| DynamiteBoy |
 DynamiteBoy Scooby Slapper
| LustyLew |
 LustyLew World Chat Champion
 Posted: 11:09 - 03 Feb 2006 Post subject: |
sounds like carb icing. It's been quite cold the past few days.
What you need is some Silkolene Pro FST mixed with your petrol.
Friend of mine has a CG clone and gets the same problem. So you're not alone! ____________________ Like a Yorkie - I'm not for the girls  |
| veeeffarr |
 veeeffarr Super Spammer
| Black Knight |
 Black Knight World Chat Champion
| DynamiteBoy |
| veeeffarr |
| hedjehog |
 hedjehog Nova Slayer
 Posted: 13:15 - 03 Feb 2006 Post subject: |
I had a thought about the petrol. How long has it been since you last rode her? Petrol 'goes off' and when I got mine it died under throttle before I put new fuel in. Also, silly but, has it got enough in it?
Not saying it is those things (I'm no mech wizz), but worth a look.
hedjehog ____________________
1988 CG125 BRE; 2000 GPZ500S D7; VFR 800 FI-X; 1980 CB 250 RSA; 1998 FZS 600 Fazer; 1986 Honda C70 E |
| sickpup |
 sickpup Old Timer
| sickpup |
 sickpup Old Timer
| DynamiteBoy |
| nrml76 |
 nrml76 Brolly Dolly
| Superlight |
 Superlight Nitrous Nuisance
| RickHolt |
 RickHolt Traffic Copper
| faith183uk |
 faith183uk Nitrous Nuisance
| DynamiteBoy |
| DynamiteBoy |
| GearboxGeezer |
 GearboxGeezer World Chat Champion
| sickpup |
 sickpup Old Timer
 Posted: 17:27 - 04 Feb 2006 Post subject: |
And the prize for not being able to read a thread goes to... |
| mr.z |
 mr.z World Chat Champion
 Posted: 18:10 - 04 Feb 2006 Post subject: |
Was it raining?
Mine used to stop at lights too, mostly when it rained..
When sparkplugs go old/bad they will play up more when cold, try checking the gaps, if not try replace the plug and plugcap (cheap enough)
(no offence but) For the love of gawd don't touch the carbs unless you know what your doing! settings just dont go "wrong" unless they are messed with, an air leak is more likely (try spraying wd40 on any joins allong the air intakes)
You can't balance one carb btw its for when you have two carbs and you need to have them feeding equal ammounts of fuel into all cylinders, i.e. you need more than one cylinder
Try spraying wd40 arorund the airway (it the revs rise then theres your leak), then check/replace the plugs...
(edit: just read your other thred, not haveing much luck eh? ) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| bidman |
 bidman Crazy Courier
 Posted: 19:12 - 04 Feb 2006 Post subject: |
hey, sorry to point out the basics but make sure that the choke is off and that the choke lever is nice and tight and not rattling shut, choking the engine, Dan  ____________________ Don't ride it, RAG IT!! |
| dotti |
 dotti Scooby Slapper
The last post was made 20 years, 185 days ago. Instead of replying here, would creating a new thread be more useful? |
