Cagiva raptor/planet 125
Jack_Cheese
PostPosted: 00:31 - 13 Jan 2006    Post subject: Cagiva raptor/planet 125 Reply with quote
I really really like these bikes, and i'm currently saving for one.
What should i look out for? I've found one with 6000 miles on the clock, and it's recently had new front wheel bearings, new swingarm bearings, and a full engine rebuild (the owner seems to think the camshaft was part of this lol). It's been dropped once (very minor damage) and it's at a price i can soon afford.
Also, what's the under-tank storage like?
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
PostPosted: 00:40 - 13 Jan 2006    Post subject: Reply with quote
Is there any under tank storage at all?
Bearings are cheap, but given the comment on camshafts (presume they mean crankshaft) it would not surprise me if by the swinging arm bearings they mean something else.
planet rider
PostPosted: 12:08 - 13 Jan 2006    Post subject: Reply with quote
Hi mate i payed 1300 for mine when i brought it with just under 3k on it no rebults etc. undertank storage you will be able to fit um er lol not a lot i could just get a pair of trainers under it.
what year is the bike and how much is it going for there good bikes i would realy pay more than 1.3 knowing that its had a rebiuld at only a small amount of miles.
mine now needs its 1st rebuild at 34k
Xj 900
Jack_Cheese
PostPosted: 12:29 - 13 Jan 2006    Post subject: Reply with quote
all i can say is, it's bloody cheap. It's a 99 bike if i remember correctly. What problems have you had with yours, and what is the parts availability like?
Jack
Fazerkev
PostPosted: 15:55 - 13 Jan 2006    Post subject: Reply with quote
Some of those Derbi 125s are very good looking...if not a tad modern
Kev
STONEY!
PostPosted: 16:12 - 13 Jan 2006    Post subject: Reply with quote
the planet is am amazing bike my friends and i have had one in our group for a long time now its probably the most fun bike i have ever ridden you should look out for electrical problems also check for play in the swingarm as the bearings arent great as for under tank storage cagiva reckon u can get a helmet under there ive tried it aint gonna happen lol i used to put my backpack in there usually but as long as its at a good price id say anything below a £1000 is ok go for it if the can/silencer is damaged i have a spair in good condition for sale
Gazdaman
I did a trackday!!!
PostPosted: 16:38 - 13 Jan 2006    Post subject: Reply with quote
Mate of mine had one, he liked it. Same engine as the Mito.
Mileage isn't hugely important if it's had all the bearings and engine done.
If he thinks a 2 stroke engine has a cam shaft maybe it hasn't actually had any engine work done...
Why would you even get as far as the crank shaft, cuz that involves splitting the cases and I can see little point unless it broke or seized.
Gaz
Jack_Cheese
PostPosted: 16:54 - 13 Jan 2006    Post subject: Reply with quote
The exhaust can is indeed scratched to buggery, but i hate the look of that anyway, i'll probably get an aftermarket can (can't be arsed with a full system as the rejetting etc. is too much hassle.
As for the cam shaft lol, i think he may have meant the balance shaft (if it has one). I'll check the recipts for engine work.
Thanks for your help guys Thumbs Up
Jack
Keen
PostPosted: 17:48 - 13 Jan 2006    Post subject: Reply with quote
I had a Planet as my first bike at 17, nice to ride and look at but mine had lots of problems (but it was from a breakers and fairly tatty).
The under tank storage is next to useless, wouldn't come close to fitting a lid and its open on either side so small stuff could fall out. Besides, when the tank's full its a bitch to hold it up while you try and get something under it.
Derestricted it was nippy, would show 105ish on the clocks, it handled really nicely and the brakes were brembos, overkill for such a little bike - so great. However electrics didn't like the wet, would stop working for a while then mysteriously be fine later. Apart from that, the lack of a rev counter is a bit of a pain on a revvy 2 stroke.
Biggest problem- getting parts. The factory are useless and it can takes ages for stuff to arrive, so if you buy it make sure it doesn't need anything and try not to drop it Very Happy
They're not perfect, but if you're after a 2 stroke race rep it makes a more sensible buy than a mito.
Jack_Cheese
PostPosted: 22:48 - 13 Jan 2006    Post subject: Reply with quote
No rev counter! the one flaw with what would be a perfect bike for me (apart from parts availability). Even my first scooter had a rev counter! How the hell can you run it in without one!
Jack
Keen
PostPosted: 23:25 - 13 Jan 2006    Post subject: Reply with quote
I suppose the good thing is it teaches you a bit about how to listen to the engine and get the most power from it without having to rely on the counter... but yeah, it was also a pain in the ass.
vlf
PostPosted: 23:31 - 13 Jan 2006    Post subject: Reply with quote
You can just ride it smoothly and let the feel of the engine get to you, you won't even be looking at the tacho, anyway.
Major_Grooves
The Doctor
PostPosted: 17:38 - 14 Jan 2006    Post subject: Reply with quote
The front wheel bearings seems to go very easily on them. I also had my alternator break. Check the downpipes - they are quite low quality so rot easily and are expensive to replace - not much chance of finding a spare set in the breakers. Mine really hated running in the cold/damp too.
All that said, I really loved it!
Keen
PostPosted: 17:48 - 14 Jan 2006    Post subject: Reply with quote
ah, its probably worth mentioning that the alternator went on mine as well, it might be a common problem and they're bloody expensive to replace! I also had my throttle cable snap twice, both times at the very top near the twist grip.
cagiva gezzer
PostPosted: 18:29 - 14 Jan 2006    Post subject: Reply with quote
Rob will become your best friend!
Owning a cagiva has become a lot easier since he's been around. As for the planet, same as the mito/supercity for a lot of the parts. The main issues have been covered.
Wheel bearings go a lot. £10/pair
Exhausts need painting twice a year.
Will make 31bhp and do 90mph
Electrics can play up a lot. Generators and starters.
Fun bikes, but you need to like tweaking with things to keep them running sweet.
Jack_Cheese
PostPosted: 14:48 - 15 Jan 2006    Post subject: Reply with quote
I can do minor repairs, and to be honest, i'd like a 125 that needs me to tinker with it, i'd rather learn my tinkering skills on a simple 125, than a much bigger and more expensive bike.
Thanks for all your help, i'm probably going to shell out on this bike.
Jack
lilredmachine
PostPosted: 14:56 - 15 Jan 2006    Post subject: Reply with quote
Make sure you get pictures, Planets are sexual 125s.
The last post was made 20 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.04 - MySQL Queries: 16 - Page Size: 101.34 Kb
