bezzabsa |
bezzabsa Scooby Slapper
Posted: 22:17 - 09 Feb 2014 Post subject: |
Jammy git!!!
noise is the wonderful kawasaki clutch rattle...as standard from the factory..
550 was underrated but still a good bike..search ebay for the 750 fairing which will make riding it a bit more pleasurable
https://japantrip.tripod.com/rides/gpzb750.jpg |
Fladdem |
Fladdem World Chat Champion
Posted: 20:58 - 13 Jul 2014 Post subject: |
Update! At last. Told you it would be slow.
I snapped a banjo bolt in the caliper putting it back together. Luckily, the head snapped off before the bolt was tight, so I could slowly wind it out with the tiny bit of thread sticking out the end. So new banjo bolts all round.
I have got new brake pistons and seals in and new pads. I have bled the front brakes about 4 times now, they are better than they were but the lever will still come all the way back to the bar. Were they always like this on these bikes, does anyone know? My Varadero does it as well but you never need to squeeze the brakes on much harder than halfway on that bike. A test ride is needed.
https://www.youtube.com/watch?v=iMiEnXYPPA4
Another thing is that these screws on the front brake reservoir are knackered. The things are starting to round off and if I want to get them out, I have to use the impact driver to do so every time. even if I just put them back loosely. Can I get new ones any where? Will anything with the same thread work?
https://i1302.photobucket.com/albums/ag134/Fladdem/P7130180_zpsf9f5e4f9.jpg
Here's the oil that came out of her
https://i1302.photobucket.com/albums/ag134/Fladdem/P7130174_zps79cb1d6f.jpg
ALso, while fiddling around and checking her over, I spotted this wobbly sprocket, never had a cush-drive before, is it meant to do this? What may be causing it, what should I get to repair her?
https://www.youtube.com/watch?v=bnvP-6xmql0&feature=youtu.be
It's also taking longer than expected because I just got a new project on the go as well.
https://i1302.photobucket.com/albums/ag134/Fladdem/P7130175_zpsa8c33130.jpg
Thanks for reading! ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
Kickstart |
Kickstart The Oracle
chickenstrip |
chickenstrip Super Spammer
Posted: 23:16 - 13 Jul 2014 Post subject: |
Like the new project - that wheelbarrow will clean up just fine
Are the brake hoses original? Might need replacing to get good firm brakes, but doubt you'll ever get them as good as modern systems. I seem to remember older Kwaks like this generally having a bit of a wooden feel, but should be able to get them so the lever doesn't come back to the bar. |
Fladdem |
Posted: 07:27 - 14 Jul 2014 Post subject: |
I think the lines are after market, stainless steel braided on the front. I don't when they were fitted but they look in relatively good nick. I don't think I'm doing it wrong, because I did the back brake fine, that feels really good.
I am going to grab some more brake fluid on the way home tonight and give it another shot. I will pull it off.
After brakes, what would you attack next? I still need to clean the carbs properly because it's running quite rich, so I'll do that. What's going on with the rear sprocket, does anyone know?
Thanks. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
chickenstrip |
Posted: 07:56 - 14 Jul 2014 Post subject: |
Feckin hell, that's a lot of movement
Has it got any cush rubbers in there at all?! The rubbers may shrink/degrade over time.
Also, the sprocket carrier might have a bearing in it - check that too.
Braided lines sometimes take ages to bleed. You pump and pump and pump for what seems like forever, then bang! they suddenly firm up. |
c_dug |
c_dug Super Spammer
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 08:40 - 14 Jul 2014 Post subject: |
There's a paddle and rubber cush-drive in there; Get new rubbers for it; they are only about a tenner ISTR.
The sprocket carrier sits on the axle, and has a bush or bearing in the middle as it goes round with the wheel.. and that would appear baulked. Not sure on the Kwak, it's been 20 years since I looked at one, but may need a new sprocket carrier, if you can get one, if the bush/bearing isn't service replaceable; failing that; take it to a local engine re-conditioners, and ask them to re-bush the old one. They should be able to drill out the old one and shrink in a new bush; take the axle with you for them to measure up if you have to resort to that salvage. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
marc_cowley |
marc_cowley Derestricted Danger
Frost |
Frost World Chat Champion
bladerunner |
Bunny Lingus |
Bunny Lingus Traffic Copper
Fladdem |
Posted: 19:26 - 24 Jul 2014 Post subject: |
The bike is my dads old Raleigh, she found her way home after 20 years, not sure on model, I did look.
