| Visitor Q |
 Visitor Q $25 whore
 Posted: 18:24 - 19 Mar 2006 Post subject: Rejuvenating the CBR |
Right, to start with, cosmetics arent really a factor to me so thats jsut a bonus if i can repair the crash damage.
Im thinking of spending around 200-500 on my bike at easter.
This may include routine stuff like a new chain and new battery (hasnt been started since september). Maybe even better tyres.
But what would you suggest. And vague prices... ?
I want;
- to get my suspension set up properly for my weight as the bike doesnt feel confident in corners at all
- i want to get my downpipes replaced (cheap stainless steel off ebay, hopefully a named company so they might fit and second hand to save money) as i think they will rot out at any moment and i dont want to replace them after a good dyno
- as mentioned i want it dynoed and jetted
- Also might want to change final gearing, purely to give better smoother wheelies, the ability to wheelie in second, the ability to bring it up at lower revs etc.
- Depending on cost id also like to (before sorting dynojetting) get a 'performance' air filter.
Now how much of it is a) Possible and b) necessary for smooth efficint and proper performance running?
I already have a 'race' can which is fucking with fuelling, so i NEED to at least get it dynoed and jetted.
If i get it jetted to i need to buy a Dynoject kit or will the dyno company be ok to do it Ad Hoc... ?
IF i have money left over, id like to get a new H frame, left hand fairing panel/full set if cheaper/respray as i intend to keep it till death do part anyway, new left side crash bung, possibly engine casing protectors to hide slide damage and get my seat either stitched/replaced/reupholstered...
Any advice, tips, rough ideas on costs?
Its a CBR 600 FT ('96) in red and white. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 18:27 - 19 Mar 2006 Post subject: |
Also, if the CCT goes how much damage does it cause?
I ask this because although mine might mildly need doing, its not really bad. Its a mild ticking when warming up then its fine.
But its obviously a slight problem. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| tatters |
 tatters Exxon Valdez
 Posted: 18:53 - 19 Mar 2006 Post subject: |
| bonny_ricardo wrote: | Also, if the CCT goes how much damage does it cause?
The cam chain could become so slack that the chain could jumped a tooth on its sprockets and do some seroius damage. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Kickstart |
 Kickstart The Oracle
 Posted: 19:22 - 19 Mar 2006 Post subject: |
Air filter is cheap, but a dynojet kit will cost you around 100 before paying for it to be set up. That is around half your budget gone.
Chain and sprockets will be around 80 if you fit them yourself.
If the CCT goes totally then the cam timing will probably go out, likely resulting in 16 bent valves and a very large bill (although probably more likely to cause problems at low revs). However I would suspect that a light ticking is more likely the valves needing adjusting.
| Visitor Q |
 Visitor Q $25 whore
| Kickstart |
| Visitor Q |
 Visitor Q $25 whore
| Zimbo |
 Zimbo World Chat Champion
 Posted: 20:31 - 19 Mar 2006 Post subject: |
The dynojet kit contains new needles of a different profile, bigger jets, new diaphram springs. The dyno people can fit new jets and adjust the current needles to improve matters, but since a large part of the bill is labour you might as well do it properly and have the dynojet kit fitted, final cost won't be that different. Cost will probably be around £200 - £250 all in (supply, fit and dyno).
I'd be amazed if you found a second hand set of downpipes on ebay or anywhere else, you'll probably need to budget for a new set, again £200 - £250 for the pipes.
New chain and sprockets - £100 ish, specify a rear sprocket a couple of teeth bigger than standard if you want to gear it down a bit.
Battery - at a guess around £50.
Suspension - again, around £50 to pay someone to set it up well for you, plus any extra on new bits you might need.
You may need to decide what to do now, and what to do another time. By the sound of it the dynojet kit and dyno is pressing, you may want to change the downpipes first though as that may have an effect on the dyno setup. If you're going to fit a performance air filter you want to do that before the dyno run as well.
Or, stick with the standard can, change the chain and sprockets and battery, have your suspension set up, and leave the performance bits till you've saved a bit more cash up??? |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 20:42 - 19 Mar 2006 Post subject: |
| Zimbo wrote: |
At the very least i want to do all the above...
I was wondering, if you just get it dyno'ed can they tell there and then how out it is mixture wise?
The reason i ask, is because my bikes downpipes are rotting a fair bit. Ive gungummed up any holes, but i doubt that will do me any favours over time.
To get at the downpipes you have to pretty much dismantle the entire bike, plus the engine studs are rusting and are just /slightly/ dodgy
Ive done it before and it took me about a day doing it all. True ive done it once now so the entire process should be a lot quicker and everythings freed up, but still. Tis a worry.
