Aprilia RS50 Starter Motor
Silky
PostPosted: 09:48 - 28 Mar 2006    Post subject: Aprilia RS50 Starter Motor Reply with quote
Hi there!
Im trying to get this bike back on the road.
So far ive changed the oil, cleaned the tank and carb and the electrics are good. But now the starter motor doesnt work. Mad
NOTE: Please excuse my lack of actual names for the parts. Smile
OK, to check it: i took it off the bike, unscrewed the sheath bit which covered the thing with copper wiring on it that spins.
BUT then that copper spinny bit came out, and through utter stupidity and lack of actual understanding i tried to put it back in but the two little cube bits with springs behind them were in the way, so i attempted to hold them back with a small screwdriver, which in-turn has broken one of them and scratched the other one to shit.
Apparently these bits are called 'Brushes'?
Can anyone tell me if i can buy these bits individually? if so, where and how much?
OR will i have to buy a new starter motor?
Ahhh i love learning from my mistakes. Smile
Have ya ever drunk Baileys from a shoe? IM OLD GREGG!!!
Ichy
PostPosted: 09:55 - 28 Mar 2006    Post subject: Reply with quote
Scratches on the brushes won't hurt. How long is the broken one? As long as they have a good contact to the commutator (the spinning bit in the middle) they will still do their job.
You can buy them seperately since they are designed to wear over time.
Silky
PostPosted: 10:02 - 28 Mar 2006    Post subject: Reply with quote
Ah thanks for the info.
The broken one is in half. Id rather get new ones to be honest.
So are they called 'brushes'?
How exactly are you MEANT to get the spinny bit back in without damaging them?
Ichy
PostPosted: 10:09 - 28 Mar 2006    Post subject: Reply with quote
Yeah they are called brushes, they are made out of carbon and usually have a piece on wire, a spring, and a cap fitted.
The brushes are spring loaded. I either tend to take them out of the brush holder completely, through the top, or i pull the spring up to the top of the holder and hold in place with a matchstick or simlar.
Silky
PostPosted: 10:12 - 28 Mar 2006    Post subject: Reply with quote
Brilliant. Thanks alot!
Just one more thing....
Where do you get them from?
PostPosted: 11:13 - 28 Mar 2006    Post subject: Reply with quote
Not sure how easy they are to get for the RS50, but they are fairly standard pieces on most bikes so you should be able to get something suitable.
Possibly easiest to try the local place that does car alternator / starter motor reconditioning. They can probably sort it for you cheaply. By the way, the starters on them are not known for lasting that long.
The last post was made 20 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.22 - MySQL Queries: 16 - Page Size: 51.95 Kb
