advice on midrange 'action' cams?
Fred3606
PostPosted: 09:48 - 15 May 2022    Post subject: advice on midrange 'action' cams? Reply with quote
Hi all,
I have been looking on eBay recently for 'action cams' but it seems to be saturated with a huge amount of cheaper brands.
Does anyone have any recommendations for brands/products within the 20-50 quid range (second hand)? I don't intend on vlogging or anything, just wanting to look back at anything interesting for my own entertainment but I'd still like to be able to make things out without ridiculously low res or blur. If possible I also wouldn't want it to be too large.
Any thoughts/advice appreciated. Thanks in advance,
Fred
Fat Angry Scotsman
PostPosted: 14:36 - 16 May 2022    Post subject: Reply with quote
Going to have to increase your budget for anything that is actually mid-range (even second hand).
The thing that always fucks you on cheap action cams isn't resolution, you can get a new 4K resolution action cam brand new for £50 but it will still blur. Not because of resolution but because of bit-rate.
This is a mid-range action camera but it's £140 and would be alright but probably shit at low light levels.
https://www.amazon.co.uk/AKASO-Waterproof-Navitve-Underwater-Batteries/dp/B0881FLJ1Q/ref=asc_df_B0881FLJ1Q/
Sorry to be the bearer of bad news but you're going to struggle hard on that budget as it barely gets you a new camera in the bargain bucket economy range of the spectrum.
ThunderGuts
PostPosted: 15:06 - 16 May 2022    Post subject: Reply with quote
To be honest, unless you're very determined I really do think even good action cams are a lot of effort for not much return. To give an idea;
- You need a half decent camera in the first place (so you're probably looking at a GoPro type - no idea what third party offerings are available, but as FAS has already said, it's not just the resolution, you need ability to process it, frame rate and optics that are half decent. Plus something waterproof).
- You need mounting options to make it work (chest strap, bar mounts etc..)
- Unless others are better, you'll need a load of spare batteries as they last less than an hour normally
- You need a decent size memory card to capture all the footage it makes
- You need a powerful computer to process said footage (and it's surprising just how much computer spec you need!)
- You need patience to trawl through it all and find the bits you want
It can be rewarding if you get it right, but don't underestimate the level of faff or "peripheral spending" that's required.
TG.
Fred3606
PostPosted: 15:08 - 16 May 2022    Post subject: Reply with quote
Thanks for the reply, I may increase my budget a little and keep looking.
I think I've seen akaso pop up a bit, any brands to look out for when searching?
Fat Angry Scotsman
PostPosted: 15:24 - 16 May 2022    Post subject: Reply with quote
In that price range it's mostly Akaso and the upper end of Apeman. There are probably other options out there but most will just be clones or re-brands of those two.
doggone
Well don't be tempted by older versions of gopro they are shit.
Far too good at crashing so you have to take battery out to reboot.
Battery life is diabolical too
The newer ones are probably better but not infallible from what I hear and too expensive.
I have an DJI Osmo Action I like a lot but not to use on helmet, I sometimes mount it on handlebars ram mount if going through a scenic or bendy stretch. It has never crashed and battery life is much more realistic up to two hours
They can be had new around £200 and I see some refurbs less than that seems a reasonable deal.
I do agree with points above you don't just buy a camera and get something worthwhile out of it. It takes a bit of trial and error to work out how to edit sections you want, add or remove audio then render your finished masterpiece. Then are you going to upload it to youtube or put it on facebook where it will still look crap unless your rendering was spot on.
Video files are large and demanding even at 1080p, and you need a decent PC to work with them or it will be very frustrating.
ThunderGuts
PostPosted: 15:35 - 16 May 2022    Post subject: Reply with quote
I know someone with a Hero7 (I've got a Hero4); they haven't improved. If anything, my old Hero4 is more reliable, although having no way to recce the field of view beyond turning on the WiFi tether (horrendously unstable) and viewing on the app is frustrating.
TG.
steve the grease
PostPosted: 15:37 - 16 May 2022    Post subject: Reply with quote
Don't make my mistake and buy a super cheap one, not worth it , the vibration on the bike destroyed the wifi link after the first run out. *
I bought an OLFI for about £150 and have been very pleased with it.
* That said you can have it for a tenner plus post if you want. Its a 'Konig CSAW100' As the wifi is us you have to take the card out. It has a spare battery.
Kawasaki Jimbo
PostPosted: 19:59 - 16 May 2022    Post subject: Reply with quote
I’ve dabbled with cheapish action cams (the last was a Goodman’s Go-Pro looky-likey; felt like quality but limited by the technology, and they haven’t improved much over the years either.) They we’re all briefly fun but quickly disappointing. Apart from the frame rate, battery life, image and sound quality there’s not much to see on your average trip, which is why you’ll see some YouTubers making an incident out of nothing. (Colchester cyclist Wolf Simpson, for example.)
The best I tried was a proper compact digital camera on a small tripod mounted to the tank and looking through the screen.* Even then, the effect of the lens, the way houses wizzed by, made it look like I was speeding when I wasn’t. I reckon any jury seeing the ‘evidence’ of another road user’s misdemeanours would just think I was at fault. Distances are also distorted.