I'd heard the brakes were good, seeing as they came off the 750, a bit over-kill at the time. I like the engine, she seems quite responsive while revving her up in neutral.
It will slow down again for a while, like a moron, I put contaminated diesel/petrol in the daily ride, TTR250, so I have been sorting that out instead. I have also just got another new toy, needs a bit of work but mostly ready to go. Keep an eye out, I'll be showing that off very shortly. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
Pie-Roe |
Pie-Roe World Chat Champion
Posted: 23:36 - 24 Jul 2014 Post subject: |
I used wemoto for res caps for my GT550, should be the same.
Or measure the size and check against another bike where you can get them. I've got a stock of them kicking about as I got angry with buying cheap bikes and not being able to bleed and reseal them without a ballache so I just bought 20 odd. I think they were for a CBR600, but they've fitted a TLR, a ER5 and a Blackbird, so it shouldn't be too hard to find. ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
_Iain_ |
_Iain_ Banned
Posted: 08:50 - 25 Jul 2014 Post subject: |
Article Number: 92001-1055
Designation: SCREW-CSK-CROS,5X12,BLACK
Classification: Spare Part
Est. Retail Price: 1.64£
Thats the official bit for the master cylinder cap screws on an '87 model. Will check stock & if I've got a pair I'll get them posted to you. Ideally, would be good to know what year this is though just incase they changed them. ____________________ Please be aware that the above post may be full of complete nonsense.
Riding: '07 KTM Duke II, Baotian BT49QT-20 Driving: '88 Volvo 340 |
Fladdem |
Posted: 19:02 - 16 Nov 2014 Post subject: |
Today, I had a go at a master cylinder overhaul, to try and stop the brake lever travelling all the way to the handlebars.
Also thought it might be handy as a guide, I couldn't find much on t'internet.
First things first:
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160200_zps01613fdf.jpg
Began by loosening the screws on the master cylinder and removing the cap.
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160196_zps9b42cfde.jpg
I then sucked all the fluid out the master cylinder before attaching a pipe to the bleed nipple on the nearside front caliper, that's front left to mere mortals.
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160197_zps54b43656.jpg
I removed the lever to reveal the piston
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160199_zps40e9579f.jpg
In order to remove the brake light switch, to get more room into the master cylinder, I had to remove the throttle and the switch gear and slide the brake perch along
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160201_zpsf921e848.jpg
Brake switch out, one mashed phillips screw holding it in place.
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160202_zps29ca64ca.jpg
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160206_zps4345ef34.jpg
I removed a plastic locking tab from the cylinder using two flat-blade screwdrivers to slide it out.
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160203_zps64349442.jpg
I then pulled the first rubber seal out the cylinder.
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160204_zps00b0dadc.jpg
With a bit of a wiggle, and a gentle prising with a flat-blade, the piston can be removed with other seals and spring attached.
The piston looked like it was corroded a bit and the seals were swollen and looked a bit worse for wear on close inspection.
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160205_zps47adc2ab.jpg
New kit looked like this
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160207_zpsab5d011f.jpg
While everything was apart, I cleaned inside the bore of the M/C and reservoir with a clean rag and a bit of brake cleaner. I inspected the bore for any scratching or corrosion.
I installed the new washer provided over the end of the piston, then pushed the new rubber seal over the end, I lubed everything up with new, clean brake fluid and pushed it in.
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160208_zps0d891dfd.jpg
All pushed home, remember to keep the old plastic retaining device, I found this fiddly, trying to keep the rubber seal square inside the master cylinder and locking the plastic clip down so it was square and nothing was trapped.
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160209_zps9d6e7672.jpg
I re-installed the brake switch with a new screw that I happened to have laying around, actually it was a master cylinder screw provided by c_dug, who sent me a few variations of master cylinder screws to replace the mashed reservoir cap screws on my bike, unfortunately, they didn't fit my GPZ but some went on my other bikes and _Iain_ provided the fresh ones for my 550. So a big thanks to those two!
I re-fitted the lever and filled the reservoir again ready for re-bleeding.
https://i1302.photobucket.com/albums/ag134/Fladdem/Master%20cylinder/PB160210_zps68c2c9bf.jpg
Put everything back together, and just finished bleeding the brakes as the rain came in, well done me!
Seems to have made a good difference, to lever feel, it moves a lot smoother and springs back better as well as not travelling so far.
I also replaced the front brake pads today.
Hopefully more to come soon.
