How to increase power output
cresad
PostPosted: 23:01 - 09 Nov 2017    Post subject: How to increase power output Reply with quote
Hi all
I've got a Suzuki EN125 that I'm using at the moment but the lights are rubbish , is there any way to increase the output of the generator/stator or change it for one off another model with a higher output that would do the job ?
Thanks , Adam
PostPosted: 00:11 - 10 Nov 2017    Post subject: Re: How to increase power output Reply with quote
cresad wrote:
Hi all
Thanks , Adam
Your best bet is to just ensure the headlight is clean.
Courier265
PostPosted: 00:37 - 10 Nov 2017    Post subject: Reply with quote
The bulb on the EN125 is a 35W or 40W output so there's your problem... Not a lot you can do. You could try getting a higher wattage bulb but I'm not sure that's possible.
PostPosted: 00:48 - 10 Nov 2017    Post subject: Reply with quote
It's possible. There's a good chance that you'll melt the wiring though.
You could rig up new thicker guage wires with a relay triggering it directly from the battery to the bulb but the relay would probably drain any gains on such a marginal system.
Teflon-Mike
tl;dr
PostPosted: 00:51 - 10 Nov 2017    Post subject: Reply with quote
Before looking for more than standard, make sure you have all you should AS standard...
Which is as above, basically; its a motorbike; they only have one headlamp, unlike cars that have two; you need to learn to look, not blindly track-follow; this may mean heeding highway code and riding at a speed low enough you can stop in the distance you can see to be clear.. rather than naively assuming that if the sign says 50 or 60 that's how fast you should go! This is all part of the learning to be had from a learner bike.
Beyond that its still a learner bike, and not a very new one; little bikes have little generators as that's all their little engines can spare the power to turn... you'll be lucky to get the full allotment of 9Kw that engine was designed to make from it, and probably have to use pretty much all of that power to hold a respectable road-speed.. without robbing any to turn a heftier generator.. which will only deliver 'more' power if the engine's reving out to let it make it....
Tip; avoid short shift tendencies, use revs not gears; forget you have a 5th gear, keep the motor spinning for 'response'ad give the genny best chance to make all the power it might, as well as best chance to keep battery charged, and give yourself best throttle response and likely best speed A-N-D likely far fewer and much smoother gear changes.
Continuing with the clean the lens phlosophy; check the bulb, common for folk to try putting n higher wattage bulbs looking for more brightness, and ending up with less, as genny doen't deliver the amps to light them. Make sure that what light the bulb is delivering is being chucked through the lens by a decent reflector, not one that's discoloring or starting to break down or covered in grime; make sure that the lens isn't robbing more from being chipped or etched or just plain dirty; THEN take it to your local freindly MOT man and stun them asking if they can put it on their alignment tool to point the darn thing where it should be! No point having more light if its not lighting up what you want to see!
All pretty basic stuff, but far more likely to make more real world difference, and help more than just in the dark, learning good riding and maintenance habbits, which is what little learner bikes are supposed to be about.
Alternatively... get a bigger bike, (and licence if necessary to ride it!) with beefier generator and engine with the oomph to spin it, and a headlamp with brighter bulb, and probably larger, better reflector and lens, if not two of them.. and STILL you wont see much more, unless you learn to make the most of it and keep lens clean and look where you are going, and ride at speed you can stop in distance you can see. Principles learned on learner bike, transfer directly to anything else, and learning this stuff is still what they are supposed to be about.
PostPosted: 00:58 - 10 Nov 2017    Post subject: Reply with quote
The stators on most 125s probably put out about say 80-90 watts
and it's unlikely a different one will put out significantly more so
bunging in a 100W blub is futile.
What you need from a low power stator is better efficiency so
I'd be looking at a HID or good ( not cheap instant melty shite) LED replacement.
bugeye_bob
PostPosted: 10:10 - 10 Nov 2017    Post subject: Reply with quote
Have you tried a lamp like the Osram nightbreaker? they are a big improvement over standard halogen and dont overload the wiring.
BTTD
PostPosted: 10:46 - 10 Nov 2017    Post subject: Reply with quote
Changing the headlights on my old Triumph made a massive difference. The original headlight was just a crap design and a reflector design seems to work an awful lot better. That was a few years ago, and there are far more LED headlight assemblies out there and youtube reviews of them so if I was doing it again I would be looking at those.
