Lithuim Based High Melting Point Grease
veeeffarr
PostPosted: 13:22 - 04 Apr 2006    Post subject: Lithuim Based High Melting Point Grease Reply with quote
Bought a massive tub of this shit for applying to nuts, threads etc.
Is this an ok use for it? What else can I use it for? says I can pack bearings with it too.
Toby
Bendy
Mrs Sensible
PostPosted: 13:38 - 04 Apr 2006    Post subject: Reply with quote
Copper grease would be better for your nuts, I reckon.
Only thing my LM grease has been used for is bearings and de-squeaking my rowing machine.
veeeffarr
Bugger,
I was torn between that and copper as well.
Bah,
It'll do.
mr.z
PostPosted: 13:39 - 04 Apr 2006    Post subject: Reply with quote
This stuff is pretty general purpose (aka general purpose high melting point grease).. i put it on springs (like on brake switch, stands, pivots on pegs, after a really good clean it gets reapplyed!
Copper grease is whats best for threds...
veeeffarr
PostPosted: 13:41 - 04 Apr 2006    Post subject: Reply with quote
It'll be better than keeping threads dry though won't it?
I've been applying it in generous amounts to my rearbrake spring/centrestand spring and anything else that i can find that's a bit creaky.
mr.z
PostPosted: 13:53 - 04 Apr 2006    Post subject: Reply with quote
Personally i put it on springs and anything that might get eaten by road salt or get crunchy (even the underside of the swingarm) but thats just me, it needs washing off and reapplying every month or so, but underneeth is allways spkarkley clean...
Haveing copper grease on threds makes it easyer to get them appart next time and acts as a barrier to oxsidation/rust
Guest
PostPosted: 14:03 - 04 Apr 2006    Post subject: Reply with quote
Oh yes. Use it sparingly though - I tend to dip the bolts on the tub of grease and then wipe the excess off just leaving a little in the threads. It's a lot better than fitting them dry as you say.
I recently had to dismantle some outside switchgear at an old power station. It had been up about 60 years and been painted every ten. Once the paint was chipped off the nuts (two inches across the flats) one good belt on the spanner and they could be spun off by hand - the original fitter had greased them well when he erected the gear. If he was still alive I'd have liked to buy him a beer or three Thumbs Up
veeeffarr
PostPosted: 16:15 - 04 Apr 2006    Post subject: Reply with quote
Hi,
Thanks for the advice,
Glad I got it Smile
Toby
map
Mr Calendar
PostPosted: 18:01 - 04 Apr 2006    Post subject: Reply with quote
Just to clarify. Is this Molybdenum paste were talking about or something else?
Thanks.
veeeffarr
PostPosted: 18:04 - 04 Apr 2006    Post subject: Reply with quote
Thanks.
No idea, I'll post when I get home.
Comes in a blue can with black lid, about a fiver from motorworld, looks like vaseline.
nrml76
PostPosted: 20:26 - 04 Apr 2006    Post subject: Reply with quote
Smear it on your chain before a long ride. Excellent lubricant, lasts for weeks and does not fling. You will have to degrease the cain every few months and reapply, to reduce build up of crap. Works better than any fancy lubricant. Afterall, that is what the manufaturer puts inside the chain.
veeeffarr
PostPosted: 01:53 - 06 Apr 2006    Post subject: Reply with quote
Can always use it for sexing the GF too
veeeffarr
PostPosted: 01:30 - 19 Apr 2006    Post subject: Reply with quote
Sorry to bump this up..
But the grease is "Carlube LM-2 Multi Purpose Grease".
Is this Molybdenum paste?
Thanks,
Toby
mr.z
PostPosted: 01:37 - 19 Apr 2006    Post subject: Reply with quote
A super high melting point lithium based grease which ensures smooth performance wherever greasing is required.
https://www.pattersons.co.uk/categories/2512.html
Google is your friend Wink
https://www.webelements.com/webelements/elements/text/Mo/key.html
Molybendum is a completely different sorta stuff..
I'd not let it worry you too much, any lube will be fine, use chain lube on chains, cable lube on cables and multipurpose lithium on sidestands and springs and stuff..
PostPosted: 01:39 - 19 Apr 2006    Post subject: Reply with quote
High molybdenum disulphide grease is black in colour and is for use in high-load, low speed applications (eg metal on metal). Also excellent for damping springs
Lithium/ LM grease is usually off-white in colour and is for use in lower load, high speed applications such as wheel bearings.
Copper grease is copper coloured is an anti-seize, anti-squeak compound for use on the back of brake pads and on scrwew threads.
So, I would use moly grease on my headstock bearings, LM grease in my wheel bearings and copper grease on my brake calliper sliders
veeeffarr
PostPosted: 01:47 - 19 Apr 2006    Post subject: Reply with quote
So is LM any good for screw threads and random springs?
It says 'do not overpack bearings' on the tin so I gather you can use it for bearings Smile
Might stick my knob in it later if it's no good.
PostPosted: 01:56 - 19 Apr 2006    Post subject: Reply with quote
It is not designed for screw threads as such but would be better than nothing, as would pretty much any form of lubricant.
Same applies for springs, moly grease would be better but it should do the job well enough.
It could cause a nasty dermatitis on your knob, vaseline would be more appropriate in this application.
veeeffarr
PostPosted: 01:59 - 19 Apr 2006    Post subject: Reply with quote
Cheers for the advice stink, I'll use it on threads and springs til I can get some decent shit...
Paid a fiver for the tub as well, Motorworld are robbers.
The last post was made 20 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.4 - MySQL Queries: 16 - Page Size: 102.67 Kb
