| Teaman |
 Teaman World Chat Champion
 Posted: 20:45 - 03 Apr 2006 Post subject: my breaks are squeeking and it annoying |
right then
breaks were squeeking,
fitted new pads,
sprayed with break and chain cleaner
wiped with thinners, , ran emery paper on pads,
copper grease on rear of pads and all bolts
checked bobbins,
checked the bolts that hold the disks to the wheel
the fuckers still squeek,,,,
any ideas?
ZZR1200 02 ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them. |
| veeeffarr |
 veeeffarr Super Spammer
| Ste |
 Ste Not Work Safe
| mr jamez |
 mr jamez World Chat Champion
| Teaman |
| meooo |
 meooo Nova Slayer
| kawakid |
 kawakid World Chat Champion
| nrml76 |
 nrml76 Brolly Dolly
| BigChris |
 BigChris Spanner Monkey
| Teaman |
 Posted: 22:49 - 04 Apr 2006 Post subject: |
doen all of the above,
pads have vertical line,
wiped disks with cleaner, and sprayed bobbins with it,
disks squeek every now and again now, depending on how hard I break,
they shut up for a while then start again.
and a note to toby,,,,
fuck off cos next time I sneak up on you to slap you round the head you WONT hear me coming ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
| G |
 G The Voice of Reason
 Posted: 09:47 - 05 Apr 2006 Post subject: |
First off, can I be the first to say it's 'brakes' .
I would go with ste's suggestion of the tooth brush.
Get the pads out, push the pistons out a bit (make sure they don't pop out ). Then clean the pistons. Ideally I believe you should apply rubber grease to the pistons before you push back in.
Also apply copper grease to the pins which the pads slide on, if you're haven't. |
| Bendy |
 Bendy Mrs Sensible
| finpos |
 finpos World Chat Champion
| Teaman |
 Posted: 12:26 - 08 Apr 2006 Post subject: |
I like bendys Idea tbh.
right then, done all of the above, even took it to the bike shop, the disks are not warped, checked em with a clocking tool, they squeek constantly if you hover over the brake and push the bike forward yet they done when pushing it backwards.
the brake disks also get stupidly hot after braking, but then they dont squeek as often.
The pads are sports touring and Ive been told they are a harder compound, and Ive been recomended to buy some organic compound ones. These are supposed to give you a slightly more progressive braking force and shouldnt squeak. £30 for the pair made by EBC. also been looking at ferodo. the reason I bought Carbone Lorraine is because I can get mine at trade. ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
The last post was made 20 years, 188 days ago. Instead of replying here, would creating a new thread be more useful? |