However, not a super cheap fix, and probably not worth it on an older 125 (save the money for the next bigger bike).
Other options:
Reduce the other loads on the system - rear lights swap to LED bulbs, gain a few watts back. Is there a front sidelight as well as the main bulb - change that to an LED as well.
Get some thicker gauge wire for the headlight to reduce the losses on the lightweight oem wiring.
Check connectors for corrosion, a can of contact cleaner costs a few quid from toolstation / screwfix etc.
PostPosted: 11:10 - 10 Nov 2017    Post subject: Reply with quote
As above, if it's a steel and glass headlight, put in a 55W techno-bulb and go LED elsewhere. If things melt, replace them.
skatefreak
PostPosted: 11:52 - 10 Nov 2017    Post subject: Reply with quote
Any thoughts on cheap, fancy ballast Xenon stuffs?
Threw a second hand set onto a 99 R1 -> huge difference!
BTTD
PostPosted: 12:46 - 10 Nov 2017    Post subject: Reply with quote
If it's going into a projector assembly which will provide a consistent cut-off, and it physically fits, then crack on.
If it's going into a standard reflector and you want to blind other road users....
Robby
Dirty Old Man
PostPosted: 00:18 - 11 Nov 2017    Post subject: Reply with quote
There are a few things that can knacker the light output of a small bike:
- Dirty glass
- Knackered bulb
- Knackered battery, so the lights are fine at high revs but crap when you're braking into a dark corner.
- Crap aftermarket light. Common on 125s where someone has tried some budget customising.
cresad
PostPosted: 01:00 - 11 Nov 2017    Post subject: Reply with quote
Thanks for all the reply’s , the light as it stands is the original 7” round unit , and all I get is an orange glow on the ground. I’ve tried the brighter bulbs and although it made it brighter it also took enough juice out of the battery so I had to charge it up every week , and there’s no kick arm on this model. The front side light is an led and I will be getting some to do the rear and dash lights. I might see if I can find a better glass / lens as it looks almost flat /clear with no molding? to the glass. The battery is less than a year old and the amount of light doesn’t change with revs. The bike gets cleaned and checked at least once a week .
I was hoping I could fit a slightly bigger generator to help with getting a brighter light , mainly due to traveling down an unlit duel caridgeway at 6 am every morning.
Thanks , Adam
PostPosted: 07:38 - 11 Nov 2017    Post subject: Reply with quote
Post hoc, ergo propter hoc?
Your battery died. Your new battery needs charged on a weekly basis.
Does anyone want to...?
OK, I'll get this one.
cresad wrote:
The bike gets cleaned and checked at least once a week.
Does this checking involve putting a multimeter across your battery terminals with the engine running? I'd suggest you do that and see what voltage you're getting, because I'll wager one Internets that it's not the 14.5V+ that you want.
smegballs
PostPosted: 09:15 - 11 Nov 2017    Post subject: Reply with quote
Things I did to improve the shit candle on the front of my GN.
Clean up the various connectors. In my case I was getting a nice 14.4V at the battery (thanks to the hardwired R/R with stupidly thick cables), but the voltage at the bulb connector was down to about 12.6V. Given the non-linear relationship between volts and brightness, lose a few volts and you lose a lots of lumens - maximising voltage at the bulb connector is the key. In my case skinny cables and 20 year old switchgear and connector blocks have a relatively high resistance and conspire to steal volts that's should be at the headlight. Clean them up as best you can.
Secondly, the biggest improvement I made was binning the shit 35w 6.5" stock headlight, that used some stupid arcane bulb design, and replacing it with the 8" h4 headlight from an old SRX400. To avoid melting said skinny wires I chucked in a 35W H4 halogen bulb.
Despite still being a 35W headlight the bigger reflector gives a much better beam pattern and you can see a lot more, with a lot more confidence now riding at night.
If I ever get the motivation, I'll put headlight relays on the bike and put on a standard H4 55/60W bulb. I've already replaced all other running lights to led so there should easily be enough headroom on the alternator.
RhynoCZ
PostPosted: 11:47 - 11 Nov 2017    Post subject: Reply with quote
OP, to get more power for your headlight, put a LED bulb into your tail light. I used generic Chinese 300lm LED bulbs on various motorcycles. These are a direct swap, emit the same amout of light as a standard double filament bulb and have only a fraction of power draw = more power for your headlight + no diming of the headlight when you use the brake light.
