Indicator doesnt flash, it just stays on!
short1uk
PostPosted: 09:08 - 29 Mar 2006    Post subject: Indicator doesnt flash, it just stays on! Reply with quote
My indicator just stays on it doesnt flash. both sides light up but dont flash its weird!
My bike is a 55 plate YBR 125.
Any ideas?
Oh thanks loads guys for info about the gear lever its been adjusted now! Laughing
tonyyzf
PostPosted: 10:10 - 29 Mar 2006    Post subject: Reply with quote
If all the bulbs are ok then it'll be the 'flasher unit' its either faulty or your battery is a bit low on voltage, try reving the bike a bit to see if they flash (reving the engine will raise the battery voltage). If not then you'll have to get a new flasher unit, not sure where it'll be on your bike but presume it's near the battery/fuses etc. It shouldn't be too expensive.
map
Mr Calendar
PostPosted: 10:24 - 29 Mar 2006    Post subject: Reply with quote
tonyyzf wrote:
...reving the engine will raise the battery voltage...
...wrong, it'll raise the alternator output, which will achieve the result of checking if the lights will flash. This is a common problem with smaller bikes when stopped at junctions/lights. Hope it is as easy as this.
HTH Thumbs Up
short1uk
PostPosted: 12:13 - 29 Mar 2006    Post subject: Reply with quote
A chap told me its the relay?
Only had bike 6 months done 230 miles. Should this have gone so quick? Is it a warrenty job?
code guru
PostPosted: 13:06 - 29 Mar 2006    Post subject: Reply with quote
most prob is a relay, mine didnt whant 2 flash so i changed the regulator (the relay is inside the regulator on my bike) and it works, i would take it back 2 the shop u bought if from and tell them 2 replace it under warrenty, coz for my bad spelling
alains
PostPosted: 13:08 - 29 Mar 2006    Post subject: Reply with quote
if you have not replace a bulb , this is the relay , otherwise check bulbs power (wrong wattage)
impaler
PostPosted: 14:51 - 29 Mar 2006    Post subject: Reply with quote
Absolutely. On a practically brand new bike you shouldn't be having problems like this - contact the dealer you bought it from and they should fix it for free.
Monster m600
Web, blog, Bikepics page
An optimist will tell you the glass is half full. The pessimist, half empty. The engineer will tell you the glass is twice the size it needs to be.
short1uk
PostPosted: 17:39 - 29 Mar 2006    Post subject: Reply with quote
took it to the dealer, apparently i had water in the relay? he said he shook it water came out, tried it again it worked?
Weird!! I dont think I have driven in the rain in ages, fair weather rider me!
Mr.Everready
PostPosted: 17:51 - 29 Mar 2006    Post subject: Reply with quote
Maybe it's what you use to wash the bike.
The water must have got in from somewhere, pressure washer or hose just at the wrong spot.
Tou could also do with maybe a small squirt of WD40 into the relay connection to get rid of the rest of the water.
alains
PostPosted: 20:04 - 29 Mar 2006    Post subject: Reply with quote
put the relay in a plastic freezing bag
tonyyzf
PostPosted: 23:51 - 29 Mar 2006    Post subject: Reply with quote
which as a result will raise the battery voltage, therefore increasing power in the whole system allowing the flasher relay to operate.
short1uk
PostPosted: 09:04 - 30 Mar 2006    Post subject: Reply with quote
Oh wicked idea will do!
I havent actually washed my bike since I bought it! Bit bad I know. I was looking at the chain when I was putting my chain on last night. Should I be oiling it? Havent done it yet. If so what oil should I use? Can i use the synthetic chain lube that I bought from Halfords for my peddle bike? Of does it have to be a special one?
Thanks for all your help so far guys
Cath
Mr.Everready
PostPosted: 13:26 - 30 Mar 2006    Post subject: Reply with quote
Yes you should lube your chain. I think the guide is roughly every 2-300 miles but get used to putting it on often. even more if you've been out in wet weather.
veeeffarr
PostPosted: 14:09 - 30 Mar 2006    Post subject: Reply with quote
Unless your chain is fully enclosed, like mine is Thumbs Up Laughing Thumbs Up
Mr.Everready
PostPosted: 14:19 - 30 Mar 2006    Post subject: Reply with quote
How does that work ?
Surely a chain should be lubed one way or another if it's enclosed or not ?
veeeffarr
PostPosted: 14:57 - 30 Mar 2006    Post subject: Reply with quote
Yeah but doesnt get fucked by rain.
crazvy
PostPosted: 06:19 - 15 May 2006    Post subject: and you shood clean the chain, too Reply with quote
they recommended me a teflon chain lube
my bike stoped flashing a several times after driving in the rain
so it's from the water
drive safe Smile
sunbear
PostPosted: 09:18 - 15 May 2006    Post subject: Reply with quote
I had this problem with my RS, and found it was as simple as a loose wire to one of the indicators. Check that Thumbs Up
Bikes had : BMW F650, suzuki tr50, gt125, SV400, GSXR600 SRAD. Honda CBR900RRP, CBR600FX, CBR1000F, VT600, Transalp 600, mtx125, nsr125r, CB500T, Yamaha fy50, tzr125, tdr125, XV535, Diversion 600, Fazer 600, TDM850 MK1 & MK2, Majesty 400, XV 1100. Cagiva mito evolution, Aprilia rs125, Piaggio x9 125. DNA 125 . Suzuki Bandit 600, GZ125 Marauder, RF600 , RF900RS2, Kawasaki ZZR400, ZX6R Ninja, ZZR600 . Ducati 750 Sport . Triumph Tiger 955i. CURRENT : 2004 Kawasaki Z750 and LOVIN IT !
The last post was made 20 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.89 - MySQL Queries: 16 - Page Size: 100.15 Kb
