Author |
malb |
malb Spanner Monkey
Back to top |
Jammy-R6 |
Jammy-R6 Scooby Slapper
Back to top |
malb |
malb Spanner Monkey
Back to top |
Jammy-R6 |
Back to top |
Richard1987 |
Richard1987 Scooby Slapper
Posted: 00:09 - 22 Feb 2006 Post subject: |
loads of preperation tho, sanding, flatting etc. you would need to be taught on how to do the job and perfect it
good skill to have tho
i dont think its worth buying all the gear without actually knowing how to use it.
but canned aerosols give a good finnish now? cutting out the price of the compressor and gun. might be a better option ____________________ add me to your msn messenger contacts : rip307@msn.com |
Back to top |
Jammy-R6 |
Posted: 00:35 - 22 Feb 2006 Post subject: |
Richard1987 wrote: | loads of preperation tho, sanding, flatting etc. you would need to be taught on how to do the job and perfect it
but canned aerosols give a good finnish now? cutting out the price of the compressor and gun. might be a better option |
Or a crap option! Your talking serious dough to use rattle cans for a whole bike and youd be left with a ok finish rather than an excellent finish. I would buy the gear, you can use the compressor for loads of other things anyway, tyre pressures etc. and once you have read the proper ways of doing it and practised a bit you'll be well away. |
Back to top |
Richard1987 |
Posted: 00:47 - 22 Feb 2006 Post subject: |
ive done various car body repairs before, in the workshop i use. we do have the equipment to do jobs, it is great in the long run i totally agree, never doubted that. but for someone who's just starting out. i think the cans would be a better option. i would be gutted if i paid hard earned cash on all the gear only to find that you just suck at spraying.
If you try the cans and find that you can spray well, spend your money gear and earn some dosh?
if you dont feel comfortable spraying, its only a few cans? accept the finished product or get someone else to do it for ya ____________________ add me to your msn messenger contacts : rip307@msn.com |
Back to top |
ZRX61 |
ZRX61 Victor Meldrew
Back to top |
JMH |
JMH Two Stroke Sniffer
Posted: 07:45 - 22 Feb 2006 Post subject: |
There's no reason you can't use spray cans. I've painted 2 bikes that way, and the one bike won first prize in a bike show! Lacquer spray paints dry very quickly (so they're better to use if you have to do your painting outside), but they lay on very thin, and require multiple coats, followed by wet sanding, then more color coats, more wet sanding, yada yada yada. The final outcome can be very nice if you're willing to take the time to spray the paint right, and follow with lots of wet sanding and final clear coats.
Enamels spray on shiny, but they take longer to dry, and have a tendency to create "orange peel".
The most recent bike I completed was painted with primarily Hammertone paint (black). The top of the gas tank was where I splurged, spraying it with that fancy color-shifting paint, adding artwork, then clear coating the top of the tank with clear urethane paint. The Hammered paint was not top-coated, since it has a higher risk of getting chipped (and will be easier totouch up because of the rougher finish of the paint).
Hope this may be of some assistance!
--JMH |
Back to top |
www.125power.com |
www.125power.com Crazy Courier
Posted: 14:30 - 22 Feb 2006 Post subject: |
If you take your time and read up on it aerosol's can give a really good finish......lots of prep work though, aerosol paint is thinner than normal paint so any dips, bumps, even dust will show all the way through to the final coat.......
I did this with aerosol's i bought 2 tins primer, 4 tins colour, 2 tins laquer and one tin of white paint and one tin of white wheel paint.
Plus sanding paper etc came to about £80-£100
https://www.bikepics.com/members/gavincarter2004/03yq100/ Paint wont be to everyone's taste but it is the finish i am showing you....... ____________________ My eBay Items |
Back to top |
Jammy-R6 |
Back to top |
ZRX61 |
Back to top |
Misc |
Misc World Chat Champion
Back to top |
The Tot |
The Tot World Chat Champion
Posted: 16:21 - 22 Feb 2006 Post subject: |
If your using spray cans, prime the areas properly and work the laquer off with 800 grit wet and dry. I'd say take the best part of a day to prepare the surfaces because otherwise you'd end up with a paint job like mine! .
I suggest not using enamel based paints as it takes forever to dry and because they're much thicker in consistency. It pissed down when i was doing my painting in the shed and consequently it caused the paint to to sponge up.
Laquer based paints from halfords are good, but thin multiple layers is how you're supposed to do it. Take time with the sanding.
It should be wise to say TAKE YOUR FAIRINGS OFF when you paint, in my case, this wasn't possible, so i ended up lines of dripping paint everywhere despite very well placed masking. Also, with masking tape, it tends to peel off the layer of paint underneath, so be careful. A hot cup of water and stanley knife can be used to score along the masking tape, using the hot water to remove the stickiness of the tape.
But if you can get access to a compressor and spray gun, by all means, use that. ____________________ The Tot 2007 Yamaha R1 4C8 2002 Yamaha FZS1000 Fazer &
www.youtube.com/Titot182 for your bike gear reviews and pop punk covers
Earl Of Easycore Pop Punk Will Never Die! |
Back to top |
malb |
malb Spanner Monkey
Back to top |
ZRX61 |
Back to top |
The last post was made 18 years, 70 days ago. Instead of replying here, would creating a new thread be more useful? |