Copycat73
PostPosted: 13:11 - 11 Nov 2017    Post subject: Reply with quote
save your money .. pass a test and buy a bigger bike ..
125cc have always had crap lights ..
caveat emptor
smegballs
PostPosted: 14:00 - 11 Nov 2017    Post subject: Reply with quote
True to a point, but an H4 headlight and a decent 35W LED headlight would probably cost less than 80 quid all in.
Tbh given the wonderful world of modding small capacity bikes...... Upgrading the lighting is actually well towards the sensible end of the spectrum. It's achievable and gives a noticeable amount of improvement for a modest-ish cost.
Courier265
PostPosted: 14:43 - 11 Nov 2017    Post subject: Reply with quote
OR you put an H4 45W halogen bulb in.... it's better than the old style bulb used in the EN125.
Increase your tickover to 2000 revs.... that will sort the battery issue. Thumbs Up
Copycat73
PostPosted: 15:33 - 11 Nov 2017    Post subject: Reply with quote
tbh .. those LED lights fitted to bicycles are a lot better than 125cc bikes .. burn you fcken eyes out and grab your attention when they flash ... i`d just fit a couple of those on me jacket or where ever and accept that they`ll need chargin..
always sounds good in theory .. let me know how it will pan out in practice.... on a tired electrical system designed in the last dark age ...
Courier265 wrote:
Increase your tick-over to 2000 revs.... that will sort the battery issue. Thumbs Up
that will be an "interesting" modification in urban traffic .. nothing like a bit of over run if you wanna stop quick... Thinking
the issue with that is the operating temperature from a over stretched chargin system .. ie.. low voltage .. the scavenging gas will not work inside the bulb causin the tungsten fillament to burn out much quicker than normal.. you`ll have to carry a spare...
caveat emptor
smegballs
PostPosted: 16:48 - 11 Nov 2017    Post subject: Reply with quote
Well it's what I planned to do... I put on the H4 headlight that I scavenged of a mate breaking a bike....
The another mate had a spare LED H4 going, cos he bought a set of two but was only running one in his K1100. I tried out the bulb, lovely and bright, nice white color, good beam pattern...... But the heatsink on back of bulb was too long to allow the shell to mate with the lamp housing. Okay.jpg
We played with the LED bulbs on the bench power supply and they have a very wide operating voltage range compared to a incandescent. Due to the switch mode power supply, they will pull more or less current as voltage fluctuates to keep power constant. We ran one up from 0-20V and current peaked about 11V, after than it progressively dropped the current to keep the power ~30W. So I can't see a reason why they wouldn't work as a replacement for a incandescent tbh.
Courier265
PostPosted: 16:49 - 11 Nov 2017    Post subject: Reply with quote
what the fuck are you on about? My CB250 idles at 2000 revs, I can stop just fine with NO fucking over run.... Middle Finger
Copycat73
PostPosted: 17:46 - 11 Nov 2017    Post subject: Reply with quote
i`m on about you turning the tick over way beyond what it says in the book .. probably 900=1200 rpm to 2000rpm .. so your engine brakin will be less than it should..
but hey let Darwinian theory take its course Rolling Eyes
caveat emptor
RhynoCZ
PostPosted: 21:53 - 11 Nov 2017    Post subject: Reply with quote
I can't agree with that. I've had ZX7R on which the low beam was a joke. The projector was in perfect condition, I put in a fresh light bulb, ... and it was still crap. All I could see at night were the white markings on the road, the traffic signs and nothing else. Thumbs Down
If you really want a good and cheap headlight, go big or go home. CBR919RR has two huge lamps equipped with cheap H4 bulbs. That motorcycle has even better headlights than many cars on the road. On a naked bike there's nothing easier than just swaping the headlight for something larger in diamater. More powerful bulb isn't always the answer.
Faster you go, better the headlight/s should be.
RhynoCZ
PostPosted: 21:59 - 11 Nov 2017    Post subject: Reply with quote
Why would you let your engine idle at 2000 rpm? Especially with air cooled engines, you want the idle as low as it's possible and reasonable, for cooling purpose and fuel efficiency. Even with a liquid cooled engine, having the idle speed at 2000 rpm is not the best idea.
Reduced engine braking isn't really an issue. Unless you're living in a mountainous area and do a lot of descents. Cooking up your brakes si not cool, m-kay. Razz
The last post was made 6 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.54 - MySQL Queries: 16 - Page Size: 144.6 Kb
