Unseizing Brakes
BikeRdean
PostPosted: 22:20 - 06 Apr 2017    Post subject: Unseizing Brakes Reply with quote
Firstly, I came off my 2001 SV650s in January. It sat in a car park, uncovered up until now. I've just managed to get it back and it appears that the brakes are quite seized though I'm no expert.
I don't really have the money to take this to anybody to get it sorted, so I'm looking for any hints on what's the best way to go about sorting it myself.
In the past I have changed my break pads and brake shoe on both my old CBF125 and GPX250. I did oil and filter changes on both too and spark plugs.
Any help or advice would be great, also any tools that might help as I'll need to putt them on a shopping list due to a lack of them.
Thanks in advance
Isj0321 This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
PostPosted: 22:29 - 06 Apr 2017    Post subject: Reply with quote
The front calipers are twin piston sliding calipers. The pins they slide on can seize, and the pistons can seize. Personally pump the pistons out (carefully as you want them to come out at the same time - at least for each pair on a caliper to come out at the same time). Take the seals out carefully. Clean up thoroughly behind the seals and clean the pistons thoroughly. Take the caliper off the pins it slides on. Clean them up and lube them. Reassemble the calipers (if you are at all unsure about the seals then replace them with new ones). Lube the seals with either brake fluid or red rubber rubber grease.
Rear caliper is probably the standard Suzuki nightmare. The pins that hold the pads seize in place. If you can get that out then pump the pistons out. With these you do have the option of pumping out the inner piston first, and pushing out the outer piston through the banjo bolt hole.
Katy
PostPosted: 22:36 - 06 Apr 2017    Post subject: Reply with quote
if you just need to move the bike and arem't planning on riding it, just belt the callipers side on with a rubber mallet.
you'll have to do it after every application of the front brake....
iooi
PostPosted: 06:21 - 07 Apr 2017    Post subject: Reply with quote
Isj0321 wrote:
Remove the bolts holding them in place, remove caliper. Grab two flat screw drivers, put them one at either end inbetween your pads. Push and pull/ lever the piston into the caliper. You can pump the brake lever to completely remove the pistons to clean and grease them.
Gotta love people who post stuff like this.....
Stop dead half way through......
So with you idea OP now has to bleed the brakes.... Rolling Eyes
OP DO NOT pump right out.... Just get them far enough out to be able to get a rag behind and clean all the crud off.
A little smear red rubber grease on them once clean will help Thumbs Up
Isj0321
PostPosted: 11:55 - 07 Apr 2017    Post subject: Reply with quote
Note i wrote " you can" and for all we know it may be the best course of action, you assume the op is of low intelligence you haughty little prick
Nothing worse than a cheesy penis
PostPosted: 12:26 - 07 Apr 2017    Post subject: Reply with quote
Isj0321 wrote:
Grab two flat screw drivers, put them one at either end inbetween your pads. Push and pull/ lever the [dirty, corroded] piston into the caliper..
Good job. OP now has chewed up pads, and torn seals. Where is he sending the bill?
Isj0321
PostPosted: 12:34 - 07 Apr 2017    Post subject: Reply with quote
He recieved free advice on an open forum, i gain nothing from giving my recommendation, he must assess the quality of the information for himself and take the best course of action taking into consideration his own skills and capabilities.
Are you telling me roger, that op has damaged his brakes? In which case he should have been more careful or better yet employ the services of a mechanic. I merely offered him a method which has worked for myself, a method which, most probably many bikers and mechanics have themselves made use of.
Are you offering any advice to the op or merely criticism of the completely free, measured, considered advice i offered?
Isj0321
PostPosted: 12:37 - 07 Apr 2017    Post subject: Reply with quote
Corrosion has the property of being less structurally sound than the metal it formed from so no problems there.
PostPosted: 12:40 - 07 Apr 2017    Post subject: Reply with quote
We've assessed it for him and have unanimously reached the conclusion that you shouldn't be giving mechanical advice. Thumbs Up
PostPosted: 12:45 - 07 Apr 2017    Post subject: Reply with quote
Piston seals are made of metal, you say?
Katy's advice doesn't need anything added to it. Your, we can milk for as long as you insist on sperg raging about it.
Isj0321
Who here is "qualified" to give advice? Are you a mechanic? I personally wouldnt take the advice of a man wearing what appears to be a paper hat, a man who seems to speak for everyone.
Are you threatened by me?
PostPosted: 12:46 - 07 Apr 2017    Post subject: Reply with quote
Where d'you wanna meet?
Isj0321
PostPosted: 12:48 - 07 Apr 2017    Post subject: Reply with quote
It would be my pleasure. Im in burnley.
Katys advice preceded my own.
You are a paper hat.
Katy is as good as qualified to give advice. Thumbs Up
Isj0321
PostPosted: 12:49 - 07 Apr 2017    Post subject: Reply with quote
My advice preceded katys.
Milk me, head on down to burnley see how that goes.
Isj0321 wrote:
Im in burnley.
Are you a grown man?
Isj0321
PostPosted: 12:50 - 07 Apr 2017    Post subject: Reply with quote
Isj0321
PostPosted: 12:54 - 07 Apr 2017    Post subject: Reply with quote
Rogerborg wrote:
Isj0321 wrote:
Im in burnley.
I could be a woman for all you know.
PostPosted: 13:02 - 07 Apr 2017    Post subject: Reply with quote
Does your mother know you do this type of stuff?
Fizzoid
PostPosted: 13:03 - 07 Apr 2017    Post subject: Reply with quote
You certainly get all emotional very quickly
Rogerborg wrote: It'd certainly make it easier to ego-find my own posts on pages, given the number of fags (gay like traps) who insist on putting my name in their .sig
Isj0321
PostPosted: 13:04 - 07 Apr 2017    Post subject: Reply with quote
Irritated i would say, who are you?
PostPosted: 13:15 - 07 Apr 2017    Post subject: Reply with quote
I'm so glad I enemied the fucknut when I first came across him....
PostPosted: 13:19 - 07 Apr 2017    Post subject: Reply with quote
Eh, it passes the time until the next Aaronspurg.
Isj0321
PostPosted: 13:35 - 07 Apr 2017    Post subject: Reply with quote
Some right nasty cunts on here.
Hows the op doing? Any progress?
The last post was made 7 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.57 - MySQL Queries: 16 - Page Size: 141 Kb
