Speedo moving with revs
Paulf
PostPosted: 14:40 - 14 Apr 2017    Post subject: Speedo moving with revs Reply with quote
Honda fes 125 all ready for mot and started this morning. It did not do the usual diagnostic swing and when I rev the engine it swings like a tacho and back wheel is not moving. The last couple of things I done is put the body plastics on. Before I undo everything does it sound as a short or a f@@ked Speedo. It is an electronic Speedo.
PostPosted: 14:45 - 14 Apr 2017    Post subject: Reply with quote
Why did you remove the plastics? Which plastic? What else did you fuck about with?
Paulf
PostPosted: 14:55 - 14 Apr 2017    Post subject: Reply with quote
Basically all plastics off it had engine out for repairs. And for bodywork repairs cracks, grazed, and missing lugs, it was a spares or repairs project. Speedo was working normally a few days ago. Unfortunately I have only noticed it today so I am taking handle plastics shroud off at present that was late on in the build and most likely culprit.
PostPosted: 15:01 - 14 Apr 2017    Post subject: Reply with quote
So, did you unplug any wiring?
Paulf
PostPosted: 15:14 - 14 Apr 2017    Post subject: Reply with quote
Basically unplugged slot of connectors. Consulting workshop manual the Speedo is driven off the pink wire from Speedo to ecm and speed sensor on back wheel. So multimeter out and chase the pink wire seem best.
PostPosted: 15:20 - 14 Apr 2017    Post subject: Reply with quote
You've plugged connectors together wrong.
Paulf
PostPosted: 17:22 - 18 Apr 2017    Post subject: Reply with quote
Partly fixed the rear speed sensor was not fully clicked. Speed now does not move when driving only when rotate. However still does not do the switch on sweep. Ecu reset performed and no codes. So good to go for mot. It will lest have no codes and no fluctuating Speedo needle.
The last post was made 7 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 16 - Page Size: 52.72 Kb
