Motrax indicator prob
True Blue
PostPosted: 21:21 - 14 Apr 2003    Post subject: Motrax indicator prob Reply with quote
I just put on some front Motrax inicators on my NSR yesterday(Lookin good Cool ).
I gave them a quick test and they were fine. On way to work this morning though the bike wouldn't indicate left. I can hear the relay/flasher unit switching frantically, which I'm sure ain't good.
The right indicator seems to be working ok albeit a bit fast, I think thats normal though. Even when indicating right I can hear the relay/flasher unit switching really fast for a second then returning to normal.
Any ideas? Confused
Much appreciated.
Ritchie
kev
I Hump Things
PostPosted: 21:24 - 14 Apr 2003    Post subject: Reply with quote
maby a bulb has blown
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
PostPosted: 21:27 - 14 Apr 2003    Post subject: Reply with quote
bulb blown.
wiring wrong
did it work when you first wired it all up etc?
True Blue
PostPosted: 21:33 - 14 Apr 2003    Post subject: Reply with quote
Bulb okay. And I checked the polarity of the connection which was fine. Though the polarity shouldn't asctually matter for a bulb.
Yeah it worked when i wired it up.
I cant understand it.
Confused Confused Confused
kev
I Hump Things
PostPosted: 21:35 - 14 Apr 2003    Post subject: Reply with quote
have you tryed a differnt bulb in it or actually tested the bulb
Demonic69
The Pink Rhino
PostPosted: 21:46 - 14 Apr 2003    Post subject: Reply with quote
What bulbs? The flasher unit may not be able to handle 23-25w bulbs very well
Back on a Blade. Just feels so right.
craigT19
Jolly Green Giant
PostPosted: 21:52 - 14 Apr 2003    Post subject: Reply with quote
bahh simple folk lol
when you fitted your motrax indicators you probably noticed the wires were the same colour.....thats cos they cant be wired wrong..its not possible the wires can go either way Wink
as for the bulb going...very unlikely, normally what happens when a bulb goes is the remaining bulb simply stops flashing.
i would think you may have a phuked relay, very unlikely its the bulbs.
unless
the motrax indicators i had needed to be clamed to the bike wires, if youve done the same theres a chyance you may have shorted it by not making the wiring neat and tidy....the above happened on my first attempt Laughing
good luck
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
True Blue
PostPosted: 21:55 - 14 Apr 2003    Post subject: Reply with quote
I put a voltage across the bulb to test it.
I'm just assuming that its 23W cause it didn't actually say on the pakaging or the indicator itself. Well I wasn't sure if the flasher unit would handle it myself, but by all accounts it should. Strange how the right hand side works though.
Where would I get a 10W bulb for it? It'll need to be an orange one.
Danny
Ask Me About Stoppie School
PostPosted: 22:03 - 14 Apr 2003    Post subject: Reply with quote
It does not seem to do any harm getting the wiring wrong way round when installing indicators on the NSR. I just randomly tried the wiring till it worked Laughing But i had to fiddle about with different what bulbs @ the front and back. I'm running 23w @ the front and 4w @ the rear Confused to get maximum brightness, but it's still kinda shit. Confused
True Blue
PostPosted: 22:04 - 14 Apr 2003    Post subject: Reply with quote
I hear what your saying there craig. The wires could go anyway round, yeah. But to make it pukka I connected It + to + and - to -. On the NSR the wires are different colours. Green is - and orange and white (or something) is +.
I definately didn't short it. I'm careful like that cause i'm an electrician.
I just thought someone might have came across this before but i'll look at it again tommorrow, seeing as i've got the day off work.. Cool
True Blue
PostPosted: 22:06 - 14 Apr 2003    Post subject: Reply with quote
4w at the rear Danny? Is that bright enough? What indicators have you got, is it the clear ones?
And where do you get bulbs to suit it?
