swampy |
swampy World Chat Champion
Posted: 19:23 - 07 Jan 2015 Post subject: |
I assume that Kevin McCloud has been round, what with the roof disaster and the newborn baby... Definitely his MO ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
Bubbs |
Bubbs World Chat Champion
SQL |
SQL World Chat Champion
Posted: 20:50 - 07 Jan 2015 Post subject: |
I may have a box of 100m Cat 6 you can have for postage in the stores, not sure if it got chucked or not before christmas. |
weasley |
weasley World Chat Champion
Posted: 22:18 - 07 Jan 2015 Post subject: |
chris-red wrote: | With ethernet, use CAT 6 cable, decide where you want sockets, add a few extra, all cables should go to the same place, somewhere out of the way and preferably central where you plug them all into a switch. Cat6 is rated to 100m, however shorter the better. |
Exactly what I did with our house renovation last year. I put two Cat 6 and two co-ax outlets in every room except for the sitting room (four of each), family room (4 Ethernet, 2 co-ax) and spare room/office (ditto).
This all ran to a central cupboard where I have the broadband modem/router and a gigabit network switch. I also had 4 co-ax run from where the satellite dish was going to be, so these feed into the same cupboard from where I can patch them to any room. If I was doing it again, I would run 8 from the dish, to allow for various Sky+ and/or Freesat options from an 8-port LNB. I do also have one co-ax running from the loft, so I could hook up an aerial one day, if I wanted.
I considered wired audio but decided if I want it in the future I will go down the Sonos route, as I couldn't be sure where I wanted speakers etc.
Remember to consider any needs outside... power, data etc for out-buildings, Xmas lights, CCTV or other outside use.
I used Cat 6 for current and future-proofing. Again, I considered optical but decided to go a bit more mainstream. Wired can also be used for stuff like telephone, HDMI and other data shifting.
Do not underestimate what you might want to plug in. Without really trying, in our family room we have the PS3, Apple TV and Sky+ box plugged into Ethernet. And that's without a smart TV or blu-ray player. Elsewhere there is a desktop PC and Vodafone SureSignal with the possibility of a NAS HD drive, printer, additional TV(s), blu-ray player and so on... you get the point. ____________________
Yamaha XJ600 | Yamaha YZF600R Thundercat | KTM 990 SMT | BMW F900XR TE |
Chinaboy |
Chinaboy World Chat Champion
Posted: 04:51 - 08 Jan 2015 Post subject: |
This thread rocks!!
You are doing a great job, looking forward to the next update. |
Bubbs |
Posted: 14:40 - 08 Jan 2015 Post subject: |
weasley wrote: | chris-red wrote: | With ethernet, use CAT 6 cable, decide where you want sockets, add a few extra, all cables should go to the same place, somewhere out of the way and preferably central where you plug them all into a switch. Cat6 is rated to 100m, however shorter the better. |
Do not underestimate what you might want to plug in. Without really trying, in our family room we have the PS3, Apple TV and Sky+ box plugged into Ethernet. And that's without a smart TV or blu-ray player. Elsewhere there is a desktop PC and Vodafone SureSignal with the possibility of a NAS HD drive, printer, additional TV(s), blu-ray player and so on... you get the point. |
Thank you for this reply, ok so if you look at the following plans could you tell me if it makes sense?
What would you do with this space?
https://i.imgur.com/dkjflLJ.jpg
https://i.imgur.com/cT3dEqD.jpg
Quote: | This all ran to a central cupboard where I have the broadband modem/router and a gigabit network switch. I also had 4 co-ax run from where the satellite dish was going to be, so these feed into the same cupboard from where I can patch them to any room. |
You mentioned patching - how does this work? Is there other tech you need to patch? (Have no clue about this stuff)
All I know is that a coax allows tvs in all rooms of the house to watch whatever is on sky. Does having more than one coax allow more things? Will I for example be able to change the channel on the sky box from upstairs etc.
Also would you run all the ethernet cables and coax to the same spot?
Any advice would be appreciated.
(I've attached PDF's of the plans just in case someone would like to draw their own designs)
EDIT: Also what speaker cables should I buy? Not sure if there are different types but be good to know what you all think ____________________ Life begins at the end of your comfort zone. |
Wave2k |
Wave2k G's Stalker
Bubbs |
MarJay |
MarJay But it's British!
panrider_uk |
panrider_uk World Chat Champion
map |
map Mr Calendar
Posted: 17:39 - 08 Jan 2015 Post subject: |
FWIW and apology of covered but I recall a thread on here once that said double up on the ethernet (cat 6) points. This was I believe to allow HD video? I forget the details but I do recall thinking it was a good idea for whatever the reason. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger? |
GrumpyGuts |
GrumpyGuts World Chat Champion
Posted: 02:32 - 09 Jan 2015 Post subject: |
I've only just noticed this thread. You mentioned to me in the car (BBQ) what your plans were for this when we drove past this and I thought it would be awsome.
Well, yeah it is! Can't wait to see it finished, Dude ____________________ My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012 |
Bubbs |
Dalemac |
Dalemac World Chat Champion
CaNsA |
CaNsA Super Spammer
Matt B |
Matt B World Chat Champion
Iain. |
Iain. Could Be A Chat Bot
Posted: 11:05 - 09 Jan 2015 Post subject: |
Have never seen those USB wall sockets before, very cool! |
weasley |
Posted: 11:42 - 09 Jan 2015 Post subject: |
I got some good advice here.
