| veeeffarr |
 veeeffarr Super Spammer
 Posted: 17:14 - 20 Apr 2006 Post subject: 2001 CG125W - Removing Front Wheel? |
I'm not brave enough to remove the back yet, but I want to get the front off so I can have a look at the brake system... (Theyre caked in road salt and crap on the outside, and I want to give it a damn good clean, and also inspect/clean the wheel spokes thoroughly etc)
- Is it ok to make a stack of telephone books/whatever under the front of the engine block to keep the bike upright?
- Do I need a torque wrench to refit it?
- Are there any crush washers/etc that I need to renew if I take the brake system apart?
Can I grease the whole thing up with LM grease?
- Is it going to be hard? I've got a workshop manual but I think taking it apart will be pretty much common sense.
- Can I use autosol on the metal parts after I've removed all the road shit from them? Or is this too harsh?
- Should I take the drum apart while I'm at it?
Thanks,
Toby
| Nath |
 Nath World Chat Champion
| veeeffarr |
 Posted: 17:40 - 20 Apr 2006 Post subject: |
Hi, I've only got a 3/8 ratchet, but it's on a very short handle, so hopefully I'll be ok
I can't get hold of a torque wrench/can't afford one, so I'll have to do it up by hand, the nut on the back wheel is still secure so it's all good! |
| veeeffarr |
| Guest |
 Guest Brolly Dolly
| Rit |
 Rit Trackday Trickster
 Posted: 09:35 - 21 Apr 2006 Post subject: |
The spindle should have a hole the other side so that you can pop a bar through. Phillips screwdriver will do it but you'll need to ask him if you can borrow it
At least if its spinning it aint stuck Unscrew the nut a a few turns then tap the nut to push the spindle through. Keep doing that, when you have no thread left. Take off the nut and you should be able to pull the spindle through with the screwdriver.
Note any bits that fall. May be a spacer on the rhs. ____________________ You watching this rubbish?
Naaaa, switch over, Neighbours is on in a minute!
www.ritzbitz.co.uk |
| carvell |
 carvell Scuttler
The last post was made 20 years, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
