name that noise
mirax
PostPosted: 17:43 - 02 May 2006    Post subject: name that noise Reply with quote
what the hell is making this noise of my vfr400 (the ticking noise you can hear) or do all of these bikes do it. the bikes running ok apart from a bog down if you fully open the throttle from first (gudders a bit) while doing this, apart from that its ok. note the carb hunting tho.
please help its driving me Evil or Very Mad
McGee
O RLY?
PostPosted: 17:44 - 02 May 2006    Post subject: Reply with quote
Valves need adjusting ?
Its pronounced Jixxer!
map
Mr Calendar
PostPosted: 17:47 - 02 May 2006    Post subject: Reply with quote
Can't listen at the moment.
However, the symptoms you describe I'd be thinking tapet (i.e as McGee said, valve) adjustment plus syncing the carbs.
craigs23
Mr Muscle
PostPosted: 17:48 - 02 May 2006    Post subject: Reply with quote
Exhaust leaking near the headers?
Shaun
Likes 'em bent
Might not be the valves, might be the exhaust headers tapping, are the downpipes in good condition?
0ddball
PostPosted: 18:08 - 02 May 2006    Post subject: Reply with quote
Sounds like valvetrain noise. It is in time with engine revs. A leaking exhaust joint noise tends to match throttle position.
mirax
PostPosted: 18:11 - 02 May 2006    Post subject: Reply with quote
its def not the rear section of the exhaust as ive had a new rear section fitted the noise seems to come from the top middle of the engine
map
Mr Calendar
PostPosted: 18:19 - 02 May 2006    Post subject: Reply with quote
mirax wrote:
...seems to come from the top middle of the engine
You mean where the valves are Wink Very Happy.
Seriously, could you describe the noise as ticking - like a sewing maching?
(I have now listened and can't really tell on the poor PC speakers).
If so then I'd go with valve adjustment.
tony532
PostPosted: 18:21 - 02 May 2006    Post subject: Reply with quote
my old gsxr400rrsp made a similar noise when i had a hole in the downpipes
my mechanic said the noise i could hear was one of the pistons.
ram_doom
PostPosted: 18:26 - 02 May 2006    Post subject: Reply with quote
Omg that video is like seeing from the viewpoint of some mutant killer b-movie bee's flying around trying to get into the fairing... Shocked
I'd go with valve clearance's
TL1000s, KDX200
geordiecbrblo...
PostPosted: 18:37 - 02 May 2006    Post subject: Reply with quote
Hmmmm does the noise alter if you pull the clutch in and rev? Confused
mirax
PostPosted: 20:30 - 02 May 2006    Post subject: Reply with quote
the noise accures with the clutch engaged or not
Flip
PostPosted: 20:48 - 02 May 2006    Post subject: Reply with quote
Don't think that's clutch rattle if that's what you mean.
I vote for the valves.
Whosthedaddy
PostPosted: 21:03 - 02 May 2006    Post subject: Reply with quote
Laughing Thumbs Up Was thinking Blair Witch myself Wink
Noise is'nt too disimilar from the noise of my, god rest her soul, late ZXR before it got all fooked up.
Arrow Tip, if this noise still persists, dont under any circumstances rev the fuck out of the engine Wink
NSR Mick
PostPosted: 21:11 - 02 May 2006    Post subject: Reply with quote
I'd go with valves too, does the VFR have quietening gears in the cam train as its a performance mod to remove them although I've never heard one with them removed the are supposed to make more noise.
cagiva gezzer
PostPosted: 21:21 - 02 May 2006    Post subject: Reply with quote
Sounds like the starter isn't disengaging and it's being spun up. Other than that, i thought my bike sounds comical!
On that note, never put "comical" into google images search.
Question
I'd like to point out that i don't work on four strokes. Thumbs Up
Flip
PostPosted: 21:33 - 02 May 2006    Post subject: Reply with quote
LOL @ that first pic.
mirax
PostPosted: 22:06 - 02 May 2006    Post subject: Reply with quote
supose yeah does sound a bit like a sewing machine at times Confused
would the valve cause the bike to hunt ???
rofl at that pic Laughing
McGee
O RLY?
PostPosted: 22:08 - 02 May 2006    Post subject: Reply with quote
Dunno, does the valve have a gun Confused
mirax
PostPosted: 22:17 - 02 May 2006    Post subject: Reply with quote
Rolling Eyes Wink 12 bore i think ,
no seriously if the valves need adjusting would it cause the bike to rough idle?
McGee
O RLY?
PostPosted: 22:19 - 02 May 2006    Post subject: Reply with quote
Not related but I got a mitsibushi colt which valves are all messed up, it wont idle tidy and it wont pull of tidy, shudders not matter how much throttle you give it.
Also gets sh*tty mpg Confused
So maybe that is the proplem like I said earlier or your down pipes are farked.
How many miles has your bike got and has it had a major service and had them adjusted ?
mirax
PostPosted: 22:28 - 02 May 2006    Post subject: Reply with quote
Not sure when they were last done, ive had the bike a year now and its done 36,000km (22 369 miles). its been doing it for a little while now havent had time to sort it as it my only for of transport to work. but i really need to get to the bottom of the cause before it becomes a problem Sad might see if i can pop down to honda tomoz and let them have a listen Confused
Whosthedaddy
PostPosted: 22:29 - 02 May 2006    Post subject: Reply with quote
Na, its because its a shitty car Laughing
tony532
PostPosted: 00:21 - 03 May 2006    Post subject: Reply with quote
who fitted new downpipes?.
did you put new washers on?.
the bike bogging down when you pull away is the same problem i had.
element
PostPosted: 02:01 - 03 May 2006    Post subject: Reply with quote
that noise sounds scarily like my speedy 100 at the minute Shocked .. Ill record a sound and post it up tomoz cos its really pissing me off now since I cant find out what it is.. Very unlikely to be the same problem since my bike has nothing to compare against yours.. My bike has also feels like its lost a little power in the mid-range since ive replaced a worn belt and rollers in an attempt to cure the noise but that could be answered by the fact the rollers are heavier and the old belt im starting to wonder if it actually was a kevlar one... Im starting to think its worn/dry crank bearings else the clutch or piston is the only thing left that is constantly moving Confused .. Hoping its not the crank bearings but Im guessing Id know if it was?
could you describe it as shaking a bearing in a full spray can?
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
The last post was made 20 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.84 - MySQL Queries: 16 - Page Size: 137.98 Kb