To cover some points:
Yes, I ran everything to the same location in each room and in my "switch room", which houses my router/wifi, network switch and co-ax patching. In truth, so far I have only a limited number of coax and ethernet requirements so I have all ethernet cables connected directly to a port on the switch and co-ax is 'patched' simply by using an f-type female-to-female between the source cable (from the dish) and the room feed cable. Don't forget you'll need power in this cupboard.
In the rooms I used the Click New Media modular faceplates and appropriate modules - all co-ax are terminated with an f-type at both ends (male at the room faceplate and female in the switchroom) and all ethernet with a Cat 6 port at the room faceplate and a Cat 6 RJ45 plug in the switchroom.
You can use ethernet to transmit HDMI but it needs an adaptor and it takes up two ethernet cables. So if you had a Blu-ray in one room you could send a full HD signal to a TV in another, by sending the signal from the Blu-ray into ethernet then patching the rooms together at the switchroom. If you had a Sky box you could use the co-ax output from it to send it to another room, but this would be standard definition only and would be an RF-modulated signal (so you would have to 'tune' your TV in to the signal). If you were using a Sky box remotely you can control them using a TV Link (Magic Eye) with a Sky remote, or (my preference) use the iPhone/iPad app to control it over wifi.
I can't see any need for 8 co-ax at any location - at most I would say 4 (so two satellite feeds, maybe one for signal return and one for a Freeview aerial source). I may be overlooking something though.
Also think about how you get the broadband feed to the switchroom. I had a Cat 6 cable run from the telephone master socket (just inside the front door) to the switchroom. Once the master socket was connected to the phone line I used the Cat 6 as a massively over-engineered phone extension line (ie I used only 2 of the 8 available strands) to put an extension socket in the switchroom, which the broadband router plugs into. This is ADSL broadband.
My future aspiration is to get a small rack into which I will mount co-ax and ethernet patch panels and the network switch. I may also look into a proper AV distribution system, but that is something of a pipe dream. At least I have the connectivity in place to enable this (and plenty of other stuff) should I want it.
I do also use wifi (tablets, phones etc) but if a device has ethernet I will use it, and when selecting a new device I will prefer an ethernet-enabled one. Whilst the speed limit I have at the moment is my broadband (for online streaming/downloading etc), internal streaming is fast (so streaming stuff from the PC upstairs to the TV downstairs via PS3 or Apple TV, for example). ____________________
panrider_uk |
DOS |
DOS World Chat Champion
Bubbs |
chris-red |
Posted: 19:07 - 11 Feb 2015 Post subject: |
https://www.techwyse.com/blog/wp-content/uploads/2014/08/6.jpg ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
Bubbs |
Posted: 10:23 - 12 Feb 2015 Post subject: |
Continued....
Internal skin of brickwork rebuilt with the use of a lintel and some celcon blocks and bricks
https://i.imgur.com/g6VCEoV.jpg
https://i.imgur.com/k1gveIx.jpg
External built back up with bricks. Needs a facia and soffit and she will be looking lovely.
https://i.imgur.com/AuQAeub.jpg
Internal: Utility room needed to have a waterproof covering to the brickwork. I was toying with the idea of doing stud wall but it would have taken too much space. So elected to go for Feb Render Mix waterproofer mixed in with cement. Slapped it all on the brickwork and then once dry doused it with more render mix to make sure no water seeped through.
https://i.imgur.com/fA0rYvV.jpg
Utility room now dry, currently in the process of battening it out with 2inch timber
https://i.imgur.com/XLHnypP.jpg
And insulating with 2 inch Kingspan foiled insulation.
https://i.imgur.com/xqFbTtr.jpg
Only other updates are that I got the electric supply fixed into the house as it had come out and we were being quite blasé about man handling the cable - if there was even a nick in it we would have been brown bread. Electric company told me to keep well away from it even though I'd been man handling it for a good few months.
https://i.imgur.com/I62veVO.jpg
Also decided I would give electrics a go and move all the breaker box and associated cables myself. I put a crowbar to it, ripped out two of the main feed cables which started sparking like fuck.... I shit myself. However once the main power was hanging loose there was no more power going to the breaker/fuze so I moved it all and got my electrician mate to re-connect. Was going to do it myself but I was on my own and sense prevailed.
https://i.imgur.com/d53G68h.jpg
Temporarily installed the wood burner. Need to buy a vitreous pipe and a couple of other things to do it properly but it works as a temporary heating solution.
https://i.imgur.com/quTtQ46.jpg
The flexi flue you can see above is cemented into the chimney cavity with a mix of vermiculite and cement.
She's fully connected all the way up the chimney. With a flashing kit and a chimney cowl. I went for black in the end because Chrome seems to blacken from soot.
https://i.imgur.com/I4eXTZs.jpg ____________________ Life begins at the end of your comfort zone. |
Bubbs |
atg90 |
atg90 Two Stroke Sniffer
The last post was made 9 years, 82 days ago. Instead of replying here, would creating a new thread be more useful? |
