Boiler primary flow ploblem
crazymotorbik...
PostPosted: 11:39 - 19 May 2013    Post subject: Boiler primary flow ploblem Reply with quote
Hi,
Before I begin I'll point out at no point would I touch the gas side of my boiler. I maybe soft but I'm not daft Very Happy
Started having a problem recently were my Halstead boiler (piece of crap I know) locks out as it hasn't detected a flow. Looking inside I noticed that the plunger which pushes the primary flow microswitch is very sluggish. When water has been run and the plunger is extended it retracts very slowly when the hot water tap has been turned off. Sometimes it doesn't retract fully so the microswitch contact isn't broken.
I replaced both the diagrpphams, gland nuts and microswitches over 3 years ago and have had no problems since (besides the secondary heat exchanger which regularly furs up.)
Prior to this problem the pump made a very loud noise one night as if it were stuck or struggling. Not sure if this maybe related.
Any suggestions as to what the problem may be?
crazymotorbik...
PostPosted: 11:53 - 19 May 2013    Post subject: Reply with quote
Sorry wrong section.. darn my fat fingers...
please can someone move this
calyx
PostPosted: 19:43 - 19 May 2013    Post subject: Reply with quote
I would start with bleeding the pump.
Actually I am lying. I would start with buying a Viessmann boiler.
And I agree with moving the thread idea Laughing
Boris - London
L4Isoside
PostPosted: 20:41 - 19 May 2013    Post subject: Reply with quote
So is the problem with heating or hot water? You say primary flow but then mention what sounds like a diverter valve with a plunger pushing a microswitch for domestic hot water.. ?
If it is the diverter valve for the domestic water, providing its the type with a diaphragm pushing out a pin making a microswitch, it could well be that it's self which is causing a problem. May be struggling to push in/ out, meaning the boiler may not see a demand for hot water and possibly mean that it's sends it heat around the plate heat exchanger rather than the central heating flow?
Just an educated guess I do not know the boiler exactly.
The last post was made 11 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 39.36 Kb
