I'm Back And Got A Problem
dolly3900
PostPosted: 20:31 - 07 Sep 2018    Post subject: I'm Back And Got A Problem Reply with quote
Hiya guys and guyettes, I've been offline for a while, change of job and far too many work commitments meaning too much time in work, nowhere near enough on bike and no time for BCF'ing.
Anyhoo, on to my reason for posting.
My lads (mentioned in previous posts), have all moved on from the trusty 125 now and progressed to various bigger bikes and cages, leaving the poor little CBF125 surplus to requirements.
I have done a bit of cosmetic refurbishment to it and, once looking pretty, it was used for a few months just to get around whilst #1 son had his 650 nicked (long story).
Since then, it has been sat in the shed, lonely and scared, but now I have someone interested in giving it a new home and the love it deserves.
Problem is that when I hit the starter button after checking the usual battery, oil, fuel, etc. the little bugger will just not start.
After testing all sorts of things, did a compression test ant it is reading bugger all, you can put your finger over the plug hole and can hold it there.
Now then, suggestions I've had are rings (would they have fallen out whilst at rest), Valves (left in the fully open position when standing and oil clogged them up to stay open).
Short of stripping the engine down, which I don't have the time for, any ideas from the massive brain and experience that is the BFC collective.
Cheers guys.
Mike
2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650
Oldie
PostPosted: 21:08 - 07 Sep 2018    Post subject: Reply with quote
Zero compression Confused
Maybe check the clutch operation?
McJamweasel
BCF Junkie
PostPosted: 22:55 - 07 Sep 2018    Post subject: Reply with quote
What does the clutch have to do with compression?
Islander
PostPosted: 23:30 - 07 Sep 2018    Post subject: Reply with quote
I wondered that too. Laughing
It could be stuck rings - try pouring a small amount of diesel into the cylinder and letting it stand for a day or two. That might free things up.
jaffa90
PostPosted: 00:16 - 08 Sep 2018    Post subject: Reply with quote
The last single cyl engine with the same issue i had was the exhaust valve stuck open.
Suntan Sid
PostPosted: 00:57 - 08 Sep 2018    Post subject: Reply with quote
If it's a valve stuck open, which sounds like a possibility, watch this video, from 14:30 :-
https://www.youtube.com/watch?v=eHLKIEGALvk
dolly3900
PostPosted: 09:54 - 08 Sep 2018    Post subject: Reply with quote
Cheers for the replies.
I've tried redex down the plug hole, but no joy, will try a bit of diesel later and see if that works.
I'll take a look at the YouTube video in a bit and see how I go.
Long time away and still the help and response does not disappoint.
Many thanks
L33n
PostPosted: 08:38 - 09 Sep 2018    Post subject: Reply with quote
Please tell me how the rings can be stuck?? If crank shaft turning piston has no choice but to move unless fully seized if this is the case the stater motor wouldn't work & would click in the sola same as flat battery so piston moving rings sit in piston witch then squash shut wen cylinder is pushed over how are these rings then stuck? Lmao absolute moroons 100000% your rings ain't stuck pal maybe worn but not stuck if bike was fully working before you've left to stand now no compression most probably is valves open although with it being ohc it should release wen oil gets round as tappets tap & springs are quite strong tbf so with luck if is valves they might release although if you haven't put bit of oil in spark plug hole & its been dry you might of scored your head & rings might be worth whipping head off take you hr tops that way can check valves & piston at same time
dolly3900
PostPosted: 10:01 - 09 Sep 2018    Post subject: Reply with quote
Re. Stuck rings.
As the bore is not a perfectly parallel cast and honed to an approximate, if the piston stopped when hot at a high point, the oil/carbon build up could make the rings stick in their groves, not against the walls, so when cool and gummed up, they'd not expand enough to take up the slacking the bore, hence no compression due to sticky rings.
Evil Hans
PostPosted: 10:04 - 09 Sep 2018    Post subject: Reply with quote
Seriously? Do you even know the difference between valves, rings and pistons?
Rings can seize in their grooves, and valves can stick open, without seizing the whole engine.
grr666
PostPosted: 10:10 - 09 Sep 2018    Post subject: Reply with quote
QFT
Islander
PostPosted: 17:27 - 09 Sep 2018    Post subject: Reply with quote
Wow. The voice of inexperience/ignorance.
The rings can and do get stuck in the grooves - old oil and carbon can cause this. Yes the piston will move but the rings will be stuck and compression would be lost. It's a common problem.
Guess who's the "absolute moroon" here then... Rolling Eyes Laughing
PostPosted: 17:32 - 09 Sep 2018    Post subject: Reply with quote
Quoted for reference... You've already made a pratt of yourself on here in another thread, so I predict either a flounce or a ban within the next two weeks...