Would rather get some pipes on it and then get it done, but i think everythings out of whack just because of its age anyway, and the fact it was restricted for three days and then derestricted by me in somewhat unprofessional conditions. So again, bit of a constant worry. So id prioritise getting it set up more then getting new pipes.
But as you've said, getting it all done then having the pipes perish on me and need replacing (thus fucking up the fuelling) would be slightly irksome. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| Visitor Q |
 Visitor Q $25 whore
double ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| Zimbo |
 Posted: 21:23 - 19 Mar 2006 Post subject: |
A dyno run should cost you about £30 ish and will tell you immediately how the bike is fueling throughout the entire rev range, will identify any tendancy to run rich or lean at any point in the rev range, and the dyno operator should be able to advise you on exactly what needs doing, if anything, to correct the fueling. Worth it for peace of mind.
Assuming the fueling issue isn't pressing, prioritise the other jobs and do them one by one till the money runs out. Top priority goes to chain and sprockets, but only if yours are worn out, if there's a bit of life in them still then perhaps sort out the suspension instead. Sounds like the downpipes amy well let you down at some stage so start looking for some, I'd start with a stainless set from Motad. You may be lucky and find a standard set of downpipes off a crashed bike second hand, worth a try, it puts off having to buy a stainless set for a bit longer!
If the fueling is bad, do that first, even if you take the cheaper option of replacing the main jets to stop it running lean. Lean running can cause serious damage to the engine over time.
As for fairings etc, I should imagine you're looking at roughly £100 second hand per fairing panel to replace them from a breaker, but you may be able to make yours look a lot better with a bit of patching and paint! Seat recovering need not be that expensive, or find a second hand seat on ebay. |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 22:41 - 19 Mar 2006 Post subject: |
Right ive seen these headers...
Here
But im slightly concerned as they look like they are alot higher then the original.
Also, do the connections from different makes work with each other? As i have a rather aging Arrow on the CBR currently.
Or i can buy a slightly knackered set and rub them down and respray them. But thats still going to be mild steel so will go eventually.
Is it worth 200 ? ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| numark1 |
 numark1 Scared of girls
 Posted: 22:54 - 19 Mar 2006 Post subject: |
Suspension ££££
Downpipes £200
Jets £100 + about £60 an hour labour messing about with them
air filter £30
Sprockets £15
I would get a smaller front sprocket then you won't need a new chain.
All this shit is pricey my friend.  |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 22:58 - 19 Mar 2006 Post subject: |
| numark1 |
 Posted: 23:07 - 19 Mar 2006 Post subject: |
Why do you want new downpipes, are yours rotten??
might be worth cleaning them up if you can, maybe repairing them.
You could then, drop a tooth on the front sprocket, new air filter, new dyno jet kit, fit it yourself have a dyno run then sort out teh suspension with your mate.
THe thing holding you back is the downpipes, same as me on my track bike. Highly overpriced.  |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 23:14 - 19 Mar 2006 Post subject: |
Trust me i am the anti tart, if i could avoid buying them i would.
But my pipes are holey everywhere, and i dont want to spend money on a dyno only to find the bike eats itself a week later and needs new pipes (crashing it also wouldnt be cheer inducing).
Ive fixed them with gungum already, but more will come and its just not worth the agro.
Plus stainless steel blue flames shouldnt lose their value for a good couple of years, even if i do have another off. I dont tend to have problems with SMIDSY's for some reason so id imagine it would be a lowside, thus leaving them intact. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| Kickstart |
 Posted: 01:54 - 20 Mar 2006 Post subject: |
A quick dyno run should be useful to know where it is running rich / lean. Might be that it is lean over a wide band of the mid range and you can get away with shimming the needles, but equally it might be that it is rich as hell at 5000rpm and lean elsewhere, resulting in a different needle profile being needed.
Suspect those Blue Flame pipes would definatly need the jetting playing with (rather different design, far more likely to screw up the jetting than just a noisy silencer). Also suspect those pipes are designed to fit a certain can rather than join up to the stock silencer / similar mounted race can.
D&K do some replacement down pipes which may be cheaper and require less fiddling around with.
| Visitor Q |
 Visitor Q $25 whore
| Kickstart |
| Visitor Q |
 Visitor Q $25 whore
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
| Visitor Q |
 Visitor Q $25 whore
| Zimbo |
| Kickstart |
| craigs23 |
 craigs23 Mr Muscle
The last post was made 20 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