* Unfortunately the screen is purple, but it came with the bike and I grew used to it so I’m not changing it. Laughing
Andy_Pagin
PostPosted: 00:05 - 18 May 2022    Post subject: Re: advice on midrange 'action' cams? Reply with quote
Second hand will most likely mean knackered battery, which on a cheapo cam will not be replaceable. When I retired my old Ghost Stealth2 the battery had deteriorated from a really good two hours down to about twenty minutes.
jeffyjeff
PostPosted: 07:40 - 05 Aug 2022    Post subject: Reply with quote
Here are two examples that show the difference between a low end and mid range action cameras.
The Vionmio was marketed as a spy cam or nanny cam. I bought it to keep an eye on the house on occasions when I am away. It is definitely not an action camera. But it is small, light, and at around $50, pretty affordable. It came with a clip that allows me to attach it to my helmet visor, so I put it to use on the bike. Here is an example of the video recording. https://youtu.be/pvnbo7Naj6E
After using the Vionmio for awhile, I decided to upgrade. I paid $339 for the DJI Action2. It has a ton of features, including adjustable frame rate and resolution. This clip was recorded at 1080P and 30 frames/second, which yeilds about 55 minutes continuous recording before battery life expires. A power pack piggy backs onto the cam that is good for 2 or 3 recharges. https://youtu.be/WaXm0Yj97iQ
In either case, the quality of resolution seems to tank when I edit the video down and post it to Youtube. Not sure if the editing software or Youtube is to blame for that. Take it for what it's worth. I'm mostly happy with the DJI, except that it overheats on hot days and stops recording. We had some 40 degree C days in Morocco this July, and I missed some good scenes because the camera quit working. Darn.
grr666
PostPosted: 09:17 - 05 Aug 2022    Post subject: Reply with quote
I got an used older Gopro Hero+ on ebay as a second camera to fix to to the bike in conjunction with my lid cam. Someone
bought it for a holiday then didn't use it again. It was as new, not a mark on it with a FULL set of mounts inc chest
mount, floats and selfie sticks etc for just £40. The app still supports it, can use my phone as a screen/monitor via bluetooth
and the image quality is decent. It's waterproof too.
Fat Angry Scotsman
PostPosted: 11:08 - 05 Aug 2022    Post subject: Reply with quote
You can immediately tell the DJI footage is better, there's way more definition and way less artefacts and tearing. What are you using to edit the video? Adobe Premiere or something free? YouTube is really bad for compression killing quality. What was your video render output settings? The best for YouTube is MP4 using H.264 video codec and AAC-LC audio codec.
doggone
PostPosted: 11:09 - 05 Aug 2022    Post subject: Reply with quote
The DJI can do much better even on youtube it might be exported at too low bitrate, but they seem to make a better job if you upload 4K or 2K (1440p) then let them create the 1080p version most will watch.
Editing video is a bit of a minefield and some older software does pretty badly with modern codecs and default rendering options for various planned uses. If you can't edit or re-render but have decent internet just upload near as possible original file.
jeffyjeff
PostPosted: 17:11 - 05 Aug 2022    Post subject: Reply with quote
Thanks, guys. I gotta admit, editing video is a challenge for me. NONE of it is intuitive; it's like I need to go to night school to learn what I'm doing. I found a free program called VideoProc Converter that is mostly intuitive for me. At least I can cut the raw video down to something usable. Video render output settings? No clue. Embarassed
jeffyjeff
PostPosted: 20:38 - 05 Aug 2022    Post subject: Reply with quote
I think I need to experiment with the DJI a little more. The adjustments allow for frame rates from 24 to 240 frames/second, and resolution from 1080P to 4K. Initially, I chose the low resolution and lower frame rate to extend recording time. That yields acceptable video on my computer. But the result is many miles of boring video that needs to be edited to access the good stuff. Yes, it is good to have the camera on and recording when something interesting comes along, (most times those unique, interesting moments are not repeatable) but you have to record a lot of crap to get there. Maybe I need to rethink my objective and strategy for recording motorcycle rides.
doggone
PostPosted: 21:33 - 05 Aug 2022    Post subject: Reply with quote
The frame rate is Ok and maybe better left on 24 or 25 unless you want to slow something down.
On the Osmo Action I usually record at 1440p - 4K does use battery and space a lot faster.
Mini SD cards are relative cheap these days get a V30 one ideally and 128GB is a decent size
jeffyjeff
PostPosted: 22:31 - 05 Aug 2022    Post subject: Reply with quote
memory is crazy cheap these days. I got a 128GB micro SD (EVO required by DJI) for $16 from Amazon. It holds enough to go through 3 battery charges before I have to download to my computer.
Hetzer
PostPosted: 08:17 - 08 Aug 2022    Post subject: Reply with quote
Cheap cam = cheap CMOS, so even with a good card you'll get that 'stepping' playback (I fucking hate that shit).
I have a GoPro 7 and it's damn good, the stabilization of it is nothing short of incredible (I see the camera jerking about on the bike but the footage is 100% smooth bar potholes).
Battery life is crap so you'll need spares. The onboard mic is good for static stuff but when moving you'll need a separate mic system. I use the RODE stuff, it's superb but not cheap.
For editing I use Filmora (superb). For processing, the lower your PC spec the longer it'll take to export the finished video. So crap PC = patience needed. For an idea, I have an i5 8600k at 5ghz and an RTX 3080Ti, a six minute vid takes about 1.5 minutes to export.
If you're not planning on public viewings (youtube etc) any old crap will probably do you though.
The last post was made 1 year, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.23 - MySQL Queries: 16 - Page Size: 116.55 Kb
