jcolley1364 Borekit Bruiser
Davo Davo To The Rescue!
Superlight Nitrous Nuisance
Posted: 14:04 - 24 Feb 2006 Post subject: |
Towbar wiring is (should be) standard, but there a few different types of connector. Assuming there is a single connector without split charging system, it should be as follows:
Pin 1 Yellow wire to L indicator
2 Blue to Fog Lamp
3 White to Chassis earth
4 Green to R indicator
5 Brown to R tail light
6 Red to Brake Lights
7 Black to L tail light
You'd be amazed how many people think they know better, and wire to their own pattern. Which is fine, if you never want to tow anything else and never want to use a different towing vehicle. Otherwise, all sorts of entertaining things happen when you plug it in, from wrong lights to meltdown
Good luck. ____________________ You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape. |
Richard1987 Scooby Slapper
Posted: 14:53 - 24 Feb 2006 Post subject: |
we had a H reg escort with a towbar fitted, when it was pluged in, we lost all light at the rear and the cars front indicators wouldnt work
was bodged onto the rear light clusters and an audible towing sensor was fitted? what ever the hell that was ____________________ add me to your msn messenger contacts : rip307@msn.com |
Hex Party Boy
