Propping up a NSR125
sunbear
PostPosted: 15:00 - 15 Mar 2006    Post subject: Propping up a NSR125 Reply with quote
Whats the best/safest way to hold up the bike to take off forks without spending 150/200 quid on a jack? Crying or Very sad Need to get the forks off for a seal change Very Happy
Groove
PostPosted: 15:09 - 15 Mar 2006    Post subject: Reply with quote
Paddock stands from Ebay? Thumbs Up Idea
Rob W
PostPosted: 16:14 - 15 Mar 2006    Post subject: Reply with quote
I dont really know much about NSR's, but is it possible to get the fairing's off and get a jack under the engine somewhere?
TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 RR-W Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900
fuzz
PostPosted: 16:23 - 15 Mar 2006    Post subject: Reply with quote
Paddock stand rear would work, but you'd need to use a jack under the engine to lift the front, or suspend it with straps from the ceiling to the headstock. A front paddock stand is no good as it holds the bike up by the forks.
kenny
PostPosted: 17:37 - 15 Mar 2006    Post subject: Reply with quote
i had to take off the front wheel on mine using a jack and some axle stands, took off the front fairing and mounted the two axle stands near the front of the engine didnt look too safe mind you but did the job
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
sunbear
PostPosted: 18:45 - 15 Mar 2006    Post subject: Reply with quote
I have a rear padock stand Very Happy cheers for ideas. Keep them coming Thumbs Up
sunbear
PostPosted: 18:46 - 15 Mar 2006    Post subject: Reply with quote
Nath
PostPosted: 19:04 - 15 Mar 2006    Post subject: Reply with quote
I've never used a padock stand, but on bikes with center stands you can lean on the back of the bike and it will pivot on the stand, raising the front wheel.
If you can get somebody to help you, raise the front end with the weight all on the back and then stick some bricks under the engine (preferably with a piece of wood ontop to avoid damaging it).
Hard livin', hard luck.
steve09
PostPosted: 19:14 - 15 Mar 2006    Post subject: Reply with quote
dont know if this can help but on me old apprilia there was holes the the bottom of the frame near swing arm i just used to wack axel stands ethier side with a socket extention throgh hole,, just used to put a car battery or few bricks on seat to keep weight on bk wheel
cheers
steve\\s
Cog Head
PostPosted: 23:32 - 15 Mar 2006    Post subject: Reply with quote
when i needed to replace my nakered rear shock, i needed to prop the back of the bike up, and didnt have a jack, and if i left it on the paddock stand it would have just dropped, so i put some tie wraps around the front break leaver nice n tight, then covered my remainig fairing with a padded jacket, and used a "pogo" stick to prop the back end up whilst the bike was lent agains the garage door frame.
must have been the best bodge iv ever concocted Thumbs Up Mr. Green
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
sunbear
PostPosted: 12:28 - 16 Mar 2006    Post subject: Reply with quote
Thanks for the ideas people Very Happy I have done it before with an OLD tzr125 with house bricks. Dont fancy doing this to my nice shiny NSR though Embarassed
Superlight
PostPosted: 13:33 - 16 Mar 2006    Post subject: Re: Propping up a NSR125 Reply with quote
Blimey, what jack have you seen for £200?
I've used centre stand (or rear paddock stand) with a bottle jack under the engine.
You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape.
sunbear
PostPosted: 14:36 - 16 Mar 2006    Post subject: Reply with quote
A proper bike jack on ebay Razz
bidman
PostPosted: 17:59 - 16 Mar 2006    Post subject: Reply with quote
https://cgi.ebay.co.uk/Sports-and-Race-Bike-Headstock-Paddock-Stand_W0QQitemZ8046409765QQcategoryZ25644QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Get yourself one of them, nice and easy to use, dont cost the earth and do the job. Thumbs Up Dan
Don't ride it, RAG IT!!
sunbear
PostPosted: 08:33 - 17 Mar 2006    Post subject: Reply with quote
That looks like it would do the job Thumbs Up Would it fit a NSR125 though ? Confused
fuzz
PostPosted: 11:27 - 17 Mar 2006    Post subject: Reply with quote
Yes it would.
unfazed
PostPosted: 12:37 - 17 Mar 2006    Post subject: Re: Propping up a NSR125 Reply with quote
you can get a small 2 ton trolley jack from most car shops or argos for £15 - £20 just use some wood with it!
sunbear
PostPosted: 13:29 - 17 Mar 2006    Post subject: Reply with quote
OK thanks for all the suggestions fellow biker dudes Razz Think I will go with the headstock stand . Not too expensive and looks a lot safer than propping the bike up on bricks or a jack that would crush my exhaust Razz Cheers all Thumbs Up
400bandit
PostPosted: 17:35 - 18 Mar 2006    Post subject: Reply with quote
I had the same problem a few weeks back when i had to change the forks on the bandit. The way I did it was to lean the bike over really far and put a axle stand somewhere near the foot peg and then jack it up with a normal jack (about 30 quids no way near 200...) and then when it was level I put another axle stand on the jack side, made sure it wasn't going to fall over in any other direction and mission acomplished
O and if I had had some one to help would have been a million times easier Shocked
400bandit
The last post was made 19 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.06 - MySQL Queries: 16 - Page Size: 109.86 Kb
