Blipping the throttle
jonnay
PostPosted: 17:45 - 03 Jan 2006    Post subject: Blipping the throttle Reply with quote
Hi,
Is there any need to blip the throttle on a 2t bike? I've recently found my back end sliding around when I'm downshifting from speed, and although it's not *too* dangerous (the slides only last a second or so), I'd still like to avoid it incase it happens on a corner, and to preserve my tyre, as well! Laughing
There's not much engine braking on a 2 stroke, and theres just about enough to lock the wheel, so would blipping the throttle help it at all? I don't really know how to do it either, so I'd just like to know whether it makes a noticeable difference before I go about asking mates how to do it.
A worthwhile skill to learn, or a waste of time?
Cheers,
Jon
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
PostPosted: 17:55 - 03 Jan 2006    Post subject: Reply with quote
Blipping the throttle helps to give a smooth change. If you are locking the wheel on a small capacity 2-smoke, I would say you are changing down way too soon.
You could lock the rear on my 660cc 4-stroke single by downshifting but you had to be taking the piss with the gearshifting or so hard on the brakes the wheel was barely touching the ground
Wave2k
G's Stalker
PostPosted: 17:56 - 03 Jan 2006    Post subject: Reply with quote
2 strokes have barely any engine braking so blipping the throttle would have no use ?
Ducati 1299 Panigale
2009 Corvette C6 z51
loply
PostPosted: 18:02 - 03 Jan 2006    Post subject: Reply with quote
Evidently has enough to lock the wheel, wave...
Yamaha SZR660 Caution to the wind, the throttle pinned!
loply
PostPosted: 18:05 - 03 Jan 2006    Post subject: Reply with quote
Sorry, to answer your question, blipping the throttle most certainly would prevent your from locking the wheel in the way you have been.
You do of course need to learn to do it smoothly, blipping too little will result in engine braking and too much is also dangerous as it can launch you into a corner faster than you mean to.
Finglonga
PostPosted: 18:07 - 03 Jan 2006    Post subject: Reply with quote
Blipping saves the gearbox greaf when changing down as it gets the engine and road speed synchronized and stops the crunch as you change down......or it should if you do it properly. Wink
Andy Sez....
F.Y.Y.F.F.
jonnay
PostPosted: 18:12 - 03 Jan 2006    Post subject: Reply with quote
OK, cheers people, I'll set about trying to get to grips with it Very Happy
Stinkwheel, yeh, it only happens if I bang through the box very quickly in the dry, but in the wet it was a bit more severe. I also had a tyre on there which was rather expired, and I imagine that didn't help matters. I'll see if it still does it with my new tyre now it's fitted Wink
Thanks!
Jon
NC30UK
PostPosted: 18:15 - 03 Jan 2006    Post subject: Reply with quote
Blipping stops the engine becoming starved of oil as high revs with no throttle means no fuel which on a 2 stroke means no oil. it's an essential thing to do on a race bike, helpful to do on a road bike.
The rear wheel is probably locking as you just drop the clutch when you change down.
When engine brakeing you have to let the clutch out more slowly than you do when pulling away!
PostPosted: 18:26 - 03 Jan 2006    Post subject: Reply with quote
Although not on a T or GT series Suzuki. They lube the bearings and bore directly on a closed throttle via injector nozzles. I have no idea why someone doesn't still use that system, it works well.
Method
PostPosted: 18:53 - 03 Jan 2006    Post subject: Reply with quote
I was thinking about this the other day...
I dont do it myself, but thought i would try it and couldnt...
So would someone care to explain how you blip the throttle to downshift - Properly.
Embarassed Laughing
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
SoND
PostPosted: 18:54 - 03 Jan 2006    Post subject: Reply with quote
On the topic of engine braking...
Does engine braking do your motor any harm because it just doesnt sound healthy to me?
Milo
PostPosted: 19:18 - 03 Jan 2006    Post subject: Reply with quote
On a 4-stoke it's the same with high revs, just normal wear and tear.
On a 2-stroke the engine relies on the fuel/oil mix for lubrication, so with less lubrication running through at high revs then when accelerating it would dramatically decrease the engine's life span.
In between half clutch on way in and half clutch on way out give it a blip to aim to increase your revs by about 1k - this will probably be more like 600rpm once the clutch is disengaged and it should smooth out your down-shifts.
