NSR Dead?
JayZ
PostPosted: 19:32 - 04 May 2003    Post subject: NSR Dead? Reply with quote
Just been for a nice ride out on this little one.
Down at the seafront and decided it's time to go... and it didnt.
All is dead, checked fuses they are fine, had a quick check around and couldnt find nothing wrong.
So had to bump start it, still all dead no lights etc, good thing it wasn't dark.
Any ideas chaps? Confused
Ant
PostPosted: 20:03 - 04 May 2003    Post subject: Reply with quote
battery? from what you say thats the first thing id check Very Happy
JayZ
PostPosted: 20:14 - 04 May 2003    Post subject: Reply with quote
Checked the battery mate.
Just had a second look, there's a small black box next to the air filter with multiplugs inside it.
When i move the wires about, i can manage to get the ignition back.
Plugs look secure enough, perhaps a broken wire. Sad
Oh well, looks like i'll be playing with electrics tomorrow. Smile
While it was all dead coming back home, she didnt half pull away and move much quicker, was suprised. Shocked
kev
I Hump Things
PostPosted: 23:10 - 04 May 2003    Post subject: Reply with quote
one silly thing to look at. make sure the kill switch aint switched off
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
JayZ
PostPosted: 23:21 - 04 May 2003    Post subject: Reply with quote
It's not the kill switch mate, looks like a loose/damaged wiring causing the problem.
If i have a play with the wiring look all comes back to life for a bit. Sad
kev
I Hump Things
PostPosted: 23:22 - 04 May 2003    Post subject: Reply with quote
you better get rewireing then
125wannabe
PostPosted: 00:31 - 05 May 2003    Post subject: Reply with quote
Oh dear.
-ped for sale 2001 Zip SP
?800 ono. its well fast for ped-
-wanted- mk2 VW golf driver 1.6, black-
PostPosted: 00:33 - 05 May 2003    Post subject: Reply with quote
How old is it?
And did you get any warrenty from where you bought it from?
If so, get them to fix it Smile
kev
I Hump Things
PostPosted: 00:35 - 05 May 2003    Post subject: Reply with quote
if not let me have a look and i will give you a price to fix it if your around this area
True Blue
PostPosted: 01:49 - 05 May 2003    Post subject: Reply with quote
Mate, just trace the wires and get a bell set to ckeck each of them in turn to see if it's broken. Might take a while but it's real easy to sort if you reckon its a broken wire.
Also check the connections for corrosion, if you see any looking in a poor state give them a clean. It may well be a bad connection. A bikes wiring isn't that well protected from dampness.
It certainly sounds like one of the above from what your saying.
Good luck Very Happy
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
JayZ
PostPosted: 13:58 - 05 May 2003    Post subject: Reply with quote
Cheers chaps.
Found the problem after cutting away all the black tape.
By the looks of it, it was a red ignition wire.
Two joined into one, it had gone green and corroded, so the soldering iron and heat shrinks came out and all is now sweet. Cool
kev
I Hump Things
PostPosted: 14:12 - 05 May 2003    Post subject: Reply with quote
its lovely when its simple
PostPosted: 14:19 - 05 May 2003    Post subject: Reply with quote
Spam whore Razz Razz
I need to fix my front indicator Sad
kev
I Hump Things
PostPosted: 14:23 - 05 May 2003    Post subject: Reply with quote
you have posted alot more than me in the last day or 2
The last post was made 23 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.29 - MySQL Queries: 16 - Page Size: 81.74 Kb
