Word of warning regarding the Abba Skylift
ADSrox0r
PostPosted: 09:59 - 19 Nov 2017    Post subject: Word of warning regarding the Abba Skylift Reply with quote
This is more a 'cooly story bro' for bants but also a tip;
Had the Zed up this weekend for service and coming to the back end of what I wanted to achieve for the day. Now, the Abba Skylift has three preset holes for different heights that you slide a big chunky pin into and drop the hydraulic ram onto for safety. Once it's 'sat' on the pin it's all good, you just pump it up once to release the pin when you want to drop it again.
Aaaaanyway, noticed the stroke on the ram was getting shorter and thought to myself I'd best top up the hydraulic fluid when I'm finished. I'd dropped the ram onto the pin with the Zed up in the air. Went to pump it to release the pin and.......fuck! Nothing. I've now got quarter of a ton stuck in the air because the pin is locked in place by the weight and the ram won't lift to release the damned thing.
Managed to get it back down after fabricobbling a jerry rigged bottle jack and a length of timber under the sump to just nudge it up in the air and release the pin. Without that I would've been royally fucked.
So, my word of advice; always check and service your hydraulic lifting gear BEFORE you get the vehicle in the air Laughing Rolling Eyes
MattEMulsion
PostPosted: 12:56 - 19 Nov 2017    Post subject: Reply with quote
The question that begs to be asked is where has the hydraulic oil gone? Do you have a leak?
Yamaha YZF-R6
nowhere.elysium
The Pork Lord
PostPosted: 14:49 - 19 Nov 2017    Post subject: Reply with quote
Oil pixies.
MattEMulsion wrote:
Do you have a leak?
No, that'd be silly.
cb1rocket
PostPosted: 21:00 - 19 Nov 2017    Post subject: Reply with quote
Didn't the whole bike come crashing down once the bottle jack was removed?
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
ADSrox0r
PostPosted: 01:10 - 20 Nov 2017    Post subject: Reply with quote
Nah, it was just air had got into the ram so needed purging but I didn't want to do it with it up in the air (although the safety pin would technically mean it's perfectly safe...but, I was tired and a little drunk). It was hydraulically sound but had obviously let air in on the stroke as it went up.
Which subsequently leads me to top tip number two; if you have a hydraulic ram or bottle jack that's not pumping up any more try a purge first. Simply open the release valve and pump it twenty times, then shut the valve off and it should just raise again. If that doesn't work then make sure the oil is topped off. And if it still doesn't raise, well you gotta strip it down and find out if either of the one way valves is farked. But nine times out of ten a simple air purge does the trick.
supZ
PostPosted: 13:53 - 20 Nov 2017    Post subject: Reply with quote
Surely the more important question is why did he decide to try to top up the fluid whilst the bike was in the air? Seems a rather silly thing to do regardless of whether 'the pin' was in or not. (For the very reason described above)
CBR954RR - Daily toy
CBR600RR - Trackbike
ADSrox0r
PostPosted: 20:17 - 20 Nov 2017    Post subject: Reply with quote
Yeah, you might want to read again. I said top up 'when I'm finished', ie. the bike is down again. I'm a drunken old fool but I'm not daft enough to start pissing about with a hydraulic ram with quarter of a ton sat on it.
Commuter_Tim
PostPosted: 20:19 - 20 Nov 2017    Post subject: Reply with quote
Did you miss the bit above where he said he was drunk?
Inebriation doesn't excuse anything but it often does explain a lot. Laughing
I ride a Bandit 600... badly.
The last post was made 6 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 16 - Page Size: 61.52 Kb