If your bike surges forward while blipping then you're doing it too soon.
Just start practicing and you'll soon get the hang of it. Thumbs Up
Shaft drives rule. Razz
Wave2k
G's Stalker
PostPosted: 19:26 - 03 Jan 2006    Post subject: Reply with quote
i baraly lock the wheel on my 750 in the cold wet snow, so the 2t must have shite tyres and be changing down near the redline.
satans_BIG_helper
PostPosted: 19:30 - 03 Jan 2006    Post subject: Reply with quote
I used to blip the throttle on the TDR and the mito when changin down through gears... it stopped the clunking problem i found... n wen coasting(in gear) i used to clutch it n blip throttle a little bit so that i knew 2T was goin through....
TS 50er >CG 125>AR 125>TZR250> z200(shit heap)> ZXR750 H2 > VT500 FT >XLR250 > Mito125mk1 (unlucky strike) > TZR250 3ma > GS550 > TDR250 > GSXR750 >GS1000 > Elefant 650 > GPZ750 > FZR600>z1000 (03) > KTM 640 LC4
(Yeah i forgot some too :S )
Zimbo
PostPosted: 19:38 - 03 Jan 2006    Post subject: Reply with quote
As suggested above, leave it in the higher gear till the revs have dropped a lot more, then change down.
I used to do the same thing, on a trackday last year i was braking from speed into a hairpin and skating the back wheel as i did so every lap, with accompanying screching of rear tyre.
After a few sessions, whilst waiting to go out, the marshal advised me to change down later to prevent this.
"Oh" said I, "i don't mind the back sliding under braking, doesn't bother me"
"well" sid he, "it's certainly bothering us . . . "
So i took his advice, and found I was no slower by leaving the downshift till later, the slides stopped, and I was more controlled into the bend. Lesson learned.
riichy
PostPosted: 20:47 - 03 Jan 2006    Post subject: Reply with quote
i just do it becouse, its sounds good Twisted Evil ....
and makes it smooth too, i would say go for it blipp all you like cant do not harm Mr. Green Thumbs Up
.......... PLOD ............ zx636 2004
JonB
Afraid of Mileage
PostPosted: 21:11 - 03 Jan 2006    Post subject: Reply with quote
Ever since the trackday I have blipped the throttle everytime I change down after a scary moment changing down into a corner. Razz
PostPosted: 21:36 - 03 Jan 2006    Post subject: Reply with quote
People change down without blipping the throttle. Wierd. Wink .
Milo
PostPosted: 21:40 - 03 Jan 2006    Post subject: Reply with quote
At first I started it because I'd heard it was good, I kept doing it because it sounded cool and I keep doing it because it's so much smoother to downshift and now totally natural to do. Thumbs Up
EllioTT_GiXXeR
PostPosted: 22:00 - 03 Jan 2006    Post subject: Reply with quote
I dont need to blip the throttle on the 600? Something i should know Twisted Evil
www.gixerjunkies.net www.gixerjunkies.net www.gixerjunkies.net www.gixerjunkies.net
Milo
PostPosted: 22:41 - 03 Jan 2006    Post subject: Reply with quote
If you've got a slipper clutch then there's less need for it in terms of safely/grip but it's still a good idea.
PostPosted: 22:50 - 03 Jan 2006    Post subject: Reply with quote
Of course, if you have the revs bang-on, you need to neither blip the throttle nor use the clutch. Tricky though.
NC30UK
You don't NEED to blip the throttle, the rev's will rise of their own accord as you let the clutch out and the rear wheel won't lock provided you let the clutch out slow enough.
colin1
Captain Safety
PostPosted: 23:13 - 03 Jan 2006    Post subject: Reply with quote
How exactly do you blip the throttle when down changing ?
I can only guess.
My guess is that you hold in clutch, blip throttle, then change down, then release clutch.
Or maybe you hold in clutch, change down, blip throttle, then release clutch.
Someone tell me what you are supposed to do pls.
EllioTT_GiXXeR
PostPosted: 23:21 - 03 Jan 2006    Post subject: Reply with quote
Heard someone say that the back wheel can lock up when you change down in wet weather? i have never had this problem and i dont have a slipper clutch.
Colin your right in what you said, you mostly see racers doing it on the track.
The last post was made 20 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.83 - MySQL Queries: 16 - Page Size: 137.36 Kb
