| Alastair |
 Alastair Borekit Bruiser
| Davo |
 Davo Davo To The Rescue!
| Kickstart |
 Kickstart The Oracle
| Alastair |
| Kickstart |
 Posted: 00:03 - 31 Jan 2006 Post subject: |
Feel how the kick start feels compared to you existing engine. Maybe take the rotor cover off and feel for any vertical play in the crank.
To be honest without stripping it down you are not going to be able to tell that much but at only £31 it is probably not worth worrying about especially if you intend to fit a new piston.
A Yamaha dealer should be able to get the parts. Only issue is that your model of TDR is not a UK model so it is likely they will not have the parts list (been told that one of the models of DT125 parts are the same but not certain on this).
| Alastair |
 Posted: 11:02 - 06 Feb 2006 Post subject: |
Found out the old engine had NO THERMOSTAT Could that have caused all my problems. I did briefly notice that it never seemed to get warm in the 2 and a half days it worked but I put that down to the cold weather.
For the replacement engine I have a few questions too:
If the cylinder is slightly scored (I can just feel it when I rub my fingers on it) should it be re-bored? Piston is pretty scored so will be replacing that but want to know if I should wait to order it as I'll need a bigger one if I need to re bore.
Inside the head is pretty covered in black powder that is proving difficult to remove. Have now got about half off with the help of wd40 and a rag, anything dodgy there or just the sign of an old engine that's not been cleaned inside?
The wiring has been cut off the loom rather than disconnected can I just solder the wires up to the same colour ones before the connector blocks I have from the old engine?
Finally, It looks like the engine was left sitting outside without a cover for a while and as a result there was a bit of rusty water inside. Will this have caused any problems? How should I flush the bottom end out? I really don't want to split it.
Truth be told I'm getting pretty fed up with this now and it's taking a long time to get sorted but thanks to everyone that's offered advice so far as I wouldn't have got anywhere yet without your help  |
| Kickstart |
| Alastair |
| Kickstart |
| ZRX61 |
 ZRX61 Victor Meldrew
| Alastair |
 Posted: 10:28 - 10 Feb 2006 Post subject: |
I had to google that, is it from a plane? Bet you love posting those pics though eh
Have decided that the engine needs decent bit of love and attention so took it into a garage yesterday. He's going to split it and then let me know everything that needs doing but I'm expecting over £250 realistically. Wont find out 'til wed next week though
He did suggest that a Malossi kit may be only slightly more expensive than the re-bore and new piston that it already needs and would take it up to 170cc. Does that sound like playing with fire? He has plenty of experience tuning 2T's though so I think he knows what he's doing. |
| Kickstart |
The last post was made 20 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
