bikertomm |
bikertomm World Chat Champion
Posted: 15:20 - 13 Apr 2012 Post subject: |
Did you try hitting it with hammer gently?
Also, following this thread with interest as mine sometimes does this.
____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
P. |
P. Red Rocket
Posted: 15:25 - 13 Apr 2012 Post subject: |
WTF, everyones starters are playing up |
BikeNewbie |
BikeNewbie Scooby Slapper
P. |
P. Red Rocket
BikeNewbie |
BikeNewbie |
Usher4566 |
Usher4566 Spanner Monkey
BikeNewbie |
Usher4566 |
Usher4566 |
Posted: 18:42 - 12 Jun 2012 Post subject: |
If you bike won't start the first thing to check is the battery. Is it in good condition and fully charged ? See the Battery Page. If the battery tests good and the solenoid clicks at you, the solenoid might be corroded inside. To check, bypass the it. A real down and dirty way is to just connect the two big posts on the solenoid with a (OLD) screwdriver. There will be lots of sparks so have a good Fire Extinguisher handy. If nothing happens when you do this, the starter wires are broken or corroded, the starter is dead, or the starter is not grounded right. Try bypassing the everything. Hook a heavy jumper cable straight from the battery to the starter. If nothing happens, most likely the starters dead. You can also run a voltage drop test, to test the starter cables. See the Electrical tests page. If the starter works when you jumper the two terminals then you need a new solenoid. If the starter works and the solenoid does not click, the solenoid might be dead or it might be that the starter button is corroded and not making good ground or the wire going to the button may be broken. Sometimes there is a fuse in the starter system, be sure to check it. Also, on new bikes, big brother has now put in all kinds of "Safety" switches to protect us from ourselves. I don't particularly like them, however, I do have at least one rather vivid memory of trying to turn left with the side stand of my Norton down ! Anyway, check all those switches before you go and replace starters, solenoids, etc. They are usually on the clutch lever, side stand, and neutral switch. Older bikes don't have these "Helper" switches so their wiring is a bit simpler. ____________________ New cd200 benly owner |
Usher4566 |
There is a gap of 5 years, 314 days between these two posts... |
geohammer |
geohammer L Plate Warrior
The last post was made 6 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