EDIT : I just remembered, if you do do it like I did there will be brake fluid inside the bore of the cylinder still, so be ready with a rag or something when you pull the piston out so as not to spill it on your nice shiny paintwork. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
Fladdem |
Posted: 17:12 - 27 Dec 2014 Post subject: |
Today, I decided to find out what was going wrong with the rear sprocket, why it was so loose. I can see why now...
Getting the wheel out was a right fiddle, you needed to remove the chain guard, brake caliper torque arm and you don't need to, but I found taking the silencers off made it easier, and then wiggle the sprocket carrier off while it was still in the swinging arm, before wiggling the rest of it around the plastic number plate holder monstrosity.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/PC270239_zps7aca3f8e.jpg
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/PC270240_zps24fab8d8.jpg
Mashed another screw. This one on the chain guard,
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/PC270241_zps7ac013ca.jpg
The sprocket carrier bearing, Can you guess what was causing the wobbliness now?
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/PC270242_zps5a2635df.jpg
The cush rubber looked OK,
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/PC270244_zps4343506d.jpg
I'm glad it was the sprocket carrier bearing and not the cush rubber, £11 rather than £45...
The cush drive rubber seems in good nick, it's a bit sloppy on the hub posts, but hardly anything, less than a millimetre. I was wondering if I could pack it out with something? Like with anti-roll-bar bushes, you can take the bushes out and wrap a bit of electrical tape around the bar before putting the bush back on as a temporary bodge for MOT...
Anything a bit more permanent than that for this? Going to order a chain and sprocket kit, new sprocket carrier bearing and then move onto the forks.
I also straightened out the offside pillion peg, somehow it's been bent down and melted onto the exhaust, so I straightened that out to keep it away from the exhaust pipe, if I ever need to carry a passenger, I don't want to have to clean burnt rubber off the bike for ages.
Also going to need to order a front brake lever, like a gorm, getting it off the paddock stand I managed to throw it onto its side and snapped my brake lever. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
chris-red |
Posted: 17:44 - 27 Dec 2014 Post subject: |
Use the rubber from the inner tubes of your other project. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
Ed Case |
Ed Case World Chat Champion
bradh511 |
bradh511 Scooby Slapper
Posted: 12:55 - 06 Jan 2015 Post subject: |
sounds the same as what the call the xj600 death rattle .. mine was as quiet as mouse after balancing carbs ... but i would deffo check cloth basket ____________________ Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013 |
Fladdem |
Posted: 19:27 - 24 Jan 2015 Post subject: |
Today, I decided to attack the rear wheel on my Kwak.
First thing, replace the sprocket carrier bearing.
So got the sprocket carrier on the very cluttered bench.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240281_zpsd2xdq4o6.jpg
Sprocket off
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240282_zpshvvrdvou.jpg
Worn teeth, change that.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240283_zps4ux4cr8m.jpg
The inner race just fell out, that's all the bearings that were left in there
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240284_zpstw5jn3kr.jpg
Circlip removed, using a centre punch and two flat blade screwdrivers.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240285_zpstr3xgjbd.jpg
Battered the old outer race out with a centre punch, assorted chisels and an old screwdriver. That handy oil can, actually is a mixture of engine oil and petrol, it's wicked, it came out of my dads GS850's sump when his floats got stuck and flooded the engine we have about 6 litres of it. It works so well for loosening stuff, as it's so thin.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240286_zpspcw4tm1f.jpg
A shot of the work bench, complete with H100S engine, a sub woofer, a stereo assorted exhaust pipes and at the very right, the front end of an MTX125 RWD
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240287_zpsb4ibfw5q.jpg[/img]
To push the new bearing in, I used the old bearings outer race, as it sits, perfectly on the new bearings outer race Only problem I had was that the old bearing got pushed into the hub as well. I used a block of wood and tapped it with a hammer.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240288_zpszwjsvzug.jpg
New Sprocket
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240289_zpsuv0ejif2.jpg
I followed chris-red's advice, I found an old inner tube and cut little sleeves out of it to sit over the top of each paddle on the rubber.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240290_zps6bjqgblu.jpg
I replaced the rear wheel bearings as well while I was at it. Look what was inside the hub, some springs all tangled up....
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240291_zpskdlex7kc.jpg
New bearings
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240292_zps2t9d4tme.jpg
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240293_zpshvt2sggb.jpg
Sprocket carrier back on
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240296_zpsrktbrqfo.jpg
That inner tub trick worked a treat, check it!
https://www.youtube.com/watch?v=6yIi61JcYpM
I wanted to try and replace the rear disc as well, it was advised on the last MOT, before I even looked at the paper work, I thought the disc was suspect, so I bought a new one. Unfortunately, the wrong disc turned up
Old Disc
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240297_zpstbjsueak.jpg
New Disc
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P1240298_zpsdwfb7576.jpg
The old disc mounts to the hub with five bolts, the new one that turned up had seven mounting holes. I'll see if I can get a refund, if not see if someone on here wants a cheap rear disc, it will probably fit most other bikes in the GPZ family, just check how the original disc mounts to the bike, if I can't get a refund or a swap.
