Handle Bar Grips...
zxr-rob
PostPosted: 18:19 - 14 May 2006    Post subject: Handle Bar Grips... Reply with quote
So i've ordered some new handle bar grips, I thought I would ask the best and easiest way of putting them on? I remember my dad changing his grips about a year ago (there was a lot of swearing from the garage)
ZXR400L - Pocket Rocket
Maidstone, Kent
Rookie
PostPosted: 18:25 - 14 May 2006    Post subject: Reply with quote
Bar ends off, obviously, pull or cut the old grips off, and lube up the handlebar with a small amount of washing up liquid, if it needs it. They will be slippy on the handlebars for a little while, but then they'll bind onto the handlebars and they're sorted.
syl
PostPosted: 18:52 - 14 May 2006    Post subject: Reply with quote
Hairspray, apparantly. Slippery when wet but helps the new grips stay on when dry.
Same for getting the old ones off - or use an air hose.
Current bike: Kawasaki Z750S
phantomtek
Lil Joe Tek
PostPosted: 18:54 - 14 May 2006    Post subject: Reply with quote
Use petrol to put them on. Just a small amount though.
zxr-rob
OK thanks guys, will try that soon. I've heard of the washing up one but not the hair spray.
Maidstone, Kent
ram_doom
PostPosted: 19:03 - 14 May 2006    Post subject: Reply with quote
Hairspray method worked for me Mr. Green
TL1000s, KDX200
KLR600
PostPosted: 19:17 - 14 May 2006    Post subject: Reply with quote
The best stuff I've discovered that works for this (I work in a mountain bike shop) is the rubber solution in mountain bike puncture repair kits. Put a bit on the bar and a bit in the grip and twist the grip when you put it on so it goes all over the bar and it'll set really well and won't budge in the rain. (You have to be quick and do it before the rubber solution goes off though!)
But saying that, the twisty throttle body thing on a motorbike is plastic so I don't know if it'd be as good but I do know it's the best stuff I've used for mountain bikes.
HTH
<Take Cool Photos!>
PostPosted: 20:56 - 14 May 2006    Post subject: Reply with quote
Another vote for hairspray.
Best way to get the old ones off it to cut them off with a stanley knife.
proximity
PostPosted: 21:04 - 14 May 2006    Post subject: Reply with quote
I want my heated grips off but i dont want to ruin them.
I think Its a plastic inside and i had to hammer them on it was really tight, any idea how to get those off?
The only way i can see is by using force but it will just break the slider.
2004 Aprilia Tuono
PostPosted: 21:10 - 14 May 2006    Post subject: Reply with quote
See if you can slide the straw from a WD40 can between the grip and the bar. Then give it a healthy scoosh. If the grip has a solid end, make a hole in it to break the vaccuum.
proximity
PostPosted: 21:22 - 14 May 2006    Post subject: Reply with quote
Unfortunatly the inside of the grip is just a solid plastic tube so there will be no vacuum, i think its just been stretched over the slider by me hammering it.
Is there any really penetrating stuff that might get in even though its tight.
2004 Aprilia Tuono
tonyyzf
PostPosted: 22:14 - 14 May 2006    Post subject: Reply with quote
I've heard of someone using paint, works the same as hairspray I suppose
syl
PostPosted: 22:40 - 14 May 2006    Post subject: Reply with quote
Use an air hose to shove air under pressure between the grip and the bar. It'll act a bit like a hovercraft and slide off easily, so I'm told.
DukeRed
PostPosted: 01:53 - 15 May 2006    Post subject: Reply with quote
Have you tried turning them on to full power and trying it then?
I've tried to get heated grips off twice and have had no luck without breaking them. If you're fitting other heated grips I would say only glue the one on the throttle tube so you can take the other one off.
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
spinglass
PostPosted: 09:55 - 15 May 2006    Post subject: Reply with quote
I have used air pressure and it works just fine.
Hair spray seems promising, as it should work as some kind of glue when dried up.
But in any case DO NOT use any kind of lubricant even in small quantities
An n-dimensional array of elements in which the orientation of each element influences the preferred orientation of its neighbors.
Simple
PostPosted: 13:24 - 15 May 2006    Post subject: Reply with quote
My dad just pulls them off and pushes em on,
but thats what you get for being a farmer type - oo ar Wink
beware when pulling the throttle grip off that it may be glued on, and that you may rip the throttle body off if you share heman tpe strength like my dad Rolling Eyes
washing up liquid... isnt that bad for rubber? Confused
Insta - FemFeral
syl
PostPosted: 14:17 - 15 May 2006    Post subject: Reply with quote
What do they make washing up gloves out of?
Simple
PostPosted: 14:21 - 15 May 2006    Post subject: Reply with quote
Yes
but there are many additives that can be added to a compound (tyres are a good example of this)
I thought washing up liquid was bad for cellulose based paints/finished and rubber.
Insta - FemFeral
Cillit-BANG
PostPosted: 17:08 - 15 May 2006    Post subject: Reply with quote
I've always been pro hair-spray but last time I used it, it was crap. It's possibly because it was still quite cold and wouldn't evaporate properly. After 2 days the grip was still spinning on the throttle side. I whipped it off, cleaned it, rubbed some white spirit in it, popped it back on and within 5 mins it had dried out and was stuck solid.
OFF Arrow Slip under thin screwdriver blade, then push wd40 tube alongside. Spray and twist. Easy.
ON Arrow Clean off any residue from bars, lube grip with a drop or two of white spirit, slide on, wait 5 mins.
The last post was made 20 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 16 - Page Size: 105.06 Kb
