| swingermike |
 swingermike L Plate Warrior
| BFG |
 BFG Brolly Dolly
| Kickstart |
 Kickstart The Oracle
 Posted: 14:52 - 27 Jan 2006 Post subject: |
Not sure what you mean by bubble? If you mean that taking the cap off the reservior and pulling / releasing the brake you will see an air bubble rise from the hole in the bottom of the reservior then that is not true. You might see an air bubble come up but only if there is air in the system.
I would suggest either the caliper needs stripping and cleaning (take your time and be careful with the seals), it is sticking on the sliding pins on the caliper or the brake fluid reserviour is far too full.
| swingermike |
| BFG |
 BFG Brolly Dolly
 Posted: 18:00 - 27 Jan 2006 Post subject: |
You can get a master cylinder repair kit for not many pounds. Strip the master cyl, blow out any passages with compressed air. Pop in the new piston (or swap the seals if no piston provided), flush the whole system through with fresh brake fluid and bleed.
Maybe then do the same to the caliper when you find it didn't cure it.  |
| Kickstart |
 Posted: 18:23 - 27 Jan 2006 Post subject: |
You should get fluid coming back up into the reserviour, but if the piston is sticking then it will not move back and will not push fluid back.
The caliper should slide on the pins fairly easily.
New caliper seals are expensive for what they are but still not much for a bike with a limited number of brake caliper pistons. Generally there are 2 seals on each piston, the inner one actually sealing the fluid while the outer one just keeps dirt and muck out. Often the caliper will work fine for a short while with the outer seal missing but it will rapidly jam up. My guess is that this is missing / damaged (and there is probably a build up of corrosion in the grooves the seals sit in).
| swingermike |
The last post was made 20 years, 246 days ago. Instead of replying here, would creating a new thread be more useful? |
