Fork seals. Bolt at the bottom.
DukeRed
PostPosted: 16:08 - 25 Jan 2006    Post subject: Fork seals. Bolt at the bottom. Reply with quote
My fork seal blew after only two months of the mechanic putting a new one in.
Reason I took them to him in the first place was that I couldn't get the bolt at the bottom out. Bent two allen keys before giving up. Any ideas how to get it out?
Also I have a dirt and oil seal, do I need anything else?
How does having one blown affect the handling? I think I noticed it being much more unhappy at high speeds on the motorway when hitting cats eyes, twitching quite alot. Is that part of it?
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
Bezzer
PostPosted: 16:16 - 25 Jan 2006    Post subject: Reply with quote
Get an allen head socket, cheap enough for a set of 3/8ths drive ones and much stronger than an ordinary allen key.
https://www.machinemart.co.uk/images/products/mid/MM040214926.jpg
You might find you have to hold the inners else the lot turns and the bolt doesn't undo, different bikes have different locking methods, what bike is it?.
And yes a blown one will affect the handling. You should also check the stanchions to see if they are bent/pitted or whatever with it blowing another seal so quick, also the bushes inside might be worn.
DukeRed
PostPosted: 16:29 - 25 Jan 2006    Post subject: Reply with quote
Ah thats what I forgot to mention.
I've got the allen key sockets but the problem is I have to take out the spindle to get to it. I have to compress the fork while doing this, yes?
ZRX61
Victor Meldrew
PostPosted: 16:38 - 25 Jan 2006    Post subject: Reply with quote
Allen socket thingie & an air powered doohicky.
DukeRed
PostPosted: 16:46 - 25 Jan 2006    Post subject: Reply with quote
Ah that air powered thing that I can't afford.
Garnsie
PostPosted: 17:07 - 25 Jan 2006    Post subject: Fork seals Reply with quote
Hi, i have the same problem took my bike to a mechanic because the forks were leaking. The person before me has rounded the bolts at the bottom.....so it cost me £25 just for him to have a look at it. So ive taken it to another mechanic and he said he can get them out but i have to get the new fork seals only thing is were im ordering them from they need the dimensions.....can anyone help its a Honda VFR400K NC21 1988 . Any help appreciated
Bezzer
PostPosted: 20:54 - 25 Jan 2006    Post subject: Reply with quote
No, first thing you should do is loosen the fork top bolt a bit while they are still in the yokes( to make it easier later) then take the forks off, you can't do anything with them on. Then try to loosen the allen bolt, the fork spring is already under compression and that might be enough grip on the inners and let you loosen the bolt. If that fails you've got to take the fork top nut off (that you started to loosen earlier) take the spring and any spacers out, drain the oil then whatever method your bike uses lock the inner so you can undo the bolt. Once that's out you rip out the stanchion from the leg, check for why it went i.e. bent/pitted/duff bushes then reassemble with a new seal.
Have you got a manual because there may be slight variations as to what you need to do?
ZRX61
Victor Meldrew
PostPosted: 17:14 - 26 Jan 2006    Post subject: Reply with quote
It literally takes about 5 seconds, any bike shop will usually undo that bolt for free.
DukeRed
PostPosted: 19:13 - 26 Jan 2006    Post subject: Reply with quote
Cheers for the replys. Was thinking since the mechanic only did it 2 months ago could I ask him to do it cheaper since he might not have bedded it in properly the first time?
The last post was made 20 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.69 - MySQL Queries: 16 - Page Size: 63.09 Kb
