosted: 15:39 - 30 Dec 2005    Post subject: Reply with quote
Mine was also intended to be a very brief decription, short on detail.
However worth noting that petrol does affect it, not by freezing but by how much heat it carries away from the carb body compared to plain air.
Wish I knew where I had seen it, but there is an impressive picture around somewhere through the intake of a carb with a large lump of ice around the area of the attomiser tube.
The last post was made 20 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.11 - MySQL Queries: 13 - Page Size: 108.79 Kb
