| malagutidan |
 malagutidan L Plate Warrior
| mr.z |
 mr.z World Chat Champion
 Posted: 13:44 - 01 May 2006 Post subject: |
You want my advice.. if its running leave it alone, no significant power gain can be made with filters and pipes unless its restricted somehow
At best it will run like shart, at worst it will run too lean, seize and spit you off into oncomeing trafic.. to make it run propperly it will need a profdessional to do it, £200 your looking at minimum, £500 would get you a bike that will be much faster (something like a ratty nsr, they will do 80 on a good day)
Keeping it well maintained, feeding it the best fully synthetic oil and (maybe) decokeing the engine will keep it at its potential ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Zimbo |
 Zimbo World Chat Champion
| Misc |
 Misc World Chat Champion
| Makaveli_Rydah |
 Makaveli_Rydah Could Be A Chat Bot
 Posted: 17:18 - 01 May 2006 Post subject: |
Yup ! as said above - if you fit an open filter you will need to upjet the carb .
I think the malaguti's use the horizontal minarelli engine ( same as mine ) and to be fair they're tempremental at the best of times .
If you just whack a filter on it is going to make your bike a lot worse - it will bog down from pull off for a start and ruin the carb mix !
Not worth it mate  |
| www.125power.com |
 www.125power.com Crazy Courier
 Posted: 23:49 - 01 May 2006 Post subject: |
I had an aerox 100 (minarelli horizontal) fitted a conical steel mesh filter quite similar to the k+n ones went up 3 jet sizes and it didnt half go! had to change roller weight to suit the new power band though (i think the max power moved up a couple of 1000revs), Still you gotta change the mix to suit the weather (or it will run w*nk) and the initial setup took me nearly 3 hours (get idle burning right and it knocks mid out-get mid and idle right top has gone etc etc)
DONT FIT IT ____________________ My eBay Items |
The last post was made 20 years, 165 days ago. Instead of replying here, would creating a new thread be more useful? |
