Running an old DOS program in XP
Mr.Everready
PostPosted: 16:58 - 09 May 2006    Post subject: Running an old DOS program in XP Reply with quote
I've just received our new PC at work and transferred some of our files over.
We have a program that runs in DOS that we need to get to work. Does anyone know how to set it up and get it running ?
veeeffarr
PostPosted: 17:12 - 09 May 2006    Post subject: Reply with quote
Sorry to sound stupid, but have you tried running it yet? If so, what happens?
Jamie.
PostPosted: 17:22 - 09 May 2006    Post subject: Reply with quote
I bet its a 16-bit application for some kind of accountancy / customer receipt things?
16-Bit programs never seem to work properly in windows xp, When im building the computers in work i always use windows 98/2000 for these applications as they are a lot more stable
thx1138
PostPosted: 17:31 - 09 May 2006    Post subject: . Reply with quote
partition your hard-drive,and install W98 on the partition to run the DOS progs?
Mr.Everready
PostPosted: 17:41 - 09 May 2006    Post subject: Reply with quote
Just to clear up a few things.
this is an old program that initially was run on a machine running Windows 3.1 Laughing
The last pc was Win98, which obviously still works. There is not a .exe file to get it to run. It was set up with a quick launch icon.
So I assume there must have been some command to get it to run.
When I right click the icon it has command line C:\F.BAT the MS DOS name is FISHSE~1.PIF
How do I find out how the program is running ?
Jamie.
PostPosted: 17:47 - 09 May 2006    Post subject: Reply with quote
Ahh, as I suspected, old program Sad
go onto the old computer, click start then run, Type C:
find "F.bat" and couble click it, if it opens and the program works fine simple copy that to your new computer and "see" if it works, but I doubt very very much it will, asl ive said we always use older versions of windows for dos programs
veeeffarr
PostPosted: 17:48 - 09 May 2006    Post subject: Reply with quote
PIF is a a shortcut to an MSDOS application.
a BAT file is a series of MSDOS commands that are processed in order... Like this
"@echo off - stops printing to the dos box
echo Hello - prints hello in the dos box
pause - pauses display"
If you go to your C:\ Drive... Is there a file there called F.BAT?
If so, open F.BAT, copy the contents, and paste it up here.
Mr.Everready
PostPosted: 17:56 - 09 May 2006    Post subject: Reply with quote
Right I've found the F on C:
It's a MSDOS Batch file
If I click on edit it says
BTRIEVE
CD TASP
TAS MO
cd\
MENU
brieve,tas and tasp are applications in the folder of the program that I'm trying to run.
veeeffarr
PostPosted: 18:00 - 09 May 2006    Post subject: Reply with quote
You need to create a new folder, copy the Brieve, Tas and Tasp directories into it (Plus any others that are in the same folder as Brieve, Tas and Tasp).
Put F.bat into the new folder, and run it.
So you have.
C:\NewFolder\TAS
C:\NewFolder\TASP
C:\NewFolder\BRIEVE
C:\NewFolder\F.BAT
m99dws
PostPosted: 19:52 - 09 May 2006    Post subject: Reply with quote
Just use DosBox
https://dosbox.sourceforge.net/news.php?show_news=1
mattfuzzy
PostPosted: 01:21 - 10 May 2006    Post subject: Reply with quote
windows xp doesnt use Dos like older versions of windows did, it uses something else instead which is pretty much the only thing that seperates it from other versions of windows.... and yet windows still sucks... anyways as for shortcuts and stuff and batch files.... i wouldnt even bother unless you have a good mind for figuring things out and stuff... sounds like you only got half the program in the first place, unless alot of money depended on it id just blow the thing up or something Laughing
Fortuna
PostPosted: 13:49 - 10 May 2006    Post subject: Reply with quote
I agree with DOSbox. Very good program.
Mr.Everready
PostPosted: 16:18 - 10 May 2006    Post subject: Reply with quote
Just tried DOSbox but an error comes up when I got to print. Rolling Eyes
Jamie.
PostPosted: 16:27 - 10 May 2006    Post subject: Reply with quote
Whats the errors?
Mr.Everready
PostPosted: 17:12 - 10 May 2006    Post subject: Reply with quote
Please check your printer - there is a problem Line #58
How do you go about adding a partition on the new drive ? I think this might be the way to go. I've been into management and if I right click the drive the option does not come up.
Jamie.
PostPosted: 17:28 - 10 May 2006    Post subject: Reply with quote
Say if the disk is 100gb, and there is already a partition on it at 100gb. Then you cannot make another unless you use a program called "partition magic" But ive never used it so I cant say anything there
Marci
PostPosted: 14:07 - 12 May 2006    Post subject: Reply with quote
Use/Download/Find/Buy VMWare to setup a dos virtual machine. This then maps in printer support via windows and should elliminate any printing issues you're having.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
The last post was made 20 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.42 - MySQL Queries: 16 - Page Size: 94.27 Kb