BusterGonads
PostPosted: 19:04 - 09 Sep 2018    Post subject: Reply with quote
OP has tried oil down the plug hole with no joy, so it now looks more and more likely that he has a stuck open valve. The video posted earlier shows an interesting approach to freeing off a stuck valve without having the head off. I remember a loooong time ago riding out with mates on a borrowed 350 BSA single which had an exhaust valve lifter. I think it was a B33. Every bloody time the thing stopped the exhaust valve stuck open and I had the head off at least twice on the ride out which was only about forty miles. Fortunately the head was only held down by four pull down stud things. I don't know what they are called but these things were half way down the barrel on the outside and there were captive studs on the head pointing downwards which engaged with these deep nut / stud things. It took about ten minutes to have the head off, tap the offending valve with a screwdriver handle and 'ping' it shut. Back on and off we went again phutphut phutting down the old A69. This is about half a century ago or very nearly.
You can see the fasteners down near the bottom of the cylinder here. The one I was riding wasn't in this condition.
https://www.carandclassic.co.uk/uploads/cars/bsa/10361485.jpg
2016 Triumph Street Twin; 2000 Honda CG125; 1997 Honda Nighthawk CB250
bikenut
PostPosted: 11:03 - 10 Sep 2018    Post subject: sticky Reply with quote
Yes rings can and do stick, yes valves can and do stick, open usually, so can clutch plates and caliper pistons, a yes valves can even "TANGLE" !!!!!!!!!!
Valves on bikes ( apart from side valves ) , but not all bikes, are usually "inclined" meaning that a stuck open one will be really damaged by a rising piston. Valve, guide, head and piston in real danger, SO ALWAYS CHECK !!
So, at valve overlap,exhaust vale stuck open, opening inlet now opens and TANGLES with the stuck exhaust..........result bent valves etc.......
Valves in line with pistons may "snap back closed" by a rising piston, or as in some car engine etc. bend a push rod or break a rocker arm.......so take notice, there's a poppet.
nuts about bikes
dolly3900
PostPosted: 20:04 - 14 Sep 2018    Post subject: Reply with quote
Update.......
OK, the lad came home with his boroscope and has taken a look at the internals.
Good news, the valves are opening and closing as they should.
Fuel is getting thrown into the bore as should be.
Bad news, the piston is moving about 3mm when turned over which would suggest that there is something more or less terminal, either broken piston skirt, rod, crank or like that kind of area.
Basically we are fubar.
He's going to drop the engine, strip down, diagnose and act accordingly.
Replace parts if cheap enough.
Possibly a dropped CB? at the local scrappy with much panel damage but probably a good engine.
Will post updates as I get them.
Thanks for the pointers.
Mike
dolly3900
PostPosted: 19:47 - 23 Sep 2018    Post subject: Reply with quote
OK, so the engine has had a strip down and it's not looking too good.
Looks like the piston skirt has disintegrated and left to piston at the top of travel.
Photos to follow.
PostPosted: 20:11 - 23 Sep 2018    Post subject: Reply with quote
Fortunately I'd already enemied him/he/it within a couple of posts.
dolly3900
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/IMAG0583_zpszga8a6b6.jpg
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/IMAG0582_zpsqi9dn31z.jpg
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/IMAG0580_zpsadytidit.jpg
nowhere.elysium
The Pork Lord
PostPosted: 20:20 - 23 Sep 2018    Post subject: Reply with quote
dolly3900 wrote:
Holy shit, that's impressive.
Also, Laughing @ L33n's weapons-grade retardation.
PostPosted: 20:22 - 23 Sep 2018    Post subject: Reply with quote
dolly3900 wrote:
Fuck me.
Time to buy a new engine, there's no point trying to fix that. I dread to consider what condition the barrel is in.
dolly3900
PostPosted: 20:37 - 23 Sep 2018    Post subject: Reply with quote
Barrel does not look too bad Smile
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/Mobile%20Uploads/IMAG0587_zpskjtovs97.jpg
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/Mobile%20Uploads/IMAG0586_zps5w92tjjz.jpg
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/Mobile%20Uploads/IMAG0585_zpsix8b5vqf.jpg
PostPosted: 20:49 - 23 Sep 2018    Post subject: Reply with quote
Really? Okay? Apart from the fact it's looking incredibly worn there's this.
https://i.imgur.com/2KEy0i8.jpg
dolly3900
PostPosted: 21:02 - 23 Sep 2018    Post subject: Reply with quote
Yeah, tongue firmly in cheek when I posted.
New barrel and piston on order.
Rest of it being stripped, cleaned, checked and made sure no damage before reassembly.
dolly3900
PostPosted: 16:03 - 26 Sep 2018    Post subject: Reply with quote
So, New bits arrived this lunchtime.
Just need to have them fitted after a good clean out and check if the rest.
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/IMG_20180926_155851_zpsbfgzifci.jpg
The last post was made 5 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.45 - MySQL Queries: 16 - Page Size: 143.66 Kb