Danny
PostPosted: 22:17 - 14 Apr 2003    Post subject: Reply with quote
NO Laughing But when i had 23w all over it was worse for sum reason Confused
nope yellow ones. But i have ultra cheap ones, for £5 a pair Shocked Surprised
local car spares shop, 30p each i think Very Happy
True Blue
PostPosted: 00:29 - 15 Apr 2003    Post subject: Reply with quote
Mine might be brighter cause they are clear. I'll look in to it tomorrow and let yo know how i get on.
In theory with 23W all round they would be about almost 2 and a half times less bright cause its only designed for 40W output tops
Danny
PostPosted: 00:56 - 15 Apr 2003    Post subject: Reply with quote
really, must get me some 10w blubs then
True Blue
PostPosted: 01:00 - 15 Apr 2003    Post subject: Reply with quote
Yeah mate, putting more powerful bulbs in will only make them brighter if the unit can handle it. You could put 300W bulbs in but the unit would still only pump out 40W or whatever
True Blue
PostPosted: 14:53 - 15 Apr 2003    Post subject: Reply with quote
So I went out this morning and tried my indicators. Much to my disbelief, they worked Shocked
Only for about 2 seconds though, then kapoot.
WTF
So anyway, I whipped out the cables from the motrax indicator and put them across a standard bulb. The indicators worked fine. Nothing wrong with the flasher unit then. Confused
Once the Motrax one was connected back up it doesn't work again.(Still don't understand why the other side works though Question )
I tried everywhere to get a 10 Watt bulb that size, and no joy. Where the hell are you guys getting them from? Can I get them off the net?
Sad Sad Sad
True Blue
PostPosted: 20:41 - 15 Apr 2003    Post subject: Reply with quote
Well 2 flasher units and £14 later, the fucking things still don't work Evil or Very Mad
I tried a unit from Halfords, didn't work. I got one from Kawasaki dealer, same make but 2 x 23W rating. This one blue the fuse ( I think I managed to throw this one over 100 feet, which was impressive).
Lesson learned - Don't fuck about with your bike it'll beat you. Sad
PostPosted: 20:49 - 15 Apr 2003    Post subject: Reply with quote
tkae it to the shop you got them from.
and my indicators just plugged straight in Confused
Danny
PostPosted: 20:53 - 15 Apr 2003    Post subject: Reply with quote
This is coming from an electrician no less Laughing Laughing Laughing
True Blue
PostPosted: 22:02 - 15 Apr 2003    Post subject: Reply with quote
[quote="Danny"]
Your'e telling me. Confused Unfortunately electronics arn't my game.
True Blue
PostPosted: 22:08 - 15 Apr 2003    Post subject: Reply with quote
Don't think he would take them back as there is nothing actually wrong with the indicators themself. Plus I have no receipt or packaging, which I'm sure aint a good thing Rolling Eyes
Yeah but everything I touch turns to shit Sad
I think I'll just replace them with some 10W ones. I found a website with some cheap ones here... https://www.vehicle-wiring-products.co.uk/VWPweb2000/mcycle-1/mcycle-1.html
Danny
PostPosted: 00:30 - 16 Apr 2003    Post subject: Reply with quote
Your'e telling me. Unfortunately electronics arn't my game.
my bad Rolling Eyes There was someone else who said he was an electrician Confused who had an NSR
Try this:
https://www.hondapart.co.uk/products.htm
Mini indicators pair - £4.99
Crazy Manx Man
The Fly Swatter
PostPosted: 06:33 - 16 Apr 2003    Post subject: Reply with quote
I've never seen Mini Indicators as a worth while 'mod' but if you have massive massive bulky ones to start off with then why not change them Smile
Too Fast For Even The Plod To Keep Up With
True Blue
PostPosted: 20:53 - 16 Apr 2003    Post subject: Reply with quote
I'm not throwing anymore money at this prob. I've just ordered 10W indicators Confused
Bennyboy2003
PostPosted: 22:52 - 16 Apr 2003    Post subject: Reply with quote
I had that problem just change the relay, goto halfords £5 problem sorted!
Take a fucking chill pill!!!!
The last post was made 23 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 1.24 - MySQL Queries: 16 - Page Size: 129.88 Kb