Tomorrow, I'll have a go at the front sprocket and chain. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
Fladdem |
Posted: 19:04 - 07 Feb 2015 Post subject: |
In the end, I had to put the old disc back on, it's not too bad condition but is definitely something to keep an eye on in the future. It's annoying after paying sixty something quid for it, I can't use it. So, it's up for grabs for £50, or a sensible offer, got an advert up in the sale section, but I have no need for it and I can't be bothered to stick it on eBay
One thing I forgot to document, but back in September I did a mod to the gear lever, the original sat really close to the foot peg, my size 11's were struggling with it, and all the bushes had worn out in the linkage making it really sloppy and horrible. I thought about what to do about it, then remembered that my pit bike came with the original gear lever, my mate replaced it with an anodized one to unleash more power, or something.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070306_zpsos3lostu.jpg
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070307_zpsfkfo68ey.jpg
So I measured up the gear lever, it was 6 inches long, I then got my dad to measure back to just above my big toe, it happened to be 3 inches. SO I got out the angle grinder and removed three inches, chopped off the splined end and then three inches of lever. I then got the welder out and glued the now shortened lever back onto the splined end.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070308_zps1azdmknq.jpg
The original lever however, had a bend in it to miss the sprocket cover/crank case. So to avoid my straight pit-bike lever from gouging a mark into the engine, I cut a small V out of the lever, at the peg end, bent it out a touch and filled it in with weld again.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070309_zpsoiufdpse.jpg
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070310_zpststh6tyn.jpg
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070311_zpsfpaadxhw.jpg
The two next to each other
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070312_zpsuonduvwa.jpg
It works really well, I sprayed it with some VHT paint, but the length of time has let rust start coming through the paint again, obviously too thin a coat. I was worried it would make the gearbox upside down, but it still works the same and is much comfier and no slop!
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070313_zpsr3maeqcy.jpg
I also changed the front sprocket and chain.
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070314_zpseypveszr.jpg
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070315_zpskl1wa9kx.jpg
Sprocket was easy enough but the circlip holding it on had seized, I worked it loose and eventually managed to wiggle it off with a skinny flat-blade.
The chain was another matter, I bought a chain breaker tool the other day and couldn't wait to use it. I ground the head off a pin of my choice on the old chain, got the tool on it and started to try and push the pin out. The chain tool pin bent and snapped. Useless.
So I just chopped the chain in half with my angle grinder and was done with it.
I measured the new chain up against the old chain to find that the new one was slightly shorter. I hoped that that was just due to chain stretch and that with the wheel pushed further forward, it would fit.
Nope, still about 4-5 Links short
https://i1302.photobucket.com/albums/ag134/Fladdem/GPZ%20550/P2070316_zpspmxkkexw.jpg
I don't know what to do about that, can you buy links separately to extend the chain a bit? I have some spare links at home, but they're for a 520 chain, this one is a 530, so it won't work, will it? ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
P. |
P. Red Rocket
Posted: 19:24 - 07 Feb 2015 Post subject: |
I wouldn't. I'd just buy a larger chain |
Ed Case |
Fladdem |
Posted: 19:57 - 07 Feb 2015 Post subject: |
Yep, I've done it again, ordered a chain for a 1982 GPZ550, the year it changed to a Uni-trak rear end, and ordered a bit for a GPZ D1 instead of the H1, they use a 100 link chain and I need a 104 link.
I'll see if they'll swap it for the correct one. If not, I'll either have a spare, for if I fancy trying out a smaller front sprocket, or try to sell it, like my disc.
Ed Case wrote: | You haven't told us yet how the wheelbarrow refurb is coming along or are you too tied up messing with this old motorbike ?. |
I've just found no time for it. I was thinking about trying to hunt down some OEM handle grips. The front tyre is starting to crack, depending on my usage I may need something slightly stickier compound, I try to push my 'barrows quite fast and I need all the grip I can get. I am half tempted to keep the rat-look and lacquer over the patina, or give it a shock-blast and powdercoated back to original colour, but with faded red/orange pin-stripes to match the grips and wheel. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
The last post was made 9 years, 116 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 162.05 Kb
