sapstar |
sapstar Nova Slayer
Old Git Racing |
Old Git Racing World Chat Champion
sapstar |
sapstar Nova Slayer
Old Git Racing |
Weisse Schlange |
Weisse Schlange Spanner Monkey
sapstar |
sapstar Nova Slayer
Old Git Racing |
Posted: 00:04 - 07 Sep 2021 Post subject: |
Replce the nuts with brass ones. They will tend not to stick and if they do, the nut is softer metal than the stud it's on.
I think "being brutal" is bad advice. Sounds like a recipe for snapping a stud off flush with the head and they are a total ball-ache to extract if you do.
If you have access to a welder, welding another nut to the top of it is usually very effective. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
MCN |
MCN Super Spammer
davebike |
davebike World Chat Champion
Posted: 08:31 - 07 Sep 2021 Post subject: |
Use heat
Use proper penetrating fluid like Kano Kroil I use Wurth Rost off but that is trade
Soak heat try (DO NOT BREAK) repeat
Cost to do professionally Time at hourly rate + small charge fro materials from 1 hour £50 with me to several and a drilled / timesert repair may be £200 !
Exhaust studs are often a problem Hopefully pro's would have good heating I use a big propane torch or an inductive heater and proper penetrating fluid + patience! Me I hate having to drill them so am very careful ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
Fat Angry Scotsman |
Fat Angry Scotsman World Chat Champion
A100man |
A100man World Chat Champion
sapstar |
sapstar Nova Slayer
sapstar |
sapstar Nova Slayer
Easy-X |
Easy-X Super Spammer
Posted: 11:59 - 07 Sep 2021 Post subject: |
Damn... I sympathise. I've always said if I'd left my bike another season I'd probably end up in the same situation.
My nuts didn't look as crusty as yours (fnarr, fnarr!) but I still soaked them with WD40 the previous day and then blasted them with a MAPP torch. Bear in mind that this is an area of the bike than gets supremely hot just in normal running so whacking it with heat isn't going to damage anything.
Similarly hammering on your too-tight nut extractor. The mere act of hammering it on will jar the stud a bit which is a good thing. The tool, nut, stud and exhaust flange are all sacrificial. I'd say give it a go as if you fuck it up and shear it off at the head you've still got three studs to hold the exhaust on with while you ride it to the garage
"But if I fuck it up I'll have to take it to a garage!" so, err... the solution instead is to take it to a garage?! ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
A100man |
Posted: 12:02 - 07 Sep 2021 Post subject: |
sapstar wrote: | I see the consensus is to use penetrating fluids, heat and go slowly. I will get a good penetrating oil and give it a go. See attached photo. The second nut from the left is the one which is currently rounded.
I don't think I will be able to heat it enough with my electric heat gun. Will just try with penetrating oils and if I can't get it to move, I will just take it to a professional. |
I'd be very surprised if any fluid makes much difference. It will will take weeks of daily applications and only once you'ce scrubbed the rust off. ease teh nut back and forth too if you can not just one way.
Then get some brass (as suggested) or domed nuts like they used to fit. ____________________ Now: A100, GT250A, XJ598, FZ750
to v or not to v |
MCN |
MCN Super Spammer
Posted: 17:45 - 07 Sep 2021 Post subject: |
Find a single hex socket that is tight AF on the nuts.
If you can get the nuts red hot then malkie the socket over them they will come off by carefully loosening. And tightening. When you get the bastirts moving then spray with what ever Jizyou have. It's all snake oil mostly. If it lubricates and can wash out some rust it might help once you get the phukers moving.
Those nuts aren't too bad.
Waste of time and cash spraying any shite on them alone. Penetrating fluid only penetrates where there is a gap. Rust expands as it grows so plugs any gaps.
If you can't move the nuts then they're effectively watertight.
Heating and cooling might help fluid get in but time wasting.
Don't set fire to anything when heating your nuts. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
sapstar |
sapstar Nova Slayer
A100man |
sapstar |
sapstar Nova Slayer
Pete. |
Pete. Super Spammer
Posted: 15:57 - 09 Sep 2021 Post subject: |
I'd have that off in two shakes of lamb's wotsit.
Wouldn't be tking it to no bloody garage that's for sure. They might be good and get the nuts off the rusted bolts, or they might shear the bolts and wreck the head trying to drill them out.
Time will tell.... ____________________ a.k.a 'Geri'
sapstar |
sapstar Nova Slayer
Posted: 18:43 - 09 Sep 2021 Post subject: |
Got the exhaust fitted today. I was charged £70 which I thought was quite reasonable. But there are a few isssues .
The garage tells me that the exhaust is leaking where the headers connect to the engine and some gaskets need to be fitted. Got the bike back today, but will need to go back after the gaskets arrive. Also I noticed that the exhaust is slightly touching the bottom of the foot peg hanger. Need to get this sorted as well.
For now exhaust sounds too loud even with a baffle, probably because of the leakage.
Also can someone clarify if this is normal. When easing off the throttle, sometimes I hear a slight backfire. This is more obvious at slower speeds and not as noticeable at highway speeds. ____________________ First/Current Bike - Kawasaki ER-6N |
Pete. |
Pete. Super Spammer
Posted: 21:21 - 09 Sep 2021 Post subject: |
You will get popping on the over-run if your exhaust is leaking at the headers because fresh air is drawn in through the leak after every exhaust event and that allows any un-burnt hydrocarbons within the exhaust to ignite - causing the backfire. It's normal for your circumstances.
The gaskets you can get and fit yourself now that the garage has fitted the exhaust. They should have changed the rusted nuts out for new ones. ____________________ a.k.a 'Geri'
The last post was made 2 years, 270 days ago. Instead of replying here, would creating a new thread be more useful? |
